Old 08-08-2006, 07:34 AM   #1
1982 31' Airstream310
Goose Creek , South Carolina
Flex Plate Problems - need info asap
My Brother is on a trip Sturgis SD and Broke Down on the Road in his 1982 Air Stream, Powered by a 6 cylinder Turbo Isuzu 353 Diesel with a Chevy Turbo 350 Transition. He is hearing a lot of noise at an idle, but none under power. He has found the Flex plat is loose and can be moved over an 1” back and forth.
My request is, does any one have a Parts Break Down or an Illustration of that area between the engine and trany. We need to learn more as to what is going wrong in there and the part numbers of the “adapter” and “flex plate” so we can find the correct replacement part the first time. Thanks to all that may help us in our time of need!
rklies is offline   Reply With Quote
Old 08-10-2006, 07:39 AM   #2
Janet H's Avatar
1964 26' Overlander
1964 19' Globetrotter
OlyPen , Washington
Images: 90
Sorry to hear you haven't been able to get this fixed. Anyone have any info available?
AirForums Custom Search
Janet H is offline   Reply With Quote
GREAT TECH INFO - good advice COArgosy78 General Repair Forum 6 10-11-2002 01:08 PM
Fridge Cooling Problems 68International Refrigerators 6 07-10-2002 03:53 PM
Airstream info Rodger Airstream Motorhome Forums 3 07-03-2002 09:15 AM
Need info on A/C unit on a 1975 26 ft Argosy ... Hayseed Argosy Motorhomes 0 06-27-2002 08:19 AM
TV Connection Plate winner Audio, Video & TV 10 06-16-2002 06:00 PM
