Old 12-20-2008, 07:38 AM   #1
Boom Sounds's Avatar
1991 25' Airstream 250
Oxford , Oxfordshire
Faulty wiper control unit
Hi - all - I have a problem with one of my wipers (1991 250 classic). My mechanic (who is v.reliable) has identified the problem as the wiper control unit. I've searched about but can't find any reference to this part. Does anyone know where I can find one?
many thanks
Nick
Boom Sounds is offline   Reply With Quote
Old 12-20-2008, 09:30 AM   #2
HowieE's Avatar
Princeton , New Jersey
Images: 12
Do you mean the wiper motor? If so you may find that the face, the plate covering the motor facing forward when mounted in the truck, of the motor can be unbolted and you should find a printed circuit board just under the cover. Look at the lower edge of the board for a fine circuit wire that has opened, as a fuse would. If so just solder a wire across this opening. The copper foil in question will be about 1/2 the size of the rest of the copper foil s on the circuit board. A GM planned failure point.
Noe sure your this will apply to your MH because of its age but this was a very common problem with many GM wiper motors for some time in the 80s.
Another approach to some GM wiper motor problems is just to give the motor a good whack with the handle of a screwdriver.
Good Luck
2004 Excursion 4x4
Old 12-20-2008, 01:14 PM   #3
Thanks Howie. I think it is the wiper/washer control module. It is attached to the back of the dash and is further upstream from the motors. I think it is an Airstream modification to the Chevvy chassis. There were a few items which were added by Airstream....and this was one of them. It might be a 'Dana wiper/washer control module'. Anyone any ideas if these are still made or whether you can get a replacement?
thanks
Nick
Old 12-20-2008, 05:54 PM   #4
HowieE's Avatar
Images: 12
See if this will work.
http://www.carlingtech.com/pdf/CarlingCTRL_LW.pdf
If it will work and you can't get it on your side of the pond let me know.
2004 Excursion 4x4
Old 12-21-2008, 08:49 AM   #5
Thanks Howie - looks v.interesting. I wasn't aware these units could be swapped out with newer alternatives. Has anyone else managed to change the original Dana unit with something else?
many thanks
Nick
Old 12-27-2008, 05:31 PM   #6
Silver Bullet
choctawmel's Avatar
1986 34.5' Airstream 345
choctaw , Oklahoma
many thanks
Nick
I made the mistake of taking my 'Silver Bullet' to a garage for alinment. Somehow they blowup the battery, started, backup camera, radio and the wipeshield wiper control. I pulled the controller box out, replaced a diode and some lands on the control board. Has worked every since. I think they tried to jump start it backwards. They broke my window latch too. I never went back... Go firgure.
You really can't find good help.
mel
choctawmel is offline   Reply With Quote
Pensacola Unit vs. Big Bend Tallahasse Unit gypsymoth WBCCI Forum 23 04-07-2013 11:19 AM
Help With Faulty Electrical Outlet GStephens Electrical - Systems, Generators, Batteries & Solar 9 09-29-2008 10:29 PM
Possible faulty fuse or short in lights? HELP!! chuman70 Electrical - Systems, Generators, Batteries & Solar 11 11-15-2007 05:05 PM
Rear Wiper... canny_banjo_man Mechanics Corner - Engines, Transmission & More... 0 05-27-2006 12:17 PM
Faulty Emerson RV E-330-5 Hot Water Dispenser winner Water Heaters, Filters & Pumps 4 08-02-2002 02:07 PM
