Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Motorhome Forums > Mechanics Corner - Engines, Transmission & More...
Old 01-21-2014, 05:08 PM   #1
mayco's Avatar
1982 31' Airstream 310
champaign , Illinois
Factory gauge removal
Howdy from the frozen tundra of central illinois! I need to troubleshoot my pyrometer gauge in my 82/83 310. Could someone enlighten me as to how one removes the gauge from the dash plate. Its not registering at all right now and i may just replace it rather than trying to fix it. Thanks so much and stay warm!
mayco is offline   Reply With Quote
Old 01-21-2014, 08:55 PM   #2
tony6373's Avatar
2000 28' Excella
1994 31' Legacy 30
Hillsboro , Texas
I just replaced my EGT today. There are about 7 screws that hold the instrument panel in place. Then a pair of nuts that hold the gauge in place. It tucks in behind a holder that holds most of the other instruments in place. And there is a black plastic ring that block out stray light. The original gauge was not much. You can replace it with a modern much better instrument for a couple of hundred bucks. I went with 2 1/16" Auto Meter. Hardest part of the refit was running the cable from the probe back to the instrument panel.
Good luck.
Tony T
2000 28' Classic TT
1994 30' Land Yacht M/H
tony6373 is offline   Reply With Quote
