Old 11-21-2007, 01:55 PM   #1
2002 31' Land Yacht 30
Nunica , Michigan
Engine Stutter Problem
I have a 2002 30’ Land Yacht with 28,000 miles on it. This summer it developed a “stutter” in the engine that occurs at both low and high speeds. When it does occur, it seems to be corrected by letting of the accelerator and then continuing. It happens once maybe every 40 to 50 miles? Any thoughts?
vplath is offline   Reply With Quote
Old 11-21-2007, 02:59 PM   #2
Ahab's Avatar
2008 22' Safari
Oracle , Arizona
Plugged fuel filter/pump or dirty injectors.
Ahab is offline   Reply With Quote
Old 11-21-2007, 04:17 PM   #3
bibbs's Avatar
1977 Argosy Minuet 6.0 Metre
1973 21' Globetrotter
1975 26' Argosy 26
Vista , California
Yes ,I agreewith Ahab,if you are on the road,try some STP injector cleaner.Worked wonders on my Jaguar and Jeep
bibbs is offline   Reply With Quote
Engine Revving Problem winner Mechanics Corner - Engines, Transmission & More... 19 02-08-2010 10:05 PM
Help on engine RonJudi Mechanics Corner - Engines, Transmission & More... 69 01-02-2010 10:13 PM
454 Engine Problem 85/345 Mechanics Corner - Engines, Transmission & More... 17 05-27-2009 10:33 AM
1983 310 Engine Problem Rik Mechanics Corner - Engines, Transmission & More... 7 10-28-2005 09:30 PM
Battery problem or converter problem Paul Daugherty Airstream Motorhome Forums 31 07-01-2003 06:16 PM
