Old 04-10-2006, 11:06 AM   #1
Mr. D's Avatar
1988 34.5' Airstream 345
White Lake , Michigan
Engine run on in my '88 454 AS
I just recently(two days ago) removed my charcoal filter in my Banks Power Pack system. I have felt a positive effect on over all power and performance in my 454 in a 345 MH. My only problem is that now when I turn off the engine I have substantial run on. My temperature gauge does not show any over heating but something is definitely wrong. Does anyone have any idea or solution to my engine run on...thanks for your help...Mr. D.
Mr. D is offline   Reply With Quote
Old 04-10-2006, 11:12 AM   #2
guy99's Avatar
1984 31' Airstream310
Dunsmuir , California
Images: 16
Didn't you say in another thread that your idle RPM are up. This could encourage run-on. Also since you seem to have removed substantial restriction in the air intake, I wonder if you could be running lean?
1984 310 Limited Motorhome
guy99 is offline   Reply With Quote
Old 04-10-2006, 11:45 AM   #3
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
when my choke sticks a bit I get some run on. Cleaning the choke and carb seems to always end it for me.
1966 overlander..sold
AIR #005
OUR AIRSTREAM PASSION! BLOG
RESTORING AN AIRSTREAM
retired!
Old 04-10-2006, 11:54 AM   #4
Well Preserved
overlander63's Avatar
1993 21' Sovereign
Colfax , North Carolina
Most vehicles of this vintage have an idle stop solenoid, or or idle increase motor, whatever it's called. If this is stuck in the "run" position, it will keep RPM up, and promote run-on. Just for S&G's, turn your curb idle down a couple hundred RPM, and see if this helps your problem.
Old 04-11-2006, 10:10 AM   #5
Mr. D's Avatar
Thanks to all problem solved
I returned to my engine with all of your suggestions. I discovered that my choke was not fully disengaging and therefore causing the engine to idle faster. A faster idle in itself seems to have caused the run on problem. A little more clean up and the choke seems to be fine. Thanks for the advice guys...everything is now ready and my rig should be rolling South on Thursday 4/13... Mr. D.
Old 04-11-2006, 12:18 PM   #6
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
Great to hear that it works. I keep a large can of carb cleaner always near the workbench.
AIR #005
retired!
Engine Revving Problem winner Mechanics Corner - Engines, Transmission & More... 19 02-08-2010 10:05 PM
Engine Oil Question ViewRVs Mechanics Corner - Engines, Transmission & More... 12 05-25-2008 08:45 AM
Help!! Engine Won't Start!! eraffety Mechanics Corner - Engines, Transmission & More... 41 07-05-2006 07:01 PM
454 engine questions Curtis-79MH Mechanics Corner - Engines, Transmission & More... 10 10-06-2003 06:22 AM
Engine Monitoring, gauges etc. thenewkid64 Mechanics Corner - Engines, Transmission & More... 1 07-25-2002 02:25 PM
