Old 10-16-2006, 06:39 AM   #29
Retired Moderator
john hd's Avatar
1992 29' Excella
madison , Wisconsin
Images: 40
andrew
from your photo it looks like the bumper sub assembly must be removed as well.
john
you call them ferrets, i call them weasels.
Old 10-16-2006, 08:31 AM   #30
RivetAddict
swebster's Avatar
1986 34.5' Airstream 345
Louisville , Kentucky
Given the choice (same money) between a local rebuilder and a crate motor with a warrantee....I think I'd go crate motor. As was previously said, you're not looking for a high horspower rebuild here...more like a tow truck motor....high torque at low rpms.
Steven Webster
1986 Airstream 345 Classic Motorhome
AIR 1760
swebster is offline   Reply With Quote
Old 10-16-2006, 09:12 AM   #31
3Ms75Argosy's Avatar
1975 Argosy 26
1963 24' Tradewind
Seattle , Washington
Gm Crate..
is what I'd buy. I had a friend build me my 350 v8 for my astro... and then fretted that wherever I was, I wasn't going to get warrenty service unless I took the engine out and back to the shop.
The short blocks are not that expensive... see also Summit Racing (delivered to you). Or your local GM dealer.
Marc
Old 10-16-2006, 09:38 AM   #32
76 Silver Argosy
abridges01's Avatar
1975 26' Argosy 26
Fallbrook , Southern California
Send a message via Yahoo to abridges01
Is the 502 HT a straight swap for a 454 lump?
Thanks folks:
So the local engine rebuilder (though I don't think there's anyway to confuse him with a hotrodder, more like an original 70's NASCAR mechanic!) is perhaps not my best option, and I thnk you for this valuable advise.
The SDPC "502 HT" engine sure looks a beaut, but is it a direct, and by that I mean bolt hole for bolt hope, replacement for my jiggered 454 block? I must ask the true purists to forgive me this sin, but I am not looking for more work right now, just the quickest and easiest means to replace my engine. If the 502 drops right in in place of the old engine then it could work (minus the $5K+ price tag of course ;-)
As to my pathetic attempts at removing the bumper and cowling, I will have another look (hopefully tonight) and see. These bumper bolts mentioned, do they run along the bottom of the front 'cross member,' possibly visible through the 'scoop' visible the photo in my last post, and number around 8 or so? If so, are they captice (wleded in place) or must I get a wrench on the bolt heads hidden inside of the box section running across the front to undo the nuts?
I am much obliged to you all,
Andrew
1975 26' Silver Argosy MH: Ethyl the Never Ready!
Fallbrook, Southern California
"Experience is something you never have... until just after you need it!"
abridges01 is offline   Reply With Quote
Old 10-16-2006, 11:38 AM   #33
1975 Argosy 26
1963 24' Tradewind
search "502"
..and I found that it seems to be the same casting block... BUT, you need a different intake manifold (and I'm assuming a new carb to pull more CFM's... what's recommended?). The higher intake means the doghouse needs to be modified (raised a bit) to clear the higher intake manifold (I'm assuming the intake runners are a bit higher/longer).
There seemed to be one member at least that did it...
I see some HP dreams in someone's eyes!
Marc
Old 10-16-2006, 01:41 PM   #34
RivetAddict
swebster's Avatar
I think there is a difference in the exhaust ports as well (square vs. oval) and some of the newer BB Chevy's don't have a mechanical fuel pump so you would need to go to eletrical.
Pound for pound the 502 would be the way to go. It's bascially what is in the "new" P30s (W22 & W24) from Workhorse.
Steven Webster
AIR 1760
Old 10-16-2006, 02:02 PM   #35
dinoburb's Avatar
1982 34' Limited
Tidewater , Virginia
Andrew,
If a straight drop-in replacement is desired then here is another option with an 18 month / 100,000 miles warranty from GM when installed in a Class A motorhome.
The 502 is a better, stronger engine but it will require some additional parts not currently installed on your present engine.
For either engine: headers, aluminum low-rise intake, and a carburetor designed for RV use will make a big difference.
Hope this helps.
Take care,
Old trucks and old trailers . . . a comfortable combination!
AIR 1446
W5CDR
A-6E All Weather Attack Driver, BUFF
USN Aircraft Maintenance Officer, Ret.
'91 Suburban R-2500 w/BBC
'78 Honda GL-1000
'72 Triumph T-100R Daytona
dinoburb is offline   Reply With Quote
Old 10-24-2006, 07:29 AM   #36
RivetAddict
swebster's Avatar
Andrew,
What is the verdict? Have you been able to locate a replacement?
Steven Webster
AIR 1760
Old 10-24-2006, 08:36 AM   #37
Chaplain Kent's Avatar
1994 30' Excella
Milwaukee , Wisconsin
Originally Posted by abridges01
Thanks so much to everyone sharing my pain here, it's true what they say; misery loves company
I realize I am coming in on this a little late but I sure do feel your pain. Having gone through this same thing with replacing the engine. Mine was ruined by a mechanic who used the wrong oil filter. My insurance company, American Family, paid for the new engine and then went after the mechanic. The work was done by an Isuzu truck repair facility.
Chaplain Kent
2015 Coachman Freedom Express 19RBS, Chummy IV- Ford Excursion- 7.3 Turbo-diesel
Chaplain Kent is offline   Reply With Quote
Old 10-24-2006, 04:15 PM   #38
76 Silver Argosy
abridges01's Avatar
1975 26' Argosy 26
No way to remove front end!
Hi folks:
Well I finally got to spend some quality time under Ethyl on Sunday, and I am now more confused than ever. From what I can see, there is no way to remove the front end as the box section securing the bumper is welded, with heavy 1/8th inch filets, to chassis and frame! (I cannot upload pictures from my hotel room here in Novi, MI)
This leads me to the nasty conclusion that I am going to have to try and drop the engine, and possibly lift the chassis, to get her out. All this on a slight incline not exactly favorable to trying to use a trolley jack to lower and roll out a very heavy block, but hey, if we wanted the easy way we'd have bought from Fleetwoood, Hoorah! (trying to pump myself up here ;-)
As to what I plan to do once I have the current lump out, I think it will have to be a crate engine; there's just to much unknown about the current one for me to go to all this trouble only to have something else (timing chain, valves, etc.) fail - possibly quickly followed by my marriage Hopefully a crate engne will give me a known starting point to work from.
Of course I am back on the orad for a couple more weeks now, but hope once this trip is over to have some serious time to really get to grips with Ethyl, so watch this space...
Cheers you all,
Andrew
Old 10-24-2006, 06:41 PM   #39
RivetAddict
swebster's Avatar
Think of it this way...you'll have a brand new engine that will service your cool coach for years to come. I've always looked at engines, transmissions, etc as replaceable components of our coaches. My 345 has almost 200K miles on the coach...everything works and its likely on it's 3rd powerplant.
If you can look at the long haul and plan to keep the coach for a really long time then this concept makes sense. I would rather keep my coach in the family and continue to invest in it as we go rather than make $750 a month payments on a SOB that will leak and fall apart in ten years. But I also drive a 71 Beetle so my sense of "normal" is a little tweaked.
Good luck with your R&R and keep us posted.
Steven Webster
AIR 1760
Old 10-24-2006, 06:51 PM   #40
1975 Argosy 26
1963 24' Tradewind
A couple of ideas....
An angle grinder should get that bumper off... once the engine is in, then weld it back on... or have brackets made to bolt it on.
I think I remember someone took their engine out the drivers window? Not sure how that would work though. Any autoshop classes at a local community college that you could enroll in ... and park that baby on their lift? Out the bottom sounds kinda hard... do you have to take the front axle off?
Marc
Old 10-24-2006, 07:53 PM   #41
RivetAddict
swebster's Avatar
Also, many modern Class A motorhomes remove their engine up into the cabin and out the entry door.
Steven Webster
AIR 1760
Old 10-24-2006, 09:50 PM   #42
JBK
JBK's Avatar
Grand Rapids , Up in the Nort' Woods of Minn.
Man, if I was going to all that trouble, I would seriously consider putting a diesel mill in there. Sounds a little more work than replacing the 351 in my old Mach I.
JB
86' 345 MH. Named "AirBus". The wife and I finally agree.
JBK is offline   Reply With Quote
Argosy Motorhome Manual & Brochures WANTED Rik Argosy Motorhomes 28 05-22-2017 11:45 AM
Stripping an Argosy CHRIS CANNON Cleaning, Stripping & Polishing 8 05-11-2017 04:42 PM
confused Argosy newbie Dave Cole All Argosy Trailers 23 09-15-2006 09:36 PM
454 engine questions Curtis-79MH Mechanics Corner - Engines, Transmission & More... 10 10-06-2003 06:22 AM
Engine Monitoring, gauges etc. thenewkid64 Mechanics Corner - Engines, Transmission & More... 1 07-25-2002 02:25 PM
