Old 01-03-2007, 04:44 PM   #1
Robfike's Avatar
1999 36' Land Yacht Widebody
Spencer , Indiana
Engine oil leak
Streamers,
I have suffered with an engine oil leak since getting the 345. It looked like it was coming from the crankshaft rear seal. As you all may know replacing this seal takes a lot of work.
I just had the coach to Green's Circle City GMC on the south side of Indy. I wanted to know what it would cost to fix the leak. Much to my very happy surprise they found that the oil filter adapter was the culprit. The gasket between the block and the adapter to be more specific. This was a very easy fix, and now I don't have an oil slick everywhere I park!
So if you are suffering with a leak at the rear of the engine, you may want to take a look at this gasket.
Later, Rob
Robfike is offline   Reply With Quote
Old 01-03-2007, 05:20 PM   #2
Aluminut
Silvertwinkie's Avatar
2004 25' Safari
. , Illinois
Isn't it great when you find that the issue was not as bad as you thought.....it's rare. Nice MoHo.
Old 01-03-2007, 05:27 PM   #3
str8strm's Avatar
1985 34.5' Airstream 345
Tujunga , California
Robfike:
No leaks yet, but good info. Thanks. Ron
Ron and Debbie Lawrence
1985 345 Motorhome...... delightfully tacky......yet unrefined
AIR 7992
str8strm is offline   Reply With Quote
Old 01-03-2007, 06:17 PM   #4
Well Preserved
overlander63's Avatar
1993 21' Sovereign
Colfax , North Carolina
The fittings for the oil cooler lines (if equipped) are also known to develop leaks in the same spot.
Old 01-04-2007, 04:52 AM   #5
TomW's Avatar
1967 26' Overlander
Huntsville , Alabama
Originally Posted by Robfike
... Much to my very happy surprise they found that the oil filter adapter was the culprit...
I had the same leak on my 7.4 liter engine repaired just a month or so ago. Apparently it is a fairly common leak path. I'm with Rob though - it looks a whole lot like a leaky rear oil seal.
I had planned to let the shop replace the oil cooler lines Terry mentioned because one of the lines was obviously leaking at the flex-to-hard-line union near the cooler itself. To my surprise, the shop said the leak was power steering oil dripping on the line and not motor oil seeping out.
After later verifying the shop was in error, I went by the local Chevy Dealership and asked for new lines to install myself, "Sorry, but those lines are NLA - No Longer Available."
Deciding to get a seasoned, honest professional's opinion on the lines' availability, I emailed overlander63 with my tale of woe. Within an hour he had replied with the telephone number of a Chevy Dealer on the west coast who had the lines and had already set aside two for me. Mrs. Claus ordered them for me, and I installed the lines this past weekend.
Thanks Terry - I really appreciate your "up & beyond" help with the oil lines.
Tom
Old 01-04-2007, 06:26 AM   #6
Chaplain Kent's Avatar
1994 30' Excella
Milwaukee , Wisconsin
What a wonderful way to start the new year, Rob.
I think I may have finally found someone to service Chummy and he's just a few blocks from my house. I had been noticing a shop with a lot of mid size older delivery vans and trucks sitting around obviously waiting for service so I stopped in to talk. Turns out the guy was the mechanic/driver for Allen Bradley, here in Milwaukee when they owned an Airstream Classic used as an airport limo. He was very knowledgeable and excited to work on one again. I have a long list of things I have screwed up or can not do myself so would screw up and made an appointment. Hopefully this will work out as well as your trip to the shop.
Chaplain Kent
2015 Coachman Freedom Express 19RBS, Chummy IV- Ford Excursion- 7.3 Turbo-diesel
Chaplain Kent is offline   Reply With Quote
Old 01-04-2007, 06:44 AM   #7
Robfike's Avatar
Spencer , Indiana
Chaplain Kent,
That is what I found. The shop I took our 345 to just works on the larger box truck stuff. A Chevy P-30 is what they see a lot of. Great guys to work with also.
Rob
Engine Revving Problem winner Mechanics Corner - Engines, Transmission & More... 19 02-08-2010 10:05 PM
Engine Oil Question ViewRVs Mechanics Corner - Engines, Transmission & More... 12 05-25-2008 08:45 AM
454 engine questions Curtis-79MH Mechanics Corner - Engines, Transmission & More... 10 10-06-2003 06:22 AM
Rainwater leak James Schmidt Leaks - Weatherstrips, Gaskets, Caulks & Sealants 8 09-11-2002 06:28 AM
Engine Monitoring, gauges etc. thenewkid64 Mechanics Corner - Engines, Transmission & More... 1 07-25-2002 02:25 PM
