Old 07-27-2009, 12:09 AM   #15
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Hi, so the push rod bent again, twice. Then I would guess that you have a stuck, siezed, or bent valve. Remove the head a fix it. This doesn't mean you have to have a new engine. Have both heads done. If the tops of the pistons still look good and no scoring on the cylinder walls, you should be good to go.
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
How to get to engine on rear diesel pusher? 442 john Land Yacht/Legacy Motorhomes 1 10-21-2011 10:26 AM
Replace engine in 95 LandYacht Diesel cjshaffer2 Land Yacht/Legacy Motorhomes 4 09-25-2011 07:40 PM
Lucky 28 :: 1962 Air Stream Safari indy Airstream Registry Discussions 0 08-19-2011 08:32 AM
Lucky 13 :: 1957 Airstream Wanderer Lucky 13 Airstream Registry Discussions 0 08-19-2011 08:31 AM
Engine troubles glassblower Land Yacht/Legacy Motorhomes 8 07-09-2011 08:03 PM
