Old 10-15-2008, 05:27 PM   #1
1984 27' Airstream 270
Wayne , Ohio
Engine Air Intake
I have a 1984 270 motorhome. My question is ,has anyone put a cold air intake air on their engine. I was driving in 80 degree plus temp, and the engine was cutting out bad. But when the temp. dropped it run great. So I thought the cold air intake would fix the problem. I tried to find one on-line, but no luck. Thank You for any suggestions.
tomjunw is offline   Reply With Quote
Old 10-15-2008, 05:52 PM   #2
Well Preserved
overlander63's Avatar
1993 21' Sovereign
Colfax , North Carolina
80 shouldn't give you problems, I'd look into the ignition coil, fuel pump, filter, etc. The motorhome has run this long without one, there should be no reason it should suddenly need one.
Old 10-15-2008, 05:52 PM   #3
TomW's Avatar
1967 26' Overlander
Huntsville , Alabama
Cutting out is a different problem
Originally Posted by tomjunw View Post
... has anyone put a cold air intake air on their engine. I was driving in 80 degree plus temp, and the engine was cutting out bad. But when the temp. dropped it run great. ....
I think you have mechanical problems up & beyond any benefit realized by a cold air intake.
Start with a tuneup AND replacing the corrugated hose between your air filter housing and the headlight mounting panel and go from there. It helped with my 454.
Tom
Old 10-15-2008, 06:00 PM   #4
Incorrigible
Ike T's Avatar
1976 Argosy 24
-- , Georgia
Cutting out as in "not running" or "just can't run at much speed"? The latter might be an air/vapor lock issue with your fuel system.
80 degrees is not usually hot enough to really aggrevate a vapor lock issue unless it's quite an air leak or you're really putting a demand on the engine.
Check all your fuel system connections and look for worn or split fuel lines.
Tim
Tim
1976 24' Argosy
1973 International Harvester Travelette 1210 4x4 'Bernard' 164" WB
1997 Georgie Boy 30' SuperDuty v10
Ike T is offline   Reply With Quote
Old 10-15-2008, 06:01 PM   #5
Vintage Kin
Fort Worth , Texas
I have seen dryer hose, pvc pipe and other such as "adapted" pieces to the OEM filter housing. Done in such a way as to drain any water, and not collect any extra dust (engine fan on unpaved surface, etc). If the air filter housing -- on a carburated engine -- uses exhaust manifold heat and/or intake manifold exhaust heat crossover, then, FIRST, clean these and replace any of the operational devices. Removing the intake may seem a big problem, but it isn't that bad IF PICTURES are taken first of how throttle and transmission linkages hook up. (Also, get factory service manual for help:: HELM, Inc).
On a carb'd engine, keeping fuel atomized is a function of heated intake AIR, etc. GM used to spec 105-115F as ideal. Repair first, adapt second.
Here is an example of an aftermarket housing. But be aware that cold start and cruise mpg will be affected negatively UNLESS the carb is modified to take advantage of the new situation. The choke is also in need of changes.
http://www.ramairbox.com/http://www.ramairbox.com/
On my last old car I used a phenolic resin 4-hole spacer (4-V carb), with a big aluminum plate underneath, (cut to fit around other parts) that kept manifold heat to a minimum (cold carb, hot manifold and regulated-temperature air). I achieved excellent fuel mileage and performance over the stock configuration, but it was time-consuming to get it straight. I also insulated fuel lines and used a vacuum-referenced fuel pressure regulator to keep fuel psi low at idle and cruise (high vacuum situations) and then a big free-flowing pipe when I tromped on it (and the secondaries were opened).
Cold air seems like an easy fix, but carb jetting, ignition advance, fuel pressure, and PROPER TEMPS are all part of the equation.
Old 10-15-2008, 06:04 PM   #6
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
basx
As dear Dad used to tell me...Keep it stupid, Simple.
Start out with the basics. A complete tune-up. Cap,rotor,plugs and wires, check the o2 sensor and EGR valve and don't forget the fuel and air filter.
W. H. Auden
"The hardest thing about Airstreaming, clearing your head and accepting how others feel itís supposed to be done"Ö..
Amanamus
"Tahawus"
Old 10-16-2008, 06:06 AM   #7
87MH's Avatar
1978 31' Sovereign
Images: 292
I have a 1984 270 motorhome.....I was driving in 80 degree plus temp, and the engine was cutting out bad. But when the temp. dropped it run great. ...Thank You for any suggestions.
As others have indicated, there are a variety of reasons that your 270 is acting like that....it COULD be a function of the air intake temp, but some interesting questions/solutions about alternative engine problems are here:
http://www.airforums.com/forums/f159...ade-16849.html
and a few more here:
ignition module
(remember, the ignition module is INSIDE the rotor cap)
and here:
7.4l tune-up
and even more here:
Help - MH Can't climb hills
As with all things old, the probable cause of your problem is most likely from multiple system malfunctions, keep at it, repair/replace the old stuff, and eventually you will have a dependable ride. The best thing about self-repair is that you will be able to recognize and repair future failures in short order, either on the road or at your home base.
BTW - in an attempt to increase the deplorable MPG's my 345 beast gets, I routed an alternative air intake to the air cleaner (leaving the original intact) - no discernable benefits were noted.
Please keep the Forum posted on your progress.
Dennis
WBCCI # 1113
AirForums #1737
Trailer '78 31' Sovereign
Texas Airstream Harbor, Inc.
Old 10-16-2008, 06:00 PM   #8
Wayne , Ohio
Tom
My 1984 doesn't have the intake hose. The carb. is a new Holley Quad. replacement. The fuel pump, fuel filter. plugs. wires almost new, also all rubber fuel lines. EGR has been eliminated. The exhaust comes off the manifolds at 2 1/4" for short distance, then goes to 3" w/flowmaster 50s. Thanks
Old 10-17-2008, 08:27 AM   #9
Well Preserved
1993 21' Sovereign
The ignition coil could be breaking down. It is the type that fits in the top of the distributor cap? Also, did this start happening right after insstallation of the carb, or some time after? What is the cfm rating of the carb?
Old 10-17-2008, 02:36 PM   #10
TomW's Avatar
1967 26' Overlander
Carbon traces in the cap
You didn't mention cap & rotor. I let the parts guy talk me into replacing my black-in-color cap & rotor with a blue one, "You'll get more power from this brand!" I know that snake oil can sometimes be blue-in-color, but I bought what he was pushing because he was so enthusiastic, and there was no appreciable cost difference. As Terry probably knows, my Burb did not subsequently leap taller buildings than it previously did.
Terry had a good point about cfm. IIRC, lower cfm helps torque. Is the Holley rated higher than the OEM Rochester with regards to air flow?
Tom
Old 10-21-2008, 06:22 AM   #11
GlenCoombe's Avatar
1984 28' Funeral Coach
Belleview , Florida
Images: 27
When was the last time the filter at the carb was replaced?
You can stuff a lot more cold air into the carb by removing the factory air cleaner and going with a remote cone type filter and a 4" air hose from the front grill.
Take a look at my photos of my remote filter and air intake fabricated from flashing aluminum. It's an easy DIY project.
http://www.airforums.com/attachments..._004_thumb.jpg
Glen Coombe AIR #8416
Former Rolling Showroom & PuttLab (now party bus)
"I'm not an expert. But I did sleep in an Airstream last night."
GlenCoombe is offline   Reply With Quote
Old 11-02-2008, 06:29 PM   #12
Wayne , Ohio
I'm not sure, but what may be happening is on hills I loose vacuum, causing the heat riser & the heat baffle on the air cleaner to close. In turn all I get is hot air. The Ram Air looks like it will make a big differance, along with fixing my other problems. Thanks to all for your help.
Old 11-03-2008, 11:27 AM   #13
Vintage Kin
Fort Worth , Texas
Those items operate on temperature, and vacuum is used only to power them. Replace or repair them first, and have a first rate mechanic be sure the choke is operating properly. These problems were ones that caused a lot of people to trade a 1970's vehicle too early (to my benefit: $20 plus an hour or two, back then). Check that the air filter housing gasket (to carb) is new, and that the carb gasket (to intake) is not leaking.
It is generally a mistake to change the air intake system, for longest engine life. Regulated air temperature is key to performance, economy and reliability.
The cooling system is more than likely neglected, and a thorough cleaning -- plus component replacement (fan clutch, thermostat, water pump; all hoses and fasteners; possibly radiator) -- will pay long-term benefits. Gasoline engines run hot, and should have at least a 185-195F thermostat.
The exhaust system is more likely to be a source of lost performance (press-bent versus mandrel-bent pipes; the tightest bend is the actual diameter of the system).
As to losing power on a long, uphill pull I would suspect inadequate fuel pressure. I would replace the engine-mounted vacuum-diaphragm pump with an electric pusher (like a Holley "blue" pump) and install a pressure regulator. Duplicate the factory fuel lines with NEW PARTS. (That alone may "solve" the problem).
Old 11-11-2008, 07:50 AM   #14
GlenCoombe's Avatar
Belleview , Florida
Images: 27
Gee, on the up hill climb the angle can be quite extreme too.
The most overlooked fuel filter is the internal filter at the front of the carb. An extreme angle can cause sediment in the filter to block flow as it can in the inline frame mounted filters.
Has anyone ever removed their air conditioning from engine compartment Mr. D Mechanics Corner - Engines, Transmission & More... 19 06-07-2007 07:11 PM
Engine Air Conditioner Howard Lefkowitz Classic Motorhomes 6 10-23-2006 12:29 PM
Ford 460 Air Intake noiva Mechanics Corner - Engines, Transmission & More... 5 04-15-2006 07:19 PM
More intake air GlenCoombe Mechanics Corner - Engines, Transmission & More... 7 02-04-2006 07:15 PM
will atwood drain from cold intake 63air Water Heaters, Filters & Pumps 2 09-14-2005 04:50 AM
