03-03-2016, 08:47 AM
#101
Richmond
, Kentucky
Originally Posted by bkahler
I forgot you have the rectangular double bulb arrangement so those won't work for my Argosy.
I'll probably give something like these a try.
I can say for certain these bulb housings do NOT fit the single bulb Argosy motorhomes or any other vehicle that uses the 7" bulbs. The profile where it sits in the headlight housing is all wrong. I don't know what the manufacturer was thinking when he made these but the don't fit vehicles with the 7" headlights that were made from the 70s and earlier.
1975 24' Argosy Motor Home
03-03-2016, 09:43 AM
#102
1982 31' Airstream 310
champaign
Weird eh? Like I said, I found this reference to the regulator in an old thread, Im not even absolutely certain its the correct one. But, Im gonna pick one up, if I can find one, and use it as a backup on board part. We'll see. Here are a few more cross references
Cross Interchange Parts
Factory Number
CARQUEST 271697
GM 88925132
GM 94205956
BOSCH 30522
AIRTEX 1V1079
ACDelco D609A
BWD R595
03-07-2016, 02:17 PM
#103
champaign
Well just so I dont let this thing die.......I got the acdelco voltage regulator today and it was wrong. So I finally called Haimlton Engine repair and they were able to source me one out of Ohio. The correct part number for our Isuzu 6bd1 voltage regulator is 894202581-0. Thats the Isuzu number not the Denso. Im just going to call Hamilton first from now on, geeeeeeeeezzzzzzzzz, I searched for days and couldnt find that thing. They have over 60 in stock. When dealing with Hamilton you will need your serial number off your engine block. I had mine already written down but they will ask for it. Its bern 3 yrs since I found mine but I believe its on the drivers side, stamped on the block just above the oil pan.
Mike
03-07-2016, 03:23 PM
#104
1985 32.5' Airstream 325
Lindsay
, Ontario
Mike
Did Hamilton give you a price on the reg
03-07-2016, 03:45 PM
#105
champaign
A bit pricey, $68.00 USD, but man, I dont even care at this point. I Googled that part number and got ONE HIT for a chinese supplier that was out of stock. When I hit "images" it showed exactly one picture. I really found it hard to believe that there wasnt more info on the forums, maybe they just dont wear out very often. For some reason I thought its a good idea to have a spare on hand while on the road. They are a mechanical device.
03-07-2016, 04:07 PM
#106
Lindsay
, Ontario
You are right, The price is not that bad let me no when you get it if it is the same as the pic sent you of mine.
What is the shipping to your addy
03-07-2016, 05:11 PM
#107
champaign
I believe that price includes shipping but cant be too much even if it doesnt. Here is a pic of the aftermarket regulator from the other supplier that is out of stock.
It seems that on these Isuzu industrial motors that they tie the regulator part to the individual alternator. Rather than listing the regulator to an specific vehicle or piece of equipment. They even refer to it as " alternator regulator" in the name of the part. In the pic you sent me, someone had reworked the wiring to the regulator because of the butt joint splices.
So now we have the part numbers for the oem alternator and regulator. (Smartstream had posted the correct alternator part number in a post from a few years ago). Another little quirk in the search for these electrical parts is that there is an Isuzu part number and the part manufacturer part number, in this case Nippondenso.
So hopefully now I will be carrying a spare of each on board the rig, (total cost for the both at right around $200.......not bad if indeed they both are correct). A little peace of mind anyway dont ya think?
03-07-2016, 05:53 PM
#108
Lindsay
, Ontario
You are right about having spares because you never know when it might be needed. And it will happen in the middle of no where.
When you get the reg check and see if the back side where the wires attach to the reg are the same as mine, My reg looks to be original I wonder if Airstream spliced the wires to match their system I haven't had a chance to look at another one.
Maybe you should look and see if yours has spliced wires then we would know.
I am going to have to get a reg because the plug on mine is in bad shape, The inside is burned and the wires won't stay in the plug.
03-07-2016, 07:25 PM
#109
champaign
Mine doesnt have the splices. It appears to be factory intact.
03-08-2016, 10:59 AM
#110
champaign
New regulator arrived by Fedex this morning. Its an exact match, wire color code even mstches
03-08-2016, 11:02 AM
#111
champaign
Oops, wire color even matches diagram in the Airstream manual that I have. If any of you diesel owners dont have the diagram of the alternator/regulator wiring here it is:
03-08-2016, 11:22 AM
#112
Richmond
, Kentucky
John, if you need to order one feel free to ship it to my place. I can bring it along to the get together with everything else.
