Old 11-10-2002, 08:29 AM   #1
Airstream Driver
PeterH-Airstreamer's Avatar
1997 30' Excella
Images: 51
emergency brakes
My 79 has rear drum brakes.
I just adjusted the emergency brakes and now have a strong emergency brake going forward. Going backwards I have virtually no emergency brake. It will pretty much role out of the driveway. I only saw one adjusting wheel. What gives?
1996 Airstream B190
1987 29' Sovereign Trailer
1997 30' Excella Trailer
AIR #13
PeterH-Airstreamer is offline   Reply With Quote
Old 11-10-2002, 08:39 AM   #2
LOST , Hawaii
Rear axle brakes or the trans/driveshaft mounted brake?
John
74Argosy24MH is offline   Reply With Quote
Old 11-10-2002, 08:42 AM   #3
Airstream Driver
1997 30' Excella
Images: 51
drum emergency brake. I think only the rear disk brake rigs have the driveshaft brakes?
1996 Airstream B190
AIR #13
Old 11-10-2002, 09:17 AM   #4
LOST , Hawaii
Don't know if you have a manual, this is a synopsis for the pedal type:
Raise on hoist
Apply parking brake 1 notch from fully released.
Tighten equalizer nut until a moderate drag is felt when rotated forward.
Fully release brake and rotate rear wheels. No drag should be felt.
Shoes are leading and trailing (primary and secondary, I have heard both). The leading shoe helps drive both shoes into the drum. If it works forward, I would look at the rear shoe to see of it is glazed, loose on the pin, springs shot so it could move. Sounds to me like the hardware, the leading shoe is grabbing going forward but the whole assembly is not expanding enough to lock against the drum.
John
Old 11-10-2002, 09:50 AM   #5
Airstream Driver
1997 30' Excella
Images: 51
Thanx John,
I got it. I first adjusted the rear brakes even more. It's a myth that the rear drum brakes will always adjust automatically. The last thing you want to do is backing up a lot.
The further adjustment gave me a little more emergency brake going in reverse.
Then I took some of the stretch out of the cable, as you mentioned above.
I think there is a mechanical difference in emergency brake strenght going forward or reverse.
1996 Airstream B190
AIR #13
Old 11-10-2002, 09:59 AM   #6
LOST , Hawaii
Got to be, the leading shoe has more bite. The way the hardware forces it to expand going forward probably isn't a lot of help in reverse either.
John
Old 08-04-2012, 07:39 PM   #7
Airstream Driver
1997 30' Excella
Images: 51
I revived this old thread from 2002 to hopefully get some input on my 1987 345 emergency brakes adjustment. Since I have rear disk brakes, do we have driveshaft emergency brakes and how do they get adjusted?
1996 Airstream B190
AIR #13
Old 08-05-2012, 02:36 PM   #8
Waipio Rim's Avatar
1984 31' Airstream310
Honokaa , Hawaii
Attaching the pages from the "Chevrolet Motor Home Chassis Service Manual" on adjusting the driveline parking brake.
Waipio Rim is offline   Reply With Quote
Old 08-06-2012, 06:02 AM   #9
Airstream Driver
1997 30' Excella
Images: 51
Thank you kindly!
1996 Airstream B190
AIR #13
What is your Brake Controller of Choice? overlander64 Brakes & Brake Controllers 71 11-29-2008 08:40 AM
Some towing Q & A for newbies femuse Towing, Tow Vehicles & Hitches 3 08-24-2004 08:05 AM
Grabbing Brakes 74Tradewind Brakes & Brake Controllers 15 08-05-2004 05:26 PM
Intermittant Brakes dinoburb Brakes & Brake Controllers 4 11-12-2003 08:00 AM
Trailer brakes won't lock-up? John Brakes & Brake Controllers 24 02-06-2003 12:22 PM
