Old 09-02-2008, 10:20 AM   #1
Mr. D's Avatar
1988 34.5' Airstream 345
White Lake , Michigan
Electrical grounding problem with AC hook up
I recently realized that both my coach batteries on my 345 MH were completely dead. I had the rig plug in for more than a month prior to knowing this. After replacing the batteries, I realized that much of the wiring showed severe signs of corrosion. I have cleaned and replaced many of the main wires and connections. While doing this I realized the 80 amp fuse for the coach batteries was blown, it has been replaced also. Somewhere in all this I began to realize that the entire rig was giving off a strong shock ... particularly on or near the frame. Does anyone have an idea why this may be occuring. It does not occur while using my generator? Mr. D.
Mr. D is offline   Reply With Quote
Old 09-02-2008, 10:48 AM   #2
richinny's Avatar
2011 34' Classic
you might have what is known as a "hot skin".
http://www.airforums.com/forums/f37/...bad-41176.html
you can start by reading this thread.
Ricky
Old 09-02-2008, 12:01 PM   #3
HowieE's Avatar
Princeton , New Jersey
Images: 12
First I am assuming you only get a shock while the trailer is plugged into a Shore Line as DC will not give a shock.
My first thought would be to check to make sure you have a ground in your AC supply from the house. Take a voltmeter and read voltage from the hot leg to ground. If you do not get a voltage there you have an open ground in your house circuit. If the ground is good inspect the Shore Line where it goes into and through the coach for ware in the cord to the hot leg of your AC power cord that could be shorting to the chassis. Do this visually all the way to the AC panel if possible or with an OHM meter, and all AC circuit breakers in the coach turned OFF, look for continuity from the hot leg of the AC line to the coach chassis. You should not see continuity from the hot leg to ground. Lets define the short and reduce the risk before we look for the reason the batteries went dead
2004 Excursion 4x4
Old 09-02-2008, 04:20 PM   #4
mustang's Avatar
1986 31' Sovereign
Kent , Ohio
Howie Good Info! I had the same thing happen. Its a shocker, mine was a bad extension cord.
mustang is offline   Reply With Quote
electrical problem ALANSD Mechanics Corner - Engines, Transmission & More... 23 09-13-2015 07:20 PM
HELP! Electrical problem FranceyS Electrical - Systems, Generators, Batteries & Solar 6 08-03-2010 02:57 PM
Electrical Hook up Question. Gael79 Lights - Interior & Exterior 14 04-27-2008 10:20 AM
greetings and electrical problem wdm1 Member Introductions 2 12-18-2006 02:02 PM
how do you hook up electrical? rama777 Electrical - Systems, Generators, Batteries & Solar 22 10-09-2006 03:16 PM
