Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Motorhome Forums > Mechanics Corner - Engines, Transmission & More...
Old 10-25-2016, 09:43 AM   #1
coairstream's Avatar
1988 34.5' Airstream 345
Denver , Colorado
Electric Rear Fuel Pump 1987 290.
Hi! I'm suspecting my rear fuel pump is producing less than desirable pressure under load and I decided to replace it as preventative maintenance. At no huge surprise when my service advisor called me this morning saying it's not your typical fuel pump and the parts department is looking into it. I wanted to post to see if any of you had experience with a particular pump that is recommended?
Thanks in advance!
Cody
coairstream is offline   Reply With Quote
Old 10-25-2016, 10:09 AM   #2
WayneG's Avatar
1984 27' Airstream 270
Scotia , New York
Unfortunately I dont think I can help with your question because I did my own installation of a high pressure aftermarket in-tank pump (where there was none before) http://theouterlimits.ws/projects/ai...uel/index.html
I am curious on how they pulled it off in a 87?
In my installation I cut a hole in the floor over the top of the pump flange. I was wondering if they made easy access in the OEM version?
Wayne
WayneG is offline   Reply With Quote
Old 10-25-2016, 10:28 AM   #3
I know in 1986 Airstream used a Carter P4070 fuel pump for the rear pusher pump. If your coach is 454 powered and doesn't use an in-tank fuel pump then this pump should do the job.
1975 24' Argosy Motor Home
Old 10-25-2016, 11:47 AM   #4
Keen amature
martin300662's Avatar
1975 20' Argosy 20
Chestfield , Kent
I recently had a Carter P4070 installed in Bella (350 small block) and the mechanical pump removed. Massively better starting, but had one or two cases of the engine dying when sitting in drive waiting for lights to change. Dropping out of gear allows the engine tick-over to pick up....haven't tried to fix the issue as Brad is holding an idle stop solenoid for me that will allow the fast idle (out of gear) to be correctly set, to give the correct idle under load.
martin300662 is offline   Reply With Quote
Old 10-25-2016, 11:53 AM   #5
Martin, maybe I ought to mail the idle stop solenoid to you. Originally I think the plan was for you to drive Bella to Richmond and I would install it here.
Doesn't look like that's going to happen now
Old 10-26-2016, 12:24 PM   #6
Grosspoluter's Avatar
Franklin Park , Illinois
I installed a carter p4070 in my 345 (454 carbureted)
My 345 didn't have one, maybe the previous owner removed it I'm not sure but I installed one and that seemed to help with stalling problems, and sometimes fuel starvation under load.
I have a fuel pressure gauge on my dashboard that I installed. My fuel pressure went from 1 to 2 psi to about 4 or 5 psi with the carter pump "helping" the Mechanical pump on the engine
Grosspoluter is offline   Reply With Quote
1987 Airstream 290 29 - Ohio schnitz Airstream Classifieds 0 06-06-2016 11:26 AM
1987 Airstream 290 29 - California ericjan2 Airstream Classifieds 0 10-03-2015 10:19 AM
1987 Airstream 290 - Illinois Janet Nelson Airstream Classifieds 3 11-05-2013 09:07 AM
Electric fuel pump and fuel line routing cooperhawk Mechanics Corner - Engines, Transmission & More... 7 02-06-2003 10:16 AM
