Originally Posted by martin300662
I recently had a Carter P4070 installed in Bella (350 small block) and the mechanical pump removed. Massively better starting, but had one or two cases of the engine dying when sitting in drive waiting for lights to change. Dropping out of gear allows the engine tick-over to pick up....haven't tried to fix the issue as Brad is holding an idle stop solenoid for me that will allow the fast idle (out of gear) to be correctly set, to give the correct idle under load.
Martin, maybe I ought to mail the idle stop solenoid to you. Originally I think the plan was for you to drive Bella to Richmond and I would install it here.
Doesn't look like that's going to happen now
