Old 05-26-2008, 08:26 PM   #1
76 Silver Argosy
abridges01's Avatar
1975 26' Argosy 26
Fallbrook , Southern California
Send a message via Yahoo to abridges01
Electric cooling fans - worth the investment?
Hi folks.
I have a 1975 26' Argosy MH with Chevy 454 engine reinstall underway and was wondering if anyone has experience of switching out the standard viscous mechanical belt driven fan with a single/twin electric cooling fans?
I have heard cooling can be an issue with the Chevy P30 chassis RV's and am prepared to make the uinvestment, but read on the Flex-a-lite faq pages that they do not recommend use on 4 core rads or RV's.
If anyone has had positive experiences, can you please advise brand/model and source? Oh, and if you're available to come round and fir it...
Cheers,
Andrew
1975 26' Silver Argosy MH: Ethyl the Never Ready!
Fallbrook, Southern California
"Experience is something you never have... until just after you need it!"
abridges01 is offline   Reply With Quote
Old 05-26-2008, 09:45 PM   #2
uwe
418
uwe's Avatar
2007 25' Safari FB SE
1958 22' Flying Cloud
1974 29' Ambassador
Yucca Valley , California
Images: 41
Originally Posted by abridges01
Hi folks.
Cheers,
Andrew
I think it depends on the fans, and the temp selection of the switch that will turn them on.
My 97 Suburban had a engine driven viscous fan clutch with a large fan blade. It always ran relatively cool. But I could hear the fan howl at times when I really didn't think it was needed. ( Like leaving my house at 6:00AM in 45F temperatures)
My 2007 Suburban has electric cooling fans, controlled by engine coolant temperature, as well as A/C requirements.
My point is, I believe that a well designed electric fan layout can definitely cool down a 454 Chevy.
Uwe
www.area63productions.com
Old 05-26-2008, 10:26 PM   #3
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Leave it stock.
Hi, just leave it stock; My P-30 "Mac Tools" truck was overloaded all the time [16,750 lbs on a 14,000 lb GVWR] and never overheated. On my 1959 Ford Galaxie, after adding Air conditioner, I had a solid fan, a flex fan, a flex fan with one electric fan, a fan clutch, a fan clutch with one electric fan, and now two electric fans. Little pluses and minuses with each, but no real improvement on any over the other.
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Old 05-27-2008, 07:03 AM   #4
1973 25' Tradewind
Romulus , New York
Best thing I ever did to my 454 was add headers. I had cracked two curb side exhaust manifolds. With a manual switched electric fan (for low speeds) I never had another problem. While you are doing the install is a great time to go with headers.
jayray5 is offline   Reply With Quote
Old 05-28-2008, 12:03 AM   #5
Salem , Oregon
Images: 18
Hi, headers is a good idea; My P-30 had three sets of cast iron exhaust manifolds while I owned it. [sold it with 68,000 miles on it]
2005 Safari 25-B
Old 05-29-2008, 11:05 AM   #6
76 Silver Argosy
abridges01's Avatar
1975 26' Argosy 26
Which headers?
Thanks for the input, I guess sticking with a stock mechanical fan is the better route.
Any recommendations for headers type or source?
Old 06-02-2008, 12:38 PM   #7
Bloomington , Minnesota
when I bought my 83 310 MH 5 yrs ago, the first thing I noticed was the temp skyHi.
I did the usual radiator maintenance routine, searched this site for ideas.
Was not in the mood to change out the radiator.
I decided to add a big fan to the front of the radiator to assist the stock clutch fan.
I use a manual switch for the electric fan.
the solution has been working great. No complaints.
PS: I added a tranny cooler with a small fan on it as well.
drfw is offline   Reply With Quote
Electrical radiator cooling fans ralley Mechanics Corner - Engines, Transmission & More... 7 05-18-2008 09:49 AM
Auxiliary Electric Engine Cooling Fan cooperhawk Airstream Motorhome Forums 8 02-25-2007 07:18 AM
Great eBay investment! markdoane Off Topic Forum 10 01-01-2005 12:17 AM
Electric Cooling Fan Settings rdm Mechanics Corner - Engines, Transmission & More... 1 07-12-2002 06:29 AM
