Old 05-12-2015, 08:59 PM   #1
1995 36' Classic 36
Ludington , Michigan
EC2000 front hubs
A little more neglect.
The hubs are lubricated with gear lube. There is a window with a rubber plug to service them. This is what came out.
Name:	ImageUploadedByAirstream Forums1431485694.469831.jpg
Name:	ImageUploadedByAirstream Forums1431485712.253817.jpg
Gross but no grit or metal. The brakes do look like new. I'll flush them out soon.
Cleaned then out, made new gaskets, and filled them with 75w90 synthetic gear lube. I'll run it for a couple hundred miles and swap it out again. Only takes about 8 oz a side.
Kota is offline   Reply With Quote
Old 05-13-2015, 07:14 PM   #2
SebasSF's Avatar
1991 30' Airstream 30
San Francisco , California
How do you add the new oil?
SebasSF is offline   Reply With Quote
Old 05-13-2015, 08:27 PM   #3
1995 36' Classic 36
The cover has a round window to check the level. There is a red rubber cap in the middle to fill the hub.
Old 05-16-2015, 06:10 AM   #4
Vycan's Avatar
1994 36' Classic 36 Diesel
Manhattan , Kansas
What are you using to torque the lug nuts? I do not have my manual in front of me, but if I recall correctly torque spec was 400ftlbs.
1994 36' Classic Diesel Pusher
Vycan is offline   Reply With Quote
Old 05-16-2015, 09:16 AM   #5
1995 36' Classic 36
375 in my book but I use my 200 lb butt standing on the 2 foot mark on a 4 foot breaker bar.
I noticed you had solid hub caps. Everyone I've seen has a open center to check the level and keep them topped off. Click image for larger version
Name:	ImageUploadedByAirstream Forums1431789350.349490.jpg
Only 3 of the lug nuts hold the caps on.
Old 05-16-2015, 07:15 PM   #6
SebasSF's Avatar
Fluid looks clean in mine.
Old 05-20-2015, 06:04 AM   #7
1995 36' Classic 36
Moisture is a bigger problem than miles in our application. Use a plastic tube to suck the fluid as soon as you park after a long run. I use synthetic as claims say it sticks longer in contact points. I do it before I put it up for the winter. It a 10 minute $5 job.
Brake Job Spartan EC2000 Kota Mechanics Corner - Engines, Transmission & More... 3 11-11-2014 07:05 AM
P32 Front Hubs. tedly797 Airstream Motorhome Forums 11 06-07-2014 03:04 PM
Replacing Front Hubs and upgrading Brakes on My 99 2500 Burb SaabLover Tow Vehicles 15 03-19-2008 05:09 PM
Hubs (balancing) Sue&Von Wheels, Hubs & Bearings 14 07-31-2007 10:28 PM
MH front wet hubs FrankR Mechanics Corner - Engines, Transmission & More... 2 07-19-2002 07:19 PM
