I have found the elusive leveler valves. They were so in my face I did not know what they were.
I have found the problem, The actuator arm that goes to leveler valve is broken. I have photos to show. I will post later.
I could actually move arm and watch the bag rise on the cone.
Next problem, I held arm up until bag would raise/fill no further but MH is still not level. There is approximately 1 3/4" inch difference in sides.i measured with tape measure. Could there be a problem in the calibration of curbside? Can it be to high?
When I get the unit home I will dabble with adjusting linkage on each side. The linkage on driver/street side has seperated from swivel joint nearest the axle. It was hanging freely.
Smily
__________________ Ken Smillie
My 1994 36' Classic MH is for sale See it in the classifieds
Book does not identify measurement. It simply says that it is calibrated at factory on level surface. It does say that future calibration may be required and simply says to adjust on level surface and adjust to ride satisfaction. It does give some reference to weight in relation to manufacturer of bag specified capacity.
Smily
You said the low bag filled when you moved the broken arm. Did you have the key in the on position? Sometimes the dump function is electrically controlled so having the key off would make it hold the pressure that was in it as it tried to compensate for the low bag.
Brett G
WBCCI #5501 AIR # 49
"Stop worrying about the potholes in the road and celebrate the journey." -- Fitzhugh Mullan
Wise men talk because they have someting to say; fools, because they have to say something. -- Plato
In politics, absurdity is not a handicap— Napoleon
Check all of the lights in the basement compartments. On my MH there is one switch that turns them all on and all off. If your are switched individually you may have one that is in the on position. These for some reason are quite often hooked into the engine battery. Also if you have a kwikee electric step you need to turn it off when not using the coach. this will leave it in the out position. The step will draw mucho power wile sitting and it is normally wired to the starting battery since the key turning on is one way to bring it in.
On the bags it sounds like get it set to level in both axis, if possible, and see how it rides. You may have to call the Factory to see if they can give you the height specs.
Brett G
