Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Motorhome Forums > Mechanics Corner - Engines, Transmission & More...
Old 01-27-2004, 01:33 PM   #29
87MH
87MH's Avatar
Profile:  1978 31' Sovereign
Katy (West Planet Houston) , Texas
Images: 144
Point of clarification
Brett:
I do not think that any AS tag axel has an air bag assist. As far as I know, all of the tag axels are straight rubber/torque tube supported - just like the trailers.
On Edit --
AS did mount the sensors for the main air bags on the tag axel wheel brackets, as the tag axel angle was an independant point of reference for the height of the bottom of the coach from the ground
Sorry if I inferred differently previously.
Dennis
WBCCI # 1113
AirForums #1737
Old 01-27-2004, 01:48 PM   #30
thenewkid64
Just a member
thenewkid64's Avatar
Profile:  Tampa Bay , Florida
Images: 21
Dennis,
I was unsure if there were tag bags...........sorry I couldn't help myself.
I did not see then in your picture, but they could have been buried under the frame.
The mounting of the leveling valves makes sense on the tag axle. This assures that the tag axle is carrying a consistent weight and the tag axle capacity is not exceeded for a long period of time, leading to torsion failure.
On edit......
Ken the compressor should come on at start even if you are level if you have done one of the following. Filled the fuel tank, filled the water tank, filled the black water/gray water and not dumped, invited your whole family to go for a beer run, loaded up for a weekend and taken everything that will fit along, finished installing the new interior, etc.
After you dump, burn off a bunch of fuel, empty the trash, or tell the extra passengers to get out and walk, the system will automatically dump air to bring the proper weight back onto the rear bags and torsion axle.
Brett G
WBCCI #5501 AIR # 49
"Stop worrying about the potholes in the road and celebrate the journey." -- Fitzhugh Mullan
Wise men talk because they have someting to say; fools, because they have to say something. -- Plato
In politics, absurdity is not a handicap— Napoleon
Old 01-27-2004, 02:28 PM   #31
donnall
donnall's Avatar
Profile:
I had the very same problem on my 33' LY.
My problem - and likely yours too - is that there's an sensor arm underthere that tells the pump when the rear is low and for the pumps to pump up the air bags.
A little bolt came loose from the arm and therefore the pump didn't know it was sitting low. The pump was fine, the airbags fine, they just didn't know they needed more air. It could very well be that one airbag has leaked down just a little faster than the other, causing your rig to set low on one side.
The shop put on a new nuts and it pumped right up nice and level.
I wish I could tell you exactly where the arm is located, I just know it's kinda hard to see, and located where it can sense the rear end hight.
The good news is it's a quick & easy fix.
Put on two nuts this time and lock them in place.
HTH
Don
Don Nall
93 Land Yacht (The Minnow)
donnall is offline   Reply With Quote
Old 01-27-2004, 04:34 PM   #32
smily
"Still Working"
smily's Avatar
Profile:  North Charleston , South Carolina
The book
I walked in the house, gave a cursory peck on the wifes cheek and walked straight to the owners manual that is sitting on Kitchen table.
She asks "what are you doing"?
I mumble "trying to figure out why our MH sags".
Okay here it is.
Upon shutting down engine and MH, the solenoid to compressor opens contacts to allow compressor to bleed pressure off.
Reason: to prevent starting under high pressure next time.
So, a little pressure bleed off is normal, compressor will energize upon startup next time to re-pressurize.
But my compressor runs for three to four minutes, much longer than needed to rebuild minimum pressure loss.
So next logical thought: Why so much pressure to be regained? maybe tank is bleeding down through compressor as stated by Brett earlier....Why?
Because Check valve between compressor and tank is probably bad.
So that is my theory on cmpressor starting up on ignition.
Now, sagging rear driver side. I agree that it sounds like the sensor switch is not talking to system and not filling bag as needed. Probably due to loose bolts as pointed out by Donnall.
I will be checking state of sensor and report back.
Thanks for hanging in there with me today.
Smily
Ken Smillie
My 1994 36' Classic MH is for sale
See it in the classifieds
smily is offline   Reply With Quote
Old 01-27-2004, 06:09 PM   #33
fangthorpe
Profile:
When I picked up my '92 30' single axle, the VDO air gauge on the dash read 60#s and the coach rear was too low. The PO removed the stock springs and bags and installed Supercoils, which don't use airbags, so all gauge and compressor action is now limited to the rear bags. I crawled under the coach and adjusted the leveling valve arm (only 1 in center) about 1/4" and the compressor went on, raised the rear up about 2", and the pressure gauge now always reads 90#s. After 3 or 4 days, it will bleed off enough air to kick the compressor on when you hit the ignition, taking maybe 1-2 mins to pump up. Before I raised the ass level, it would always bleed off air when leveling, as the compressor wanted the rear lower than the front and the levellers wanted everything level. Unless something is preventing air from getting to the left bag or unless you have 2 leveling valves, I can't imagine why you have a sag on one side. Is there any chance the PO unhooked the rear bags when he unhooked the front ones, and you need to also air them seperately? Maybe the compressor is only filling the tank and not the bags. 120#s is too much pressure to have a sag. I'll bet the driver's bag is low.
fangthorpe is offline   Reply With Quote
Old 01-27-2004, 06:49 PM   #34
smily
"Still Working"
smily's Avatar
Leveling valves
Book, (Service manual) says that I have two leveling valves. One on each side.
The forward bags were never attached to air system. They have always been independant. The book leads me to believe that air bags in the front were optional and not necessarily part of the original design. The book says that these are aftermarket bags and are not covered under warranty.
You maybe correct that no air is getting to back but I believe that the passenger side is getting air. The bag was very firm.
Tomorow, I will post scanned image of Air system. My money is n faulty leveler sensor on driver side.
Smily
Ken Smillie
Old 01-27-2004, 07:07 PM   #35
swebster
RivetAddict
swebster's Avatar
Profile:  Louisville , Kentucky
Smily,
For what it is worth these guys (above) guided me through an issue with my air system recently. Turned out to be a bad check valve. I replaced it in five minutes with $10 in parts from Grainger.
I've not got into the leveling valves on my tags (yet). I replaced it to solve a different probem (full dump of air when I turned the ignition off) but noticed a small hairline crack in it once it was out. If would guess that this would be the reason for mine coming up to pressure much faster now.
Steven Webster
1986 Airstream 345 Classic Motorhome
AIR 1760
View My ThisOldRV.com Personal Page
ThisOldRV.com
swebster is offline   Reply With Quote
Old 01-27-2004, 07:20 PM   #36
smily
"Still Working"
smily's Avatar
Speculation
Then my guess was correct. If you read above, I speculate that my check valve is not working.
Did your compressor start every time you turned ignition on?
And run for several minutes?
Ken Smillie
Old 01-27-2004, 07:39 PM   #37
swebster
RivetAddict
swebster's Avatar
Mine always come on when I start the coach. But now that I know the difference they used to take a long time to get up to pressure.
The Airstream manual says to expect it to come on when you first start the coach but mine would run a lot. My setup is a little different in that it appears as if my front bags are "plumbed" into the main air system. I had no idea anything was amiss until it started dumping all of the air when I turned it off.
Steven Webster
AIR 1760
ThisOldRV.com
Old 01-28-2004, 08:14 AM   #38
smily
"Still Working"
smily's Avatar
Leveling valve location
Anyone know the exact location of the two leveling valves on the LY? I am going to look today but I would like to minimize my search time. (crawling time)
Smily
Ken Smillie
Old 01-28-2004, 08:46 AM   #39
swebster
RivetAddict
swebster's Avatar
Don't have a LY but if the P30 setup is the same and AS didn't change the component you should find them mounted inboard of each tag axle pivot just inboard of the rear shock mount. (You can see the mounting location in Dennis' picture above)
There are two air lines going into the back of the valve and a single open "blow out" line coming out. There is also a threaded rod down to the tag axle (this adjusts the valve position lever).
When I replaced my tag shocks this fall I removed the tag wheels and unbolted the leveler valve brakets to get at the shock bolts.
The valves were ready accessable with the tag wheel removed. Just remember to jack up the tag axle!
Steven Webster
AIR 1760
ThisOldRV.com
Old 01-28-2004, 11:42 AM   #40
smily
"Still Working"
smily's Avatar
Been under unit
I was typing just as site crashed.
I have had time to settle down.
I have been to unit and crawled under it. I have found where air lines leave tank and I have found dump lines. But for the life of me I cannot see the leveling valves. They are way up in the framework and I cannot get to them.
I will have to go back with flashlight and mirror I guess.
Obviously, it will not be easy to repair if needed.
I checked the bags again and they are like rocks. Do I need to raise unit to see bag collapse?
I am getting frustrated
Smily
Ken Smillie
Old 01-28-2004, 12:53 PM   #41
thenewkid64
Just a member
Images: 21
If the bags are hard as rocks, that is good!
This means that the leak is a slow one. Since one side gets saggy I would start there at the bag with a leak detecting solution. Also inspect the tubing to be sure it has not cracked or gotten crimped. Since one side is down, but the other is not I would assume that it is isolated to the fittings on that side, or the valve or the bag.
Does your system maintain pressure after you leave it overnight in the accumulator tank? This would be tested with a standard air gauge on the bottom of the tank fitting.
Brett G
Old 01-28-2004, 02:55 PM   #42
74Argosy24MH
Profile:  LOST , Hawaii
If the bags are as hard as rocks also make sure the low side is the one that's wrong. It should be pretty level front to rear.
John
74Argosy24MH is offline   Reply With Quote
