Old 05-11-2015, 09:39 PM   #1
1995 36' Classic 36
Ludington , Michigan
Driveline shudder!
Looks like another victim of abuse and neglect was the driveshaft. The AEDs (Rear End Diesels) have a cute little driveshaft thats a two yokes coupled by a spline.
I noticed a significant vibration that started about 35 mph. I found a significant amount of play in the spline and ujoints. They look pretty dry. I'll update my odyssey on finding a new driveshaft.
Kota is offline   Reply With Quote
Old 05-12-2015, 04:59 AM   #2
bobmiller1's Avatar
2005 34' Classic S/O
2006 39' Land Yacht 396 XL
north blenheim , New York
Let me know if I can help. One of my customers owns an excellent driveshaft company that can fabricate any driveshaft up to 12 feet long.
bobmiller1 is offline   Reply With Quote
Old 05-12-2015, 05:21 AM   #3
Gainesville , Florida
AED commonly referred to as diesel pushers? Jim
Old 05-12-2015, 09:54 AM   #4
1995 36' Classic 36
Name:	ImageUploadedByAirstream Forums1431445806.761316.jpg
The drive shaft was installed out of phase.
Doesn't appear to be any damage the anything but the rear ujoint.
Old 05-12-2015, 09:59 AM   #5
r carl's Avatar
Lin , Ne
Anything can happen under a shade tree.
Old 05-12-2015, 10:15 AM   #6
mayco's Avatar
1982 31' Airstream 310
champaign , Illinois
Lucky not more damage
mayco is offline   Reply With Quote
Old 05-12-2015, 11:51 AM   #7
1995 36' Classic 36
Driveline shudder!
Unfortunately, this was done by a shop.
Name:	ImageUploadedByAirstream Forums1431452990.022709.jpg
Based on the receipts the previous owners were incapable of even changing oil.
Old 05-12-2015, 11:56 AM   #8
1995 36' Classic 36
Here's another bit of quality work:
Name:	ImageUploadedByAirstream Forums1431453374.748209.jpg
Name:	ImageUploadedByAirstream Forums1431453399.520378.jpg
Old 05-12-2015, 02:45 PM   #9
1995 36' Classic 36
Name:	ImageUploadedByAirstream Forums1431463521.387176.jpg
Ready for reassembly.
Old 05-12-2015, 08:44 PM   #10
1995 36' Classic 36
Driveline shudder!
Name:	ImageUploadedByAirstream Forums1431484610.211717.jpg
I was a little surprised that the splines go straight through and are open to the yoke. It's possible that a rubber baffle or something is missing. In any case it's important to keep the splines lubricated to keep contamination out. Turns out everything was well lubricated and the splines were in good shape. The out of phase shutter beat up the u-joints but didn't appear to damage anything else. I hope!
U-joints were about $75 each. $10 for a new spline seal. Could have been worse. Used Spicer series 1610 driveshafts run about $600 and you would probably have to have it shortened. New from Spartan are about $1200.
Down Hill Brake Shudder Scott J-24 Brakes & Brake Controllers 17 04-22-2018 02:34 PM
Preferred driveline brake for '83? dljosephson Mechanics Corner - Engines, Transmission & More... 2 10-05-2009 11:46 AM
Brake Shudder Problem Jim & Susan Brakes & Brake Controllers 12 11-26-2008 04:18 PM
Driveline Whirring Worsens swebster Mechanics Corner - Engines, Transmission & More... 7 12-21-2003 08:46 AM
"Whirring" Noise in the Driveline at Speed swebster Airstream Motorhome Forums 20 08-15-2003 05:57 AM
