Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Motorhome Forums > Mechanics Corner - Engines, Transmission & More...
Old 12-16-2007, 07:27 AM   #1
bkahler
Profile:  Jefferson , Arkansas
Drive line vibrations
As we were driving home after replacing all of our tires with new Toyo's we noticed what seemed to be a drive line vibration or harmonic. We didn't notice it before because the new Long March tires we had put on the coach this past summer were all out of round causing horrendous vibration problems. The vibrations were so bad that anything loose in the coach would rattle around.
Have any of you experienced drive line vibration issues? I'm leaning towards the drive shafts as being the culprits but I'm not sure how to go about checking them. My guess is I'll have to take them off and have a shop check them out.
Any thoughts or suggestions would be appreciated.
"Wherever you go... there you are." - Buckaroo Banzai
1984 310 Limited Motorhome
1974 31' Excella 500 (future hauler for 2 Triumph race cars)
1974 20' Argosy Motorhome (future Excella 500 tow vehicle)
Old 12-16-2007, 07:33 AM   #2
klattu
Liberator
klattu's Avatar
Profile:  Heart of Dixie , Alabama
Images: 854
Twisted
Most of mine have always been caused by the U-joints.
Even though they sometimes looked OK, were dry or moved enough to throw balance off.
Block wheels,
Then but trans in nutural<sp
Don't use parking brake.
Double check blocked wheels
Get under there and try to twist or shake drive shaft.
Your opinion is valued, please not your opinion of someones else's opinion.
Click To See Me Wet
1989 Airstream 345 Liberator
klattu is offline   Reply With Quote
Old 12-16-2007, 07:42 AM   #3
overlander63
overlander63's Avatar
Profile:  1974 31' Sovereign
Still in the trailer , Fulltiming
Images: 58
Check the easy things first
Take a look at the driveshafts, and make sure the u-joints are aligned front-to-back. All the u-joints should be oriented the same way, if you look down the shaft, they all should be pointed up, or down. If not, you will have to move the shafts around until they are. It can and does make a huge vibration if they are not in line with each other.
Change is inevitable, except from a vending machine
AIR#2611
overlander63 is online now   Reply With Quote
Old 12-16-2007, 10:56 AM   #4
Excella CM
Excella CM's Avatar
Profile:  1978 31' Excella 500
Venice , California
As Overlander pointed out, U joints need to oriented the correct way. This is normally a problem that occurs on vehicles with three U joints and a two- piece driveshaft (Hotchkiss drive). What happens is that the constant input speed at the transmission is converted into a sinusoidal output at the miss-aligned u joint. I happens when the driveshaft halves are separated at the spline and re-mated at an odd angle. Always good to check for this as it is a common error made by mechanics-amateur and otherwise. This the same reason that dictates constant velocity joints on front wheel drive cars. NOTE: this problem only occurs when the driveline is operating at an angle. When the driveline is perfectly straight, the orientation of the u joints is immaterial.
"Not all who are lost are wondering" say Bill & Heidi
'78 Excella 500,"The Silver Pullit". vacuum over hydraulic disc brakes, center bath, rear twin. '67 Travelall 1200 B 4X4 WBCCI 3737
Excella CM is offline   Reply With Quote
Old 12-16-2007, 11:41 AM   #5
TBSarfari28
Profile:  2005 28' Safari
Santa Ana , California
Problems with driveline components, U-joints, center bearings, slip yokes, flanges, angles, timing/phaseing, and etc. will cause vibrations that are intermittent. The vibration will come in at a certain speed and disappears at a higher speed, example, 32 to 48 MPH. Check for the items pointed out above, check for any looseness at any of the components. If you don't find any looseness take it to a driveline shop and have them check it out. They can check to see if it is out of phase, balance and alignment etc. If the driveline arrangement is a compound driveline arrangement and is a 3 joint 2 shaft type or more, then usually the u-joint at the center bearing can be
off-phased (looks to be out of phase/time). If you have this type of driveline arrangement and you align the yokes as mentioned above, your vibration problems will get worse. Have it checked by someone who knows drivelines.
TBSarfari28 is offline   Reply With Quote
Old 12-17-2007, 01:44 PM   #6
Robfike
Robfike's Avatar
Profile:  Speedway , Indiana
I have also seen new tires that vibrate even though they are ballanced on a machine. Worth a look, and if bad, they should replace the tire for free.
Rob
Robfike is offline   Reply With Quote
Old 12-17-2007, 05:08 PM   #7
RUSSELL
Desert Fox
Profile:  1985 31' Sovereign
Tucson , Arizona
Thumbs up Hi Brad,
Also check engine, transmicion and ceter support mounts. These will also give you vibration in your system
Russell in sunnny and cool Tucson Az.
RUSSELL is offline   Reply With Quote
Old 12-17-2007, 05:48 PM   #8
bkahler
Thanks for the ideas. When we first realized we had drive line vibrations my first thought was the u-joints. However after reading Russell's comment about the motor and transmission mounts makes me wonder what condition those mounts are in. The engine was replaced about 8 years ago and I assume they would have used new motor mounts. I have the receipts and will check on that this evening.
Rob, we know its not the tires as these are brand new Toyo's and the ride improved immensely after getting rid of the near new but out of round Long March tires. It wasn't until we put the new tires on that we realized there was something else causing a problem.
Possibly around new years I might have time to look under the coach.
I'll keep everyone posted as to what we find.
Thanks!
Old 12-17-2007, 06:27 PM   #9
Beginner
Profile:  1984 31' Excella
Norfolk , Virginia
Images: 11
Drive Line Vibrations
bkahler
I have a 1990 GMC 12 passenger van that I tow with (G3500).
It has a two piece drive shaft.
My engine was also replaced by the local Oldsmobile/GMC dealer prior to me buying it.
I had low speed high torque vibration to the point it was making the mirrors useless.
Over a two year period I had the darn thing looked at and serviced by two commercial shops and the looked at by the local International truck dealer (they blew me off).
I finally found the answer on the internet.
My problem while relatively simple to repair was very hard to identify.
First as mentioned in previous posts determine the condition of the universal joints.
They must be perfect.
Next pay close attention to the rear motor mount (transmission mount).
It must be in good order (perfect). Transmission oil and engine oil will make them go soft and fail.
Next the engine mounts. The best way is to jack up the engine (board on a floor jack under the oil pan [bee delicate and careful]). Remember, on the front engine mounts, they are interlocked so that the engine cannot come loose and spin under high torque(yes it will spin).
I assume you also have a two piece drive shaft. Here are the web sites that finally allowed me to identify my problem.
http://www.babcox.com/editorial/us/us50014.htm
http://www.vibratesoftware.com/html_help/html/Diagnosis/Propshaft/Propshaft_Angles.htm#Propshaft%20Phasing
Here is a quick and dirty synopsis:
The drive shaft must be balanced. They have been known to shuck balancing weights.
As stated before, the drive shaft must be phased properly (u joints lined up properly).
Next, and here is what was wrong with mine,
THE DRIVE SHAFT MUST BE IN A STRAIGHT LINE IN ONE DIMENTION, PERIOD, NO EXCEPTIONS.
Since the engine and the differential are at different angles then the drive shaft must be straight as if you were looking straight down from above or looking up at it.
I checked mine with a string. I rotated the drive shaft so that a u joint bearing cap face (flat) was straight down (parallel with the ground).
I tied a string at the differential on the pinion shaft.
I tied the other end to the transmission yoke.
I tied the string tight.
I centered the string on the u joint bearing cap at the differential and on the bearing cap at the transmission yoke.
The center u joint bearing cap was about ¾ of an inch out of straight.
I moved the tail shaft of the transmission to the right (passenger side) as far as I could to remove part of the problem and shimmed the center bearing to remove the rest of the out of alignment condition. To do this safetly I had to cut a 2 inch wide ¼ inch flat bar longer than the center bearing was wide and drill two holes in it. This I placed on the top of the center bearing. This was to hold the center bearing and the rubber shock mount for the bearing in the u shaped bracket the center bearing assembly lived in.
Then I started shimming with washers until all misalignment was gone.
Next, with the u joints rotated so that two bearing cap flats are facing the sides of the vehicle and one is facing straight down (very important [just as above]) measure the angle of the cap.
I used a machinists combination square.
My first trial run of flooring the gas pedal was nothing short of nirvana.
Smooth as silk.
And it only took me two years to figure it out.
As a precaution I replaced the transmission tail shaft bushing and transmission rear oil seal.
Good luck.
Beginner
Beginner is offline   Reply With Quote
Old 12-17-2007, 06:45 PM   #10
Mikethefixit
Mikethefixit's Avatar
Profile:  1977 27' Overlander
Trotwood , Ohio
Slid under there and check all of the afor mentioned. There are balanceing weights on each shaft,check to see if they are still there,they have been know to fall off.
Then Check that Amid-ships or carrier bearing I bet money its never been replaced . The best of luck finding that vib sometimes they are HAIR JERKERS.
HAPPY HOLIDAY
Roger
Mikethefixit is offline   Reply With Quote
Old 12-17-2007, 06:51 PM   #11
Bob Thompson
'97 Excella 25
Bob Thompson's Avatar
Profile:  Corpus Christi , Texas
Images: 60
One of the ways you can check whether it is tires or driveline, jack the rear end, remove the tires, support the rear axle on jack stands, then start the engine, engage the transmission, and watch the hubs and driveline spin.
2002 Toyota Tundra
Why is it Levee's built by volunteers with sand bags hold better than Levee's built as directed by the Corps of Engineers with millions of taxpayer dollars?
Bob Thompson is offline   Reply With Quote
Old 12-17-2007, 07:16 PM   #12
Beginner
Norfolk , Virginia
Images: 11
Drive line Vibrations
First put some lug nuts on the lugs tight against the brake drums to keep them from comming off during rotation.
Beginner
Old 12-17-2007, 09:15 PM   #13
TBSarfari28
Brad,
There are two types of driveline arrangements, single plane and compound in both arrangements the u-joint MUST have equal working angles. All the things that everyone has memtioned must be in good condition. Check out this web site, you may find some info that will help you.
Go to: WWW.roadranger.com/roadranger/servicesalesliterature/index.htm
click on service & troubleshooting under driveshaft. View the following vidoes.
RRSD001 and RRSD003 and take a look at the service manual DSSM3264
Hope this helps.
Old 12-18-2007, 06:12 AM   #14
GlenCoombe
GlenCoombe's Avatar
Profile:  Sumter , South Carolina
Wow, lots of great info here. Brad, do check the varios and obvious as mentioned here. If your 310 has the driveline manual parking brake do check that as well. I found mine to have 3 very loose bolts due to drive line vib.
Check that tail shaft mount on the tranny too.
Good luck, and good vibrations for the new year.
Glen Coombe AIR #8416
1984 28' Funeral Coach
Golf Professional Sales Rolling Showroom
"I'm not an expert. But I did sleep in an Airstream last night."
GlenCoombe is offline   Reply With Quote
How Easy Is It To Drive One Of These? vandh016 Member Introductions 13 06-03-2007 04:08 PM
Hi Way Drive In firebird Mid-West Boondocking 10 05-28-2007 10:58 AM
Not So Good .. VIBRATIONS Silvercamper General Repair Forum 5 10-22-2005 07:07 PM
Air Conditioner Vibrations raebaker06 Furnaces, Heaters, Fireplaces & Air Conditioning 3 06-29-2005 06:54 AM
Drive vs Over Drive joshua32064 Tow Vehicles 10 10-17-2003 01:25 AM
