Old 10-27-2003, 06:00 PM   #15
87MH's Avatar
1978 31' Sovereign
Images: 292
Oil Consumption
1 quart after 2,000 to 3,000 miles, then about 1 quart per thousand miles.
75,000 miles on engine.
Dennis
WBCCI # 1113
AirForums #1737
Trailer '78 31' Sovereign
Texas Airstream Harbor, Inc.
Old 10-27-2003, 06:03 PM   #16
jaiman's Avatar
Images: 32
My 81 doesnt burn a drop. With 52,000 miles thats pretty damn good. I too check the oil often. Before everytrip and along the way when I make a stop. Cant be too cautious on fluid levels.
jaiman is offline   Reply With Quote
Old 10-27-2003, 06:39 PM   #17
Airstream Driver
PeterH-Airstreamer's Avatar
1997 30' Excella
Images: 51
less than 1 quart per 1000 miles. 51K on the engine
1996 Airstream B190
1987 29' Sovereign Trailer
1997 30' Excella Trailer
AIR #13
PeterH-Airstreamer is offline   Reply With Quote
Old 10-27-2003, 07:34 PM   #18
Astrodokk's Avatar
1992 30' Airstream 30
Santa Rosa , Northern California wine country
56K on engine...don't know consumption cuz I can't check!!!
Astrodokk is offline   Reply With Quote
Old 11-01-2003, 07:24 PM   #19
Astrodokk's Avatar
new tube
pic...they said it doesn't need an O ring.(on edit)
Old 12-11-2003, 09:38 PM   #20
shelocta's Avatar
1990 25' Excella
Pflugerville , Texas
Question Oil Capacity 454
I change the oil and filter in the driveway tonight, warmed up the engine first and then did the work on the bottom. Added six quarts, stated the engine and got good oil pressure. Checked the oil level and it is just over the full mark. Ran the engine up to full temp, no change. My question is, how can you tell if the dip stick is wrong or there was oil not drained, like out of the oil cooler.
Bill
Give me 40 acres and I'll turn this rig around.
shelocta is offline   Reply With Quote
Old 12-12-2003, 08:06 AM   #21
87MH's Avatar
1978 31' Sovereign
Images: 292
Oil Volume
Total oil volume of the heat exchanger (including lines) is only about a half pint.
The heat exchanger internal to the radiator is quite a bit higher than the engine oil sump, therefore I always assume a pretty good drain by gravity will have occured.
Dennis
WBCCI # 1113
AirForums #1737
Old 11-07-2010, 05:30 AM   #22
TOG Unit Member
1979 31' Excella 500
1995 36' Classic 36
Marietta , Georgia
Airsteam "buddies" are the best! I just completed the 454 Chevy "new starter" install with the expertise of a great man named Paul Whittle. (Thanks, Paul) The job took a little longer than we expected, and Paul had to depart for another engagement, so I was left with getting the "oil dip stick tube (53 inches)" reinstalled and have been challenged getting it completed. I get the tube nearly completely installed, with only a 1/2inch remaining, but can't get the tube down that remaining little bit. Does anyone have any recommendations on "reinstalling" the 454 BB "dip stick tube"? I have the Banks header system. Is it best to install from the open "dog house" and then "carefully" bent the tube towards the front of the MH or come from the front hood and curve down the mainifold into the pan? What's the "trick?"
BudClem is offline   Reply With Quote
Old 11-07-2010, 01:45 PM   #23
Robfike's Avatar
1986 34.5' Airstream 345
Speedway , Indiana
We use about 1 quart in 500 to 700 miles. No leaks or smoke, just uses it. We have 80,000 on the engine since overhaul at 110,000.
Robfike is offline   Reply With Quote
Old 11-08-2010, 06:31 AM   #24
TOG Unit Member
1995 36' Classic 36
Marietta , Georgia
FYI. I was successful yesterday with the installation of the dip stick tube without breaking it. The "trick:" two man party, one working from above the open doghouse and second under block at oil pan feed. Remove the air filter and air feed over the carberator. Carefully straighten the "removed tube" and gently feed to your partner under the block near the oil pan. First get the tube into the funnel feed into the oil pan. Then gently bent the dip stick tube and carefully position by rotating the tube into the appropriate area near the front hood of the MH, next to transmission dip stick. Note: You may need to remove a few of the "supporting brackets" near the transmission tube. Be carefully not to loose the "clip" which holds the tube in the oil pan funnel. Remembering to gently re-attach it.
Old 11-08-2010, 12:06 PM   #25
Kmpro
kmpro's Avatar
1984 31' Airstream310
Lubbock , Texas
Thumbs up Dip Stick
My 310 with 79,000 miles uses 1 quart every 500 to 700 miles which I believe is just lubricating. No smoke or leaks so I am sure it is like all the 454s I have had in the past, which use some oil through the valve guides. This is normal for a big block though. At rebuild, i install new guides and better valve seals than OEM and this stops consumption through the guides. I also run the larger oil filter which makes 7 quarts with the filter. I change every 90 days or 4000 miles whichever comes first. I may stretch it on the days but never on the miles.
KMP
A Man has got know his limitations-Dirty Harry
That's Some Bad Hat Harry-Jaws 1978
kmpro is offline   Reply With Quote
Old 11-08-2010, 01:15 PM   #26
pwhittle's Avatar
1982 31' Airstream310
Alpharetta , Georgia
Hey Bud,
Sorry I had to run before the work was complete, but kudo's to you and Don for "bringing it home"!
Paul
1982 FFC with Motorhome Interior
http://shineee.whittlegroup.com
pwhittle is offline   Reply With Quote
Old 11-09-2010, 04:08 PM   #27
Silver Bullet
choctawmel's Avatar
choctaw , Oklahoma
Boy, dip stick tube replacement. That's a job!
The Silver Bullet is over 83,000 and I have never added any oil between oil changes. If she was drinking a quart ever 5-700 miles, that 454 would be on the shop floor right next to the transmission!
mel
choctawmel is offline   Reply With Quote
Is my math right? ITowSilver Tow Vehicles 11 01-15-2004 12:05 PM
Dometic dip stick? Stinky Refrigerators 2 11-03-2003 07:22 PM
Just a Idea. xtrm69 Our Community 4 01-19-2003 08:12 PM
