Old 02-03-2010, 07:58 PM   #1
1994 36' Land Yacht
kunkletown , Pennsylvania
diesel engine doesn't turn off with key
My diesel engine on 94 landyacht will not turn off with the key. Have pulled relays with key off still runs. Help
hit the road is offline   Reply With Quote
Old 02-03-2010, 09:25 PM   #2
Well Preserved
overlander63's Avatar
1993 21' Sovereign
Colfax , North Carolina
Depending on which engine you have, you could have a bad cutoff solenoid, or the alternator could be feeding back through the wiring. You could have an LP leak, but that would normally cause the engine to run away, not merely continue idling. Have you tried pressing the accelerator, and seeing if the engine continues running normally, or "surges"?
Old 02-03-2010, 11:02 PM   #3
vswingfield's Avatar
1983 34' Excella
1967 24' Tradewind
Little Rock , Arkansas
Images: 32
Terry is right about the cutoff solenoid. That would be the first thing I would check.
The injector pumps usually fit a wide variety of different engines. For example, the old Chevy diesels used a Roosa Master pump and shared solenoids with several models of John Deere, Allis Chalmers, and others. Several engines that use the Bosch pumps, including Mercedes have much in common with several Deer, Allis, and Cat engines.
If you need a solenoid, you may be able to find one locally at a farm equipment facility, not just truck places. Handy in a pinch, especially if the need arises in farm country. Be sure to get the correct voltage. I have seen ones that pretty much looked identical, but one was 12v and the other was 24v. They are marked, but be sure to check.
Vaughan
Old 02-04-2010, 11:59 AM   #4
1994 36' Land Yacht
tried that
cut off selenoid works, if I pull ignition fuse engine stops. Any more ideas?
Old 02-04-2010, 12:16 PM   #5
Wise Elder
Jammer's Avatar
2010 30' Classic
Check the alternator wiring. As a test you can disconnect the field power, voltage sense, and idiot light connections from the alternator and see if that's part of the problem. It often is. Leave the big output wire hooked up.
Old 02-04-2010, 12:18 PM   #6
1983 34' Excella
1967 24' Tradewind
Images: 32
OK, that's good.
Check and see if the ignition switch itself if good. It may still be allowing current when it should be off. I have had problems with the switches themselves in the past. You can move the lock part from the existing switch to a new one, so re-keying is not an issue.
Vaughan
Old 02-04-2010, 05:51 PM   #7
richinny's Avatar
2011 34' Classic
have you tries turning the key as far back as the accessory position?
Ricky
Old 02-06-2010, 01:56 PM   #8
Ag&Au's Avatar
Port Orchard , Washington
I was curious about this when it was posted. Has the cause been found?
regards,
Ken
Old 02-07-2010, 07:49 PM   #9
1994 36' Land Yacht
I wish a cause had been found.
Old 02-07-2010, 07:53 PM   #10
garry's Avatar
1969 31' Sovereign
Broken Arrow , Oklahoma
May be a long shot but I had the cruse control cause the same problem only I had a high idle to go with it.
Garry
Old 02-07-2010, 08:48 PM   #11
2005 28' Safari
Mono City , California
Hit the road,
If you could find either the Engine Serial Number or CPL(control parts list) number, they both will be on the engine data label, which is located on the engine valve cover or fuel pump side of the engine. Your engine has an electronic control module(ECM) there could be a couple different ones, from the engine serial number or CPL number I can get Cummins service information that may help with finding the cause to your problem.
Tom
TBSarfari28 is offline   Reply With Quote
Old 02-07-2010, 11:18 PM   #12
2005 28' Safari
Hit the Road,
I have been checking some Cummins Service info, I was incorrect your engine does not use an ECM. If you can still get the engine info I requested I can check Cummins service info for possible causes.
Tom
Old 02-08-2010, 12:08 AM   #13
NevadaGeo's Avatar
1978 31' Excella 500
Genoa , Nevada
I'm sure this has nothing to do with a 94 Landyacht, but my 92ish Cat shuts off when you push the throttle all the way off.
I admit to being powerless over housecleaning and social niceities
Airforums 22655 and now, WBCCI 22655
NevadaGeo
NevadaGeo is offline   Reply With Quote
Old 02-08-2010, 06:12 PM   #14
1994 36' Land Yacht
tom
I have a model# 85.9-230 . I do not know which is the serial# because there are many #s without labels. ref.# p111798 Family# rce359d6daab ( 3926649 19940208 )no labels on these 2. Catalyst # no.26233. I thank you in advance for your help. I have been trying to solve this problem for weeks.
'77 Argosy. "Turn-Key" condition. Overpriced? rosewood Trailer Values 16 08-26-2009 11:51 AM
1977 Airstream Argosy with All New Appliances! Turn-Key eBay Watch Airstreams on eBay 0 08-01-2009 12:30 PM
1977 Airstream Argosy with All New Appliances! Turn-Key eBay Watch Airstreams on eBay 0 07-25-2009 12:10 PM
Turn The Key And Nothing Happens Chaplain Kent Mechanics Corner - Engines, Transmission & More... 102 04-20-2009 07:02 AM
Investigating a business plan for a turn key AS rwrussom Dollars & Cents 21 08-21-2008 03:28 PM
