Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Motorhome Forums > Mechanics Corner - Engines, Transmission & More...
Old 02-10-2006, 12:14 PM   #1
guy99
guy99's Avatar
Profile:  Dunsmuir , California
Images: 16
Diesel Engine Braking
I was wondering what provision there is for engine braking on the various diesel solutions for the classic motorhome.
Exhaust brake? Jake? ???
What's on the stock isuzu?
Cummins?
Duramax?
1984 310 Limited Motorhome
guy99 is offline   Reply With Quote
Old 02-10-2006, 12:18 PM   #2
wahoonc
Rivet Monster
wahoonc's Avatar
Profile:  1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 35
Cummins?
Duramax?
To the best of my knowledge none of them come with exhaust brakes as stock. It is my understanding that only Cummins will work with a true Jake brake. The others require an exhaust mounted brake. Pac brake and Banks Brake are two that come to mind. I have also seen electric retarders and driveshaft brakes, but they aren't as common. The electric retarders can be found on the older Blue Bird Wanderlodges.
Aaron
WBCCI #2449 AIR #2495
Old 02-10-2006, 12:19 PM   #3
Chaplain Kent
Chaplain Kent's Avatar
Profile:  Wauwatosa , Wisconsin
[quote=guy99]I was wondering what provision there is for engine braking on the various diesel solutions for the classic motorhome.
If there is a provision for engine braking on my engine it was never explained to me.
Chaplain Kent
1982 280 Turbo Diesel Motor Home (Chummy)
http://www.fuzzytravel.com/grandakent/
Chaplain Kent is offline   Reply With Quote
Old 02-10-2006, 12:21 PM   #4
guy99
guy99's Avatar
Images: 16
Doesn't that make them pretty hard on the brakes in the mountains?
What do people with big trailers and diesel pullers do?
Old 02-10-2006, 01:01 PM   #5
GStephens
GStephens
GStephens's Avatar
Profile:  1982 31' Limited
Hamilton , Texas
Those with the Ford Tow Haul automatic transmission or the Allison automatic in the GM products get a surprising amount of braking when operating in the tow/haul mode through the transmisson. The main thing about driving in the mountains is to slow down and use your lower gears whatever type of transmisson or additional braking one might have.
GStephens
GStephens is online now   Reply With Quote
Old 02-10-2006, 01:42 PM   #6
davidh
1977 31' Sovereign
davidh's Avatar
Profile:  Kalispell , Montana
exhaust brakes
Cummins engine brakes are called Jackebson engine brake, better know'n as the jackeb Brake. This is how they work simply stating, Energizing the brake converts a diesel engine into a energy absorbing air compressor, this is done by opening exhaust valves near the top of the compresion stroke, releaseing the compressed charge into the exhaust, the energy used to compress the charge without a firing cycle acts as a brake.. engine brakes are made for steep grades downward decent, to save on drum wheel brakes, and the possibility of over heating drum wheel brakes on a downward decant,whitch is also know'n as smoked the brakes, because of brake shoes overheating. Heat will glaze brake shoes to the point where you will have no brakes. I know Isuzu has exhaust brakes so call a dealer and ask them about it.
1977 31' landyacht Sovereign
davidh is offline   Reply With Quote
Help!! Engine Won't Start!! eraffety Mechanics Corner - Engines, Transmission & More... 41 07-05-2006 07:01 PM
1982 excella diesel airstream motorhome engine spec's jeniamundo Mechanics Corner - Engines, Transmission & More... 9 11-02-2004 08:24 AM
454 engine questions Curtis-79MH Mechanics Corner - Engines, Transmission & More... 10 10-06-2003 06:22 AM
1981 Isuzu Diesel Engine jpurdy Mechanics Corner - Engines, Transmission & More... 10 11-30-2002 10:14 AM
Engine Monitoring, gauges etc. thenewkid64 Mechanics Corner - Engines, Transmission & More... 1 07-25-2002 02:25 PM
