Old 11-26-2012, 06:01 PM   #1
Didn't expect this under the doghouse cover
I was poking around the doghouse cover of the 310 the other day and taking reference pictures for when I reassemble the Argosy. I didn't notice the problem until I was sitting at my desk reviewing the pictures.
Can you spot the problem?!
Old 11-26-2012, 06:03 PM   #2
robert claus's Avatar
2000 19' Bambi
mt. Prospect , Illinois
Isn't the fan belt coming from the left on upside down?
robert claus is offline   Reply With Quote
Old 11-26-2012, 06:06 PM   #3
Yep, you got it.
I replaced all three belts in April while sitting along I-75 south of Knoxville. I'm fairly certain I got them on right so I have no idea what cause it to roll like that.
Old 11-26-2012, 06:08 PM   #4
LimeyRich's Avatar
1988 34.5' Airstream 345
The eastern swamps , North Carolina
Under the doghouse
I hate being in the doghouse!
Nice twist on that belt Brad.
My 454 seems to do that too, right at the end of the belts life, except it's always the alternator belt.
All the best. Rich
LimeyRich is offline   Reply With Quote
Old 11-26-2012, 06:15 PM   #5
All the best. Rich
Rich,
I don't like being in the doghouse either but sometimes you just have to bite the bullet
It's not the alternator belt that's twisted. I believe it is the crank/waterpump/ac pump that is twisted. All three belts are new within 800 miles.
Any idea what might cause that to happen?
Old 11-26-2012, 06:18 PM   #6
clancy_boy's Avatar
2003 22' International CCD
Kiln , Mississippi
Images: 8
New belts should be re-tightened shortly after instalation. They get max stretch after they warm up after a few hundred miles.
That is a nice twist - no fan belt noise when running?
Michael & Tina with Layla and Preston BZ
The family has grown.
2003 22' INTERNATIONAL CCD
Old 11-26-2012, 06:21 PM   #7
Didn't notice any difference in sound. I had never heard that belts needed to be re-tensioned after installation. It sorta makes sense though. I'll straighten it out and re-tension all three of them.
Thanks!
Old 11-26-2012, 06:34 PM   #8
Skater's Avatar
1995 30' Excella
Bowie , Maryland
I remember seeing some wear on the edge one of my new belts on the B190, and it turned out to be due to the water pump's bearings going bad. I'd check all of the pulleys on that belt for play.
1995 Airstream Classic 30' Excella 1000
2014 Ram 2500 Crew Cab with Cummins 6.7L Diesel
Sold but not forgotten: 1991 Airstream B190
Sold: 2006 F-250 6.0L Powerstroke Supercab
Skater is offline   Reply With Quote
Old 11-26-2012, 06:37 PM   #9
Now that's good to know. I'll have to loosen all of the belts to check the water pump but considering the alternative of losing all three belts again at the most inopportune time it's worth it.
Thanks!
Old 11-26-2012, 06:44 PM   #10
LimeyRich's Avatar
Like clancy boy said remember to retighten the belts once they have had a short running in period. Yeah I knew which belt it was, for some reason my alternator belt is the one that does that. It seems to last just over a year,then twists. I straighten it out, then in about a month it dies. So now I just put a new one on.
Rich.
Old 11-26-2012, 06:48 PM   #11
This is the first time I've ever seen a belt twist like that. Considering we lost all three belts recently and now this one twisted I suppose there is a good possibility that the water pump or the A/C pump pulley could be going bad.
I'll check all to see if I can find a culprit.
Old 11-26-2012, 07:16 PM   #12
1974 Argosy 20
Kooskia , Idaho
Since the old stile V belts are far less common than the were in the past, many manufactures are making one size fits all belts, and not telling anyone that they are a compromise and may not work right.
I had a GMC motorhome, 1975. The GMC community found that many of the belts listed for the 455 Olds engine would not last worth a darn. The problem was that they were only 10 mm wide, not the 11 mm of the original spec belt. The trick GMC owners use now is to take an 11 mm open end wrench with them to the parts house. If it just slips over the belt, you have the right width. If it has play in it, it is a 10 mm belt, and the wrong one for the application. Of course you can also take a 10 mm wrench to do the same thing, when you have your thinking cap on right.
Point is that the Chev 454 engine belts could have the same problem. I don't know. You might check with the 454 P 30 forums to see if there are any others having the problem.
Old 11-26-2012, 09:09 PM   #13
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
You may be running the wrong type of belt. There is an "A" type belt for industrial/agricultural use that is different from an "A" type belt for automotive use.
One would assume that your supplier would know which belt is the correct one.
As noted above; proper tensioning is important. You might also check for alignment of the pulleys.
Old 11-26-2012, 10:35 PM   #14
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Hi, this is caused by being over tightened. As mentioned before they should be installed with the correct tension and after run for as while, [about a week] re-tightened. This is similar to an overloaded Marathon tire, destroying the belts. In your belt, the cords are broken so the stronger side goes to the inside and the weaker side goes out.
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
ROBERTSUNRUS is online now   Reply With Quote
Disc brake reservoir cover desertair27 Ribs, Skins & Rivets 5 01-29-2012 08:40 AM
Kitchen exhaust & cover missing Sheepmate Roof Vents, Skylights & Fans 0 07-27-2011 01:02 PM
RETRAX Bed Cover Mr & Mrs S Tow Vehicles 12 07-19-2011 09:56 AM
How do you cover the back of your truck? aname4me Tow Vehicles 34 03-01-2011 12:36 AM
