Old 09-28-2009, 10:06 AM   #1
spat61's Avatar
2003 31' Land Yacht 30
New Bern , North Carolina
Dash Fan/Rear Monitor
I'm hoping someone can help me out on this forum. I didn't get any response on the other forum. Here goes:
I had my A/C on high with rear camera on when I stopped for gas. I turned the key and heard a very audible short chirp sound when the engine shut off, but didn't give it another thought at the time.
After gassing up, I started the engine and neither the A/C, dash fan and Camera/Monitor would lite up. What happened?
I checked every fuse that I can locate, including under the hood, under the dash, inside driver side compartment and a pigtail from the monitor.
I'm wondering if there may be a relay somewhere in the mix that may have burned. I also pulled the blower motor resistor, it's not burned. I also reseated the connector at the rotary switch panel and checked all connections.
What is strange to me, why did the camera/monitor quit working at the same time the A/C fan? Could it be tied to the fan circuit or relay?
I hate to post twice but I'm also hoping someone can give me a good starting point to help correct this problem. Thanks.
Steve
spat61 is offline   Reply With Quote
Old 09-30-2009, 07:16 PM   #2
I would have to say the audible short chirp that you heard is definitely a clue. Clue to what, wish I could answer that for you.
Its very possible that a relay has crapped out on you. The only way you're going to fix this one is to literally trace each power feed back to its source. On our 84 310 the dash A/C blower motor was fused separately in the fuse block provided by GM. Ours didn't come with a backup camera so its hard to say where Airstream might have pulled power from.
Knowing how the wiring on our 310 was cobbled together at the factory it wouldn't surprise me a bit if they didn't connect your camera to the same fuse or circuit used by the A/C blower.
Unfortunately finding a solution is going to take some good detective work on your part. Wish I could help more............
Good luck!
Replacement Fan Motor for Roof Exhaust Fan SaabLover Furnaces, Heaters, Fireplaces & Air Conditioning 20 01-08-2014 04:00 PM
Need help with "No Dash Fan" spat61 Land Yacht/Legacy Motorhomes 4 09-24-2009 04:05 PM
Help! Dash Air/Blower and Rear Monitor both quit spat61 General Motorhome Topics 0 09-20-2009 06:26 PM
Late 70's light/fan Fantastic Fan installation question tschat Roof Vents, Skylights & Fans 2 07-18-2009 01:30 PM
Rear View Camera and Monitor. cooperhawk General Motorhome Topics 19 04-18-2008 04:10 PM
