Old 06-12-2016, 07:47 PM   #1
1996 30' Cutter Bus
Lawrenceville , New Jersey
Dash air conditioner puzzle
Hi all,
The dash air conditioner on my 1996 30’ Airstream Cutter puts out only warm air.
I’m only learning about air conditioners now. I have a set of gauges and was preparing to take a first set of readings.
These are pictures of the top of the compressor; low pressure fitting on the left; high pressure fitting on the right; I think.
On the low pressure side, you can clearly see the core of the schrader valve.
On the high pressure side—where is it?
The weird thing is is that there are no threads to screw in the core.
What am I missing? Am I looking at the wrong fittings?
This is one of those elusive “Acme” air conditioning systems. So far, I haven’t been able to find any documentation.
David
daa1111 is offline   Reply With Quote
Old 06-12-2016, 08:44 PM   #2
drboyd's Avatar
1978 25' Tradewind
Metro Phoenix , Arizona
You're looking at fittings for R-134a; they're different than the old R-12 threaded fittings. You can get adapters if you have the old style hoses.
Old 06-12-2016, 08:59 PM   #3
1996 30' Cutter Bus
I wasn't clear enough
Hi drboyd,
I guess I wasn't clear enough.
Yes, these are 134a fittings.
The threads I'm talking about are interior threads for the schrader core. There is no schrader core on the high pressure side and there are no threads to screw the core in.
I'm not talking about threads to screw on the test hoses. I have 134a hoses that just snap on.
David
Old 06-12-2016, 09:10 PM   #4
drboyd's Avatar
1978 25' Tradewind
If you're adding refrigerant, you dont really want to be on the high side anyway.
There could actually be a stop valve stem under those plastic caps....
Old 06-13-2016, 12:02 PM   #5
1977 31' Sovereign
Lynnwood , Washington
The system is open and thus, "contaminated." For a proper fix, you can't simply add freon to a contaminated system. It'll never work as intended.
Start by evacuating the AC system. To check for leaks, the system hasta hold 15 lbs of vacuum (negative PSI) for 15 minutes. Once your system can do that, then recharge system with freon.
Be sure to add dye. That way, you can check for leaks.
All of the above requires special equipment. Take it to a shop.
Tom
TomKirk is offline   Reply With Quote
Old 06-13-2016, 02:56 PM   #6
drboyd's Avatar
1978 25' Tradewind
TomKirk is right, if the system is open. Try depressing the Schrader valve on the low side just a bit. If refrigerant hisses out enthusiastically, you can go ahead and recharge it. If nothing comes out, you're "hosed" (pun intended), and you would need a vacuum pump to do it right.
Old 06-13-2016, 04:36 PM   #7
1996 30' Cutter Bus
Hi guys,
I have a vacuum pump.
But I'm not that far yet. The system can't hold any refigerant because of the issue I explain.
David
Old 06-13-2016, 05:17 PM   #8
1991 25' Excella
Stanfield , Oregon
R-123a fittings are generic they sell repair kits for them high and low pressure side. The problem is your system is now contaminated and well need flushed and serviced. There is oil and freon in the system or in your cause there needs to be. Id take it to a shop with the correct tooling and experience. Otherwise it can get expensive in a hurry.
SpletKay06 is offline   Reply With Quote
Old 06-13-2016, 07:41 PM   #9
1996 30' Cutter Bus
So I have an idea about what's going on:
Some high pressure ports don't use schrader valves; they use some kind of ball and gasket valve. And these are supposed to be highly susceptible to leaking.
I understand that these can be replaced with a schrader valve. Which would make sense to me since I have no idea about where to get test guages that would work on one of these ball valves.
And as SpletKay06 said, these are cheap and are easily replaced.
I will look into that soon.
David
Old 06-13-2016, 09:11 PM   #10
drboyd's Avatar
1978 25' Tradewind
Find a store specializing in automotive a/c parts. They will also have "system flush" fluid and oil to replace the oil that may have been lost.
Old 06-14-2016, 07:32 PM   #11
1996 30' Cutter Bus
Finding a new valve is turning out to be difficult. There doesn't seem to be any kind of generic valve. I've been to three auto stores and online, and everything seems to be for a specific make and model of auto. How to find a valve for a now defunct "Acme" system is, at the moment, beyond me.
David
Old 06-14-2016, 07:50 PM   #12
drboyd's Avatar
1978 25' Tradewind
How about getting the model number off the compressor and getting a new discharge fitting? Or, if you're cheap like me, scrounge another one at a salvage yard...
Old 06-15-2016, 01:02 AM   #13
1991 25' Excella
Stanfield , Oregon
I'd need a better look but most of those older systems got converted with connectors like these http://www.ebay.com/itm/like/2316417...&ul_noapp=true
Old 06-15-2016, 08:33 AM   #14
mayco's Avatar
1982 31' Airstream 310
champaign , Illinois
Have you tried these folks....
http://www.acmeairparts.com/rvacheaterparts.html
mayco is offline   Reply With Quote
P-30 Dash Air Conditioner and "H" valve smily Mechanics Corner - Engines, Transmission & More... 19 10-24-2015 09:59 AM
Dash Air Conditioner Problems Santart Land Yacht/Legacy Motorhomes 4 09-05-2012 01:54 AM
Dash air conditioner/heater landmarc Flat-Front (Cutter, Clipper, XC, XL & Skydeck) Motorhomes 2 02-10-2012 05:03 PM
Galley Puzzle Cat Cabinets, Counter Tops & Furnishings 9 10-07-2006 05:26 AM
Dash Air Conditioner-Not Cool rickd Mechanics Corner - Engines, Transmission & More... 16 06-17-2004 02:50 PM
