Old 06-13-2007, 09:28 PM   #1
Dash a/c vacuum hoses
The heater/ac control switch on our 84 310 was busted up pretty good when we got the MH. I've managed to locate a replacement switch and while removing the old one I found that one of the vacuum hoses was pulled from the connector. And to make matters worse one slipped out while removing the old assembly.
So, doing a search I ran across the following thread http://www.airforums.com/forums/f159...nes-22451.html which included a nice breakdown of how the switch is wired and plumbed. Unfortunately it doesn't seem to quite match how mine is laid out. Also I have a white tube in place of the yellow one. My blue and red hoses were the ones that were pulled out of the back so I don't really know where they go. To make matters worse the plug assembly has some of the holes blanked which makes those a no brainer when it comes to not plugging a hose in
Could someone with the same color hose combination Blue, Red, Black & White point to where each of the tubes go? I did verify using a Mity VAC that the Red, Blue and White are tied to servos and they seem to be working fine. The black hose I believe is the vacuum supply line and it has no vacuum on it while the engine is running. Anyone know where that tube originates? I'm planning on pulling the dog house cover tomorrow evening to see if I can pin point its point of origin.
While I'm inside the dash I also plan on fixing the vacuum line to the fuel economy gauge. Always makes me feel bad when I see it hit the red
Of course once I get the vacuum feed line working I can probably figure it all out for myself. But then, where's the fun in that
Any help would be greatly appreciated.
Old 06-14-2007, 06:37 AM   #2
1984 31' Excella
Norfolk , Virginia
Images: 11
Heater Controler
Could you post a picture of the controller?
I really looks like the heater controler out of dodge vans of the 1980s decade. If that is the case, parts could be readily avaliable and cheaper.
Beginner
Beginner is offline   Reply With Quote
Old 06-23-2007, 10:26 PM   #3
Beginner
Beginner, I managed to sort the mess out a few days ago. Part of my problem is I'm now having to wear reading glasses and I'm finding it hard at times to know just what I'm looking at
Anyway, I looked closer and finally realised there were only 4 openings in the plug going into the switch so all it took was some swapping lines around to get things sorted out. I even managed to fix the vacuum line that goes to the fuel economy gauge. I found a receipt from the PO that indicated the mechanic cut the line and plugged it "because of a vacuum leak under the dash somewhere was keeping it from passing the smog test". The PO didn't want to pay the extra money it would take to fix it
The job is done and I'm now onto other items that have to be fixed before our trip.
Vacuum source for hydraulic brakes Coastalview Brakes & Brake Controllers 9 07-12-2014 07:41 AM
A/C replacement? VWMARTINEZ Furnaces, Heaters, Fireplaces & Air Conditioning 6 03-09-2007 02:14 AM
Dash A/C PeterH-Airstreamer Mechanics Corner - Engines, Transmission & More... 32 08-10-2003 04:39 PM
1971 Armstrog A/C uwe Furnaces, Heaters, Fireplaces & Air Conditioning 2 08-06-2002 05:08 PM
Mediocre A/C Chuck Furnaces, Heaters, Fireplaces & Air Conditioning 4 07-07-2002 07:52 PM
