Old 10-14-2004, 08:47 AM   #1
Chaplain Kent's Avatar
1994 30' Excella
Milwaukee , Wisconsin
Cruise Control
I have just purchased a 1982 280 Turbo Diesel runs like a clock but the cruise does not work. Any advice as to which way to go. Should I repair or get an electronic cruise installed. A cruise is a must since I am disabled and need it for driving. The PO had it repaired prior to delivery, servo and drive shaft pick up. The mechanic is 1500 miles away so good to me.
Chaplain Kent
Chaplain Kent
2015 Coachman Freedom Express 19RBS, Chummy IV- Ford Excursion- 7.3 Turbo-diesel
Chaplain Kent is offline   Reply With Quote
Old 10-14-2004, 09:16 AM   #2
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
Imhop electonic cruise would be a bonus for you. My old cruise does not work also, never has. Same year model as yours. Good luck with your 280, I have really enjoyed ours.
1966 overlander..sold
AIR #005
OUR AIRSTREAM PASSION! BLOG
RESTORING AN AIRSTREAM
retired!
Old 10-14-2004, 09:21 AM   #3
Just a member
thenewkid64's Avatar
1978 28' Argosy 28
Tampa Bay , Florida
Images: 21
I have installed the Audiovox Aftermarket cruise control system on multiple vehicles. They work well and come complete. They can use the OEM turn signal mounted control. They run about 100 bucks and take 3-4 hours to install.
Brett G
WBCCI #5501 AIR # 49
1978 Argosy 28 foot Motorhome
Old 10-14-2004, 01:49 PM   #4
87MH's Avatar
1978 31' Sovereign
Images: 292
Originally Posted by Chaplain Kent
I have just purchased a 1982 280 Turbo Diesel ...SC does not work. ...... Should I repair or get an electronic cruise installed.
Does your Turbo Diesel have a vacuum pump? - You might want to check the operational level of the pump.
I, also, have an audio-vox, but you will need a vacuum source for the control.
Ford has a mechanical cruise control that may be able to be adapted for use on the Isuzu engine.
Dennis
WBCCI # 1113
AirForums #1737
Trailer '78 31' Sovereign
Texas Airstream Harbor, Inc.
Old 10-14-2004, 07:56 PM   #5
Just a member
1978 28' Argosy 28
Tampa Bay , Florida
Images: 21
I may be wrong, but I think on the Isuzu powered models that Alternator has a vacuum pump slaved to the shaft to supply vacuum for other needs. It makes for one less belt, but a very expensive alternator.
Brett G
1984 motorhome cruise control cooperhawk Airstream Motorhome Forums 2 12-25-2003 08:12 AM
Heater, Airconditionor Dash Control cooperhawk Airstream Motorhome Forums 4 11-11-2003 08:38 PM
Control Panel fix! Mike76251 Electrical - Systems, Generators, Batteries & Solar 1 10-03-2003 03:35 PM
No cruise control on '92 30' fangthorpe Mechanics Corner - Engines, Transmission & More... 3 05-09-2003 09:46 PM
Cruise Control Servo Diaphram zamboni Airstream Motorhome Forums 5 06-26-2002 09:14 PM
