Old 10-01-2018, 08:49 AM   #15
1987 34.5' Airstream 345
Sevierville , Tennessee
https://photos.app.goo.gl/GfYW9w399TuMEmfE8
John P is offline   Reply With Quote
Old 10-01-2018, 09:47 AM   #16
Magnet18's Avatar
Churubusco , Indiana
I don't see any attachments
1983 Airstream 310 Class A Motorhome
-Rob
Magnet18 is offline   Reply With Quote
Old 10-02-2018, 08:38 AM   #17
https://photos.app.goo.gl/aqHJxHKpoDs2kRWu7
Old 10-03-2018, 07:11 PM   #18
Look what I found in 50 pounds of manuals. One of the previous owners either modified or replaced the electric cooling fans wiring system. I havenít a clue as to what or why this was done. Can anyone venture a guess based on these hand sketches? Any thoughts will be welcome.
Old 10-04-2018, 04:49 AM   #19
Why did he do it, who knows. Basically what the PO did was to wire it so that the AC pressure switch, dash switch or engine coolant temp will turn the fans on.
In general that's pretty much what any cooling system with fans is trying to do, turn them on when the temp gets to high or when the AC system is running.
At first glance I don't see why this arrangement wouldn't work. It would be nice to know what coolant sensor was used and what temperature setting causes it's internal switch to close.
Sorry, not much help.
Old 10-04-2018, 05:04 AM   #20
Magnet18's Avatar
Assuming
1 the coolant temp switch goes to ground
2 the solenoid goes somewhere logical
I also don't see why it wouldn't work
After you troubleshoot and verify what is happening, I'd recommend inspecting all the wiring and looking for bad connections. Also verify that it matches your schematic you just posted. Especially if the PO did the wiring, there could be slice-n-dice connectors gone bad or something.
-Rob
Old 10-12-2018, 12:15 PM   #21
Thanks everyone for all the thoughts and recommendations. Not knowing if it was good or bad, I decided to just replace the fan clutch. All electrical connectors were examined and all ground leads were removed and cleaned. The AC high pressure switch and radiator temperature sensor were examined and found to be in working order. On a test ride I was not able to duplicate the original issue so I think I am good. Thanks again for the recommendations. I am a happy camper!
Old 10-13-2018, 05:50 AM   #22
Boom Sounds's Avatar
1991 25' Airstream 250
Oxford , Oxfordshire
Good stuff, aside from keeping the temps down, the fan clutch will save costly repairs to the engine and tranny. You'll hear it kick in when you go up hills etc. Don't be alarmed by the noise; it's a 'feature'. A cheap and worthwhile fix in my opinion. Happy camping. Nick
Boom Sounds is offline   Reply With Quote
Air Conditioning cooling issue Neil Archer Land Yacht/Legacy Motorhomes 14 10-04-2016 10:48 AM
domestic rm 60 cooling issue batt Refrigerators 0 07-25-2010 11:09 AM
cooling fan ?? kepko Land Yacht/Legacy Motorhomes 4 08-10-2008 10:50 AM
Auxiliary Electric Engine Cooling Fan cooperhawk Airstream Motorhome Forums 8 02-25-2007 07:18 AM
Electric Cooling Fan Settings rdm Mechanics Corner - Engines, Transmission & More... 1 07-12-2002 06:29 AM
