Old 02-27-2007, 08:45 PM   #1
Cooling at idle
Just wondering how many of you can have your MH sitting at idle for long periods of time without any significant temperature rise or over heating issues. Our previous SOB MH built on the P30 chassis would start getting excessive temperatures if sitting and idling for a period of time, even with a new replacement radiator. I've noticed (while idling) that our 84 310 temperature can rise to as high as 220 or so (before I finally shut it down) and that was with an ambient temperature of around 65 degrees. This particular engine has about 17,000 miles on it and was a factory Gen 5 crate engine. From Savannah GA to Arkansas it ran pretty much right at 200 degrees. Of course we were traveling with ambient temperatures only in the upper 50s max, however we were towing our Honda behind it so that did add some overall weight.
It does have a new fan clutch, water pump and radiator all within the last 5 years. The PO did comment that when going up grades in the mountains towing his Jeep he had to keep his eye on the temp gauge. That just doesn't seem right to me. I would think a properly designed (and maintained) cooling system should be able to deal with these conditions. Am I missing something?
Anyway, any input would be greatly appreciated
Old 02-28-2007, 05:41 AM   #2
Well Preserved
overlander63's Avatar
1993 21' Sovereign
Colfax , North Carolina
It's an ongoing issue, since there really isn't a lot of area to cool with. Also, the radiator sits way far back into the body getting air to it is a challenge. Does your moho have an auxillary cooling fan on the radiator? If not, this is one method of helping with the issue.
Old 02-28-2007, 07:12 AM   #3
Druupy's Avatar
2005 28' Safari
Port Orchard , Washington
You probably have a 195 degree thermostat in the motor.
That gives the best fuel mileage as long as it ses only light duty.
What you have is at least medium duty 180 degree,
or heavy demand 165 degree.
Get a cooler thermostat and see what happens.
Druupy is offline   Reply With Quote
Old 02-28-2007, 08:51 AM   #4
guy99's Avatar
1984 31' Airstream310
Dunsmuir , California
Images: 16
My 1984 310 Limited ran 200-210 no matter what I did to the cooling system until I replaced the temp gauge and sender. Now runs 180-190 unless under heavy load with high ambient temps.
I suggest you validate the reading you are getting.
1984 310 Limited Motorhome
guy99 is offline   Reply With Quote
Old 02-28-2007, 09:26 AM   #5
Aluminut
Silvertwinkie's Avatar
2004 25' Safari
. , Illinois
There are several things that can be done in cars that I would assume can be done to mohos and the P30 in particular.
One is do a good flush of the system. Clean the radiator from the inside out by pushing water from a hose from the engine side to dislodge any bugs, dirt, etc the came in from the other way. These two alone lowered my coolant temps by 3-4 degrees.
I added water wetter and frankly found no benefit, though some swear by it.
Some folks have place an all alum radiator in place of the current designed units. These puppies will drop temps like a rock, but be prepared to shell out some war bucks for them!
Of course as has been suggested, a thermostat replacement can do. I have a 160 stat in my SS, but it has reverse cooling, where the heads get cooled first as part of the LT1 design, which I doubt the 454 has. Going too cool on a non reverse cooled engine can be problematic, particularly for engines that have temperature controlled functions, not computer controlled. Going from 195 to 180 might not be too bad, but going from 195 to say 160 on that engine might not be such a hot idea (literally).
Old 02-28-2007, 10:36 AM   #6
2017 27' Flying Cloud
Altoona , Florida
I like two of the suggestions provided - Do a verification of the actual temp and if it turns out high, look into auxiliary electric fans to increase the airflow though the radiator when the moho is not moving. It sounds like you cooling system is working ok, just can't get enough air to provide a suitable heat sink when the moho is at idle.
Poprivet is offline   Reply With Quote
Old 02-28-2007, 12:25 PM   #7
GlenCoombe's Avatar
1984 28' Funeral Coach
Belleview , Florida
Images: 27
I changed my thermostat out last summer for a 160 and saw a great drop of course. Didn't put the 195 back in til the cold snap last month. Now with the temps returning to normal I'll be looking for an opportunity to change back to the summer stat.
I also have a fast idle setup from the old engine driven bus type a/c. If things get too hot I can always wind it up some.
The big block at idle is just kind of loping along so consider shutting down if you're idle time and temp is of concern.
But the bottom line is to change that thermostat for the summer.
Heat is the enemy.
Glen Coombe AIR #8416
Former Rolling Showroom & PuttLab (now party bus)
"I'm not an expert. But I did sleep in an Airstream last night."
GlenCoombe is offline   Reply With Quote
Old 03-01-2007, 04:41 PM   #8
Wow Thanks for all the replies. As yet I don't know what range thermostat is in the engine and I really like the idea of verifying what the real temperature is. Any suggestions on how to best determine what the real temperature is? I've been thinking of using something like a laser temperature probe, would that work?
I'm still hoping someone will post pictures of their electric cooling fan installations so I can see what that looks like.
Thanks!
Old 03-01-2007, 04:55 PM   #9
guy99's Avatar
Images: 16
When I had my radiator replaced the shop used a laser temp gauge on the thermostat housing and got a much lower reading than my gauges. Also the engine did not seem hot, it didn't smell like a hot engine, didn't ping, and cooled down very quickly when I parked.
Old 03-01-2007, 06:36 PM   #10
lewster's Avatar
Naples, FL , Hood River, OR
Along with the great suggestions above, you might also consider an oil cooler as a desired engine mod. It will do a lot to keep your engine at lower temps, along with a functional cooling system.
Old 03-01-2007, 07:00 PM   #11
str8strm's Avatar
1985 34.5' Airstream 345
Tujunga , California
Brad:
We're going try to get over to where our 345 is stored this weekend and do some tinkering. I'll take some pix of the fans and post them. Ron
Ron and Debbie Lawrence
1985 345 Motorhome...... delightfully tacky......yet unrefined
AIR 7992
str8strm is offline   Reply With Quote
Old 03-01-2007, 07:32 PM   #12
Originally Posted by str8strm
Brad:
Ron,
Photos would be great! Like my wife says, men are visual oriented and women are intellectually oriented
Lewster,
I had been thinking about an oil cooler and will have to include that to the list of upgrades to be done. In our last MH I really hated sitting in traffic having to turn the a/c off just to try and keep the temp from climbing through the roof.
guy99.
Sounds like the laser probe might just do the trick.
Thanks for all the feedback!
Old 03-01-2007, 08:15 PM   #13
Altoona , Florida
Heres a test you can do -
With your motor home near an A/C electrical supply, hook up an ordinary household box fan against the grill, on fast, and blowing streight into the radiator. See if the idle temp goes down any.
Old 03-02-2007, 04:34 AM   #14
David, I should have thought of that myself. Thats exactly what I used to do with my wifes race car before we installed the electric fan in front of the radiator. She used to run with no fan at all so we had to use one of those square box fans while doing tune up work on it at idle.
Thanks for the reminder
refrig cooling problem frydmans 1969 - 1973 Safari 12 08-25-2002 06:19 PM
Electric Cooling Fan Settings rdm Mechanics Corner - Engines, Transmission & More... 1 07-12-2002 06:29 AM
Fridge Cooling Problems 68International Refrigerators 6 07-10-2002 03:53 PM
Poor cooling on AC, good on gas Pahaska Furnaces, Heaters, Fireplaces & Air Conditioning 1 06-13-2002 10:46 PM
Auto trans temps chart FrankR Mechanics Corner - Engines, Transmission & More... 9 05-05-2002 08:42 AM
