Old 04-08-2007, 10:48 AM   #15
IPM
1996 clipper gas 34'
Blue Springs , Missouri
I moved the aux trans cooler and engine oil cooler to right of radiator, put an electric suck thru fan on stacked engine oil cooler/aux trans cooler, installed exhaust headers which moved heat under chasis, removed radiator and had cleaned out, installed 180 thermostat, new water pump, hoses, belts and it runs very cool at all times. Before it got hot like yours.
It's all good
IPM is offline   Reply With Quote
Old 04-08-2007, 12:52 PM   #16
bobchevy89's Avatar
1977 24' Argosy 24
Inverness , Florida
try flushing the fins of the radiator out with a hose .do you have a trans cooler and a oil cooler in front of the radiator? the help trap dirt in the fins .causing poor air flow.
just want to camp happy
bobchevy89 is offline   Reply With Quote
refrig cooling problem frydmans 1969 - 1973 Safari 12 08-25-2002 06:19 PM
Electric Cooling Fan Settings rdm Mechanics Corner - Engines, Transmission & More... 1 07-12-2002 06:29 AM
Fridge Cooling Problems 68International Refrigerators 6 07-10-2002 03:53 PM
Poor cooling on AC, good on gas Pahaska Furnaces, Heaters, Fireplaces & Air Conditioning 1 06-13-2002 10:46 PM
Auto trans temps chart FrankR Mechanics Corner - Engines, Transmission & More... 9 05-05-2002 08:42 AM
