Old 07-09-2011, 04:59 AM   #1
1989 34.5' Airstream 345
Jamestown , Kentucky
Images: 13
Convert aircondition Pump to serpintine belt
can this be done on the 88 era 454's ?
only a single, small belt now drives the air conditioner pump.
Belt dressing also is a big Plus.
John H. is offline   Reply With Quote
Old 07-09-2011, 07:21 AM   #2
Well Preserved
overlander63's Avatar
1993 21' Sovereign
Colfax , North Carolina
Is it a DA4 or A6 compressor? The DA4 had a serpentine belt pulley and clutch as an option on some models.
Old 07-10-2011, 08:15 AM   #3
Images: 13
5D-709
is the only number I can see, read
maybe a SD ?
Sanden corporation is the manufacture
there are 2 V belt pullys on front
Old 07-10-2011, 08:20 AM   #4
Well Preserved
1993 21' Sovereign
If it looks like this one, I'd say yes you can get a serpentine pulley:
REMANUFACTURED SANDEN SD709 6 GROOVE A/C COMPRESSOR AND on eBay!
Old 07-10-2011, 03:49 PM   #5
Images: 13
Thank You !
Flojet or Shurflo Fresh Water Pump? SilverCottage Water Heaters, Filters & Pumps 8 07-24-2011 02:25 PM
Top air Pump Froze up, cooked the belt John H. Mechanics Corner - Engines, Transmission & More... 16 07-14-2011 07:53 PM
Bad Check Valve in Pump??? tinbender Water Heaters, Filters & Pumps 3 06-16-2011 06:56 PM
Water pump leaking between head and motor Ezmoneybcs Water Heaters, Filters & Pumps 4 03-20-2011 06:32 AM
Is it a water pump or an electrical problem? Taj MaHaul Water Heaters, Filters & Pumps 7 01-23-2011 07:20 AM
