Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Motorhome Forums > Mechanics Corner - Engines, Transmission & More...
Old 07-06-2003, 01:31 PM   #15
wb13798
wb13798's Avatar
Profile:  2004 28' Classic
huntsville , Alabama
the infared test was done at a muffler shop here in huntsville.
just finished installing the new clutch (thermal clutch) and i cant get the temp over 180. i havent put a thermostat in yet. and the water has the watter wetter stuff in it. before the trip to nashville i dumped a can in the system and it dropped the temp 20 degrees, i was impressed . now that i look back im lucky to have done same as i probably would have had to fix the weenie for over heating last week end.
the non-thermal clutch looks like the thermal but it is a rpm sensitive clutch. more rpm less friction and fan turns less rpms. it is supposed to turm one for one at low less than 1000 rpm .
we all have a problem with the 454s running hot and when you pull a toad you have more heat to worry about.
your sencet in the block might need replacing . they are not that expensive . i replaced mine before i had the temp checked at the muffler shop. also on my engine the right side exhaust manifold runs hotter than the left side. im going to put a 180 thermostat tomorrow, and hopefully that will be the end of this effort.lol
al
wb13798 is offline   Reply With Quote
Heat Pump and Furnace Operation Cracker Water Heaters, Filters & Pumps 21 12-10-2003 04:10 PM
Refer heat / venting JaceBeck 1999 Safari 3 08-21-2003 09:40 PM
Starter heat problems ALANSD Mechanics Corner - Engines, Transmission & More... 0 02-15-2003 03:51 PM
Heat protection ALANSD Airstream Motorhome Forums 14 11-03-2002 03:55 PM
Heat Riser ALANSD Airstream Motorhome Forums 7 09-11-2002 04:38 PM
