10-16-2015, 06:45 PM
#21
Rivet Loser
La Ronge
, Saskatchewan
Originally Posted by chiefair
No, the 8.1 is a different block than the 502. The 8.1 is a "tall deck" with a longer stroke than the 502.
1982 310 motorhome 454
Henniker New Hampshire
Interesting. So does the 502 not burn more gas than the 454? I presume we're talking TBI for fuel atomization though.
1989 345LE
10-16-2015, 07:36 PM
#22
1982 31' Airstream 310
Henniker
, New Hampshire
I have a Holley 850 carb. I have been on one shakedown cruise and one weekend camping trip since I installed the 502. My initial impression is that my fuel mileage has improved. I never calculated it with the 454 so I can't make a real accurate assessment. I've always felt that if you are worried about fuel mileage you should probably find another hobby.
I think the 502 is not working as hard as the 454 was so that may explain my perceived increase in economy.
I certainly never expected it to run so much cooler.
1982 310 motorhome 502
10-16-2015, 08:22 PM
#23
Franklin Park
Too hot?
For what it's worth
When I receieved my 345 last year it would 200 - 220
I did a little research and had people on the internet say that 200 - 210 is normal and good for a 454 "they like to run hot" seemed to be the answer, but I just could end stomach it so I did a simple flush (not removing the radiator)
I replaced the 190 thermostat with a 160 then ran just water and a product called water wetter. Now my temps seem to run cooler 180 - 200. BUT I live north (Chicago Area) and I will flush again and install antifreeze very soon!
Here's another thing... The temp sensor on the 454 is in the head I since have installed another gauge with its sensor in the upper radiator hose
Just today running down the highway the temp difference between the two pretty great at one point the head temp was 200 and the upper hose one was 180
Also for what it's worth I also installed a engine oil temp it was reading 200 - 210 today (it was however a PERFECT travel day sunny and 60*)
10-16-2015, 09:40 PM
#24
Dazed and Confused
Hillsburgh
, Ontario
Just my 2 cents
83 Isuzu, no dash air due to compressor seized and disconnected, with interior heater cored bypassed runs a steady as a rock 180 degrees in up to 95 F.
Recent trip in much cooler temps with heater core bypass open, saw temps 165-170 for much of the trip on highway, into the hills and on the diesel, close to, but not quite 180.
Cheers
Tony
10-17-2015, 07:22 AM
#25
1989 34.5' Airstream 345
Ebro
, Fla Panhandle
WOW ! Chiefair. Only 100 degrees indicated temp would cause me to doubt the gauge. Have you confirmed those temps? Those hand held laser thermometers are usefull.
Hell, I mean in Phoenix up until a few days ago you'd get 100 degrees before starting the engine.
Interesting to hear that the cooling water additives are so effective .
It seems clear to me that managing airflow thru the engine compartment is crucial to proper cooling in our classic coaches. I had read here about the importance of the air dams , so that's why I replaced mine.
10-17-2015, 07:24 AM
#26
Ebro
, Fla Panhandle
I lost the previous text two times when trying to add pics. So here it is in the making and fitting stage.
10-17-2015, 07:27 AM
#27
Ebro
, Fla Panhandle
And installed.
Also replaced the dams at the bottom of the radiator.
10-17-2015, 07:29 AM
#28
Ebro
, Fla Panhandle
Better pic
Having the new dam in place totally blocks any view of the front of the engine. But is somewhat removable for access.
10-17-2015, 07:37 AM
#29
Ebro
, Fla Panhandle
The view out the stream door while parked here at my place here in Chino Valley.
Tho it's usually covered I still enjoy seeing it right out the window.
Really appreciate all the positive comments about my rig and Toad.
The Porsche is a great car to own, drive, and to tinker with.
Mostly DIY maintaince. Also fun PCA club activities like Autocross, and track days. Big fun!
I'm hoping to include more Porsche club activities into future travel plans, join in with distant track or Autocross events while traveling.
The online Porsche community is active and a lot of fun for me.
Here is a link to my summer travel thread that I posted on pelican parts, my favorite site. Warning lots of car content.
Cheers Richard
http://forums.pelicanparts.com/off-t...g-911-tow.html
10-17-2015, 07:48 AM
#30
champaign
Originally Posted by Isuzusweet
Just my 2 cents
Cheers
Tony
Same same Tony, on my 310 TD. No dash air, heater core is connected, steady Eddie at 185. It will climb to 200 when its warming up, thermostat opens and it sits at 185.
10-17-2015, 09:06 AM
#31
Ebro
, Fla Panhandle
Those ornate chrome vents above the front wheel wells really do work.
This became clear to me after an overnight drive across the desert from Az to Ca. At the very beginning of this summers trip.
I started out all freshly washed clean, coach and toad.
I stopped at a rest stop in the wee hours of the morning for a couple of hours of shut eye.
My morning walk around showed that I had An oil leak in the hard trans oil cooling line to the radiator. ( too much movement while doing the radiator work ).
Anyway the pinhole leak had blown into the wheel well area and out that vent and only out that vent, none around the edges of the wheel well.
Out the vent in a narrow swath growing wider till mid way down the coach it covered the whole side of the coach and the car as well. Yuck. Sticky mess to find yourself in in the middle of a drought area.
BUT THE VENTS DO WORK!
Cheers Richard
10-17-2015, 10:12 AM
#32
Henniker
, New Hampshire
I have confirmed my temps with a thermometer. My temp sensor is in the head but I found very similar readings at the thermostat housing.
10-17-2015, 02:33 PM
#33
1966 26' Overlander
Woodstock
, Georgia
Cheers Richard
R Ving with 911 in tow - Pelican Parts Technical BBS
I know this is off topic...but I too am a Pelican since 2002. Had an 81 Euro Targa in 1987 until 90, bought my present one in 93.
10-17-2015, 02:49 PM
#34
Rivet Loser
La Ronge
, Saskatchewan
I figure I'm not old enough to buy a Porsche or start playing golf yet.........
1989 345LE
10-17-2015, 02:50 PM
#35
Airstream Driver
1994 30' Excella
1992 35' Airstream 350
Austin
Beautiful Porsche, Alan, You and me both know what you need to pull that with
hint.......:
AIR #13
10-17-2015, 04:12 PM
#36
Rivet Loser
La Ronge
, Saskatchewan
Cheers Richard
I have to admit that is pretty convincing evidence. It was only yesterday that I had my head stuck inside the left fender well and felt very skeptical that the vents would actually accomplish anything.
1989 345LE
10-17-2015, 04:16 PM
#37
Airstream Driver
1994 30' Excella
Austin
Never too late to learn.
I have 2, one for trans fluid, the other for engine oil
AIR #13
10-17-2015, 04:18 PM
#38
Rivet Loser
La Ronge
, Saskatchewan
Originally Posted by dznf0g
I do not have any personal experience with the MH, but I was involved form a MFR standpoint 20 years ago. I specifically recall the absolute need for inner fender closeouts for both sides. When they are open there is a lot of turbulence in that area which prohibits a flow of hot air out of the engine bay. You want a smooth stream of air from the grille opening, back and down and out through the rear. Having no inner fender closeout "balls up" all the hot air and leads to overheating and fuel boiling issues....especially on carbureted models.
So why did not Airstream (or was it GM?) not fit a closeout on the right side? And we're talking years and years without one. There's some old guy somewhere who knows the answer to this.
1989 345LE
10-17-2015, 04:20 PM
#39
Rivet Loser
La Ronge
, Saskatchewan
So you have some ducting in the fender well that leads to the vents separately?
1989 345LE
10-17-2015, 04:22 PM
#40
Airstream Driver
1994 30' Excella
Austin
No, never seen a duct connected to one of the vents. More stuff I have to learn about these?
AIR #13
