Chevy Chassis Brake System
Just to give all of you P-3X S&M dudes (you all know who you are) a "heads up" on one more thing to watch out for...
When driving back from the Blanco Rally, I just pulled into my street when the "Brake" idiot light came on.
I still had brakes - just a bit hard to apply.
Jacked up the front end, installed the safety jacks, and took off the two front wheels (I'm getting pretty good at this by now) - found the "front" reservoir bone-dry and found the leak to be the curb side brake bleeder - upon inspection there is a circular "cut" (3/4 of the way around) on the bottom of the failed bleed valve - almost as if I over-torqued the valve and the seat cut into the valve.....don't know for sure the mechanics of the actual failure. I use a wrench about 6" long for all of the brake bleeding work, so it's hard to imagine that my carpel tunnel affected wrists could screw up ANYTHING with only a 6" wrench.
Replaced the bleed valve with a new one, bled the fronts, re-set the combination proportioning valve, replaced and torqued the front wheels, and hit the back streets for a test drive. BTW, the test route navigated the 345 to the local Mega Lo Mart where I took on a considerable number of gallons of 87 Octane at $1.449 per gallon. Don’t think I will ever see gasoline at that price again.
Interesting thing - the proportioning valve - it actually performs 3 functions:
a.) metering valve
b.) warning switch
c.) proportioning
…. and I did not think I had one! It (the valve) is hidden within the front crossmember - took a lot of touchy-feely to determine that it was actually there - the reason I was looking for it was I KNEW there were no electrical connections to the master cylinder, and yet I had the idiot light come on - so I knew there was a brake/electrical interface that I was not aware of.
I had assumed previously that the two pressure outlets from the master cylinder went only to the front and rear systems respectively - learned something new….one of my “Christmas gifts” to myself came in handy – a genuine paper set of 1986 Chevy Light Truck Service/Repair Manuals…off of e-bay. Most of the time understanding what the manuals are trying to say is a bit of a chore for me, but this time it was explained simply enough (interpretation – there were a LOT of pictures and diagrams) that I was able to follow along.
Dennis
WBCCI # 1113
AirForums #1737
