Old 11-22-2016, 04:41 AM   #1
1981 28' Airstream 280
Wentworth , NSW
Chev 400 Auto Gearbox
My excella motorhome that I imported to Australia has an Isuzu diesel motor and a chev 400 gearbox. The auto has no 'park position'. My roadworthy engineer needs an explanation why for his report. Is this how they came from the factort after vthey were reprogramed to match the diesel?
Ted
Ted OShann is offline   Reply With Quote
Old 11-22-2016, 05:02 AM   #2
Retired.
. , At Large
Welcome to the forums.
The heavy duty transmissions generally don't have a parking pawl in them, as it is too easy to damage or destroy it. Most use the parking brake, typically mounted at the rear of the transmission, as "park".
Old 11-22-2016, 11:57 AM   #3
Smartstream's Avatar
1982 28' Airstream 280
Port Angeles , Washington
Your Airstream should have a TH 450 or 475 and it should have a park position on the gear selector. It also has a parking brake on the rear of the trans operated by a lever under the dash. If you have rear drum brakes the parking brake will be in the rear drums rather than the rear of the trans.
If you have no park position on the gear selector you may have an Allison transmission. They were rare but they do exist with the Isuzu diesel and they do not have an internal park pawl.
Good Luck,
Cheers, Dan
~ Margaret Thatcher ~
Old 11-24-2016, 03:51 AM   #4
Wentworth , NSW
Chev or Allison?
Thanks Dan and Terry,
I had assumed that it was a chev auto but I would be happy if it was an Allison. I will have to have a closer inspection. I just have to research the difference between the 2 so that I can recognise which one it is. It does make sense that it is a heavy duty box as there is definitely no park position on the gear selector.
Cheers,
Ted
Old 11-24-2016, 04:20 AM   #5
Retired.
. , At Large
Cheers,
Ted
It's been the better part of a decade since I was under one of those, but I remember the pan on the transmission of the THM 400 series having something like "Hydromatic GMC" stamped in them.
Old 01-21-2017, 02:17 PM   #6
For GM...
http://www.maliburacing.com/auto_tranny_id.htm
Allison.
http://www.trucktransdiag.com/1k2k-tech-tips.htm
Old 01-23-2017, 12:43 AM   #7
Boom Sounds's Avatar
1991 25' Airstream 250
Oxford , Oxfordshire
Steve - very useful. Thanks for that.
Boom Sounds is offline   Reply With Quote
Old 01-24-2017, 12:49 AM   #8
Wentworth , NSW
Allison gearbox
It is definitely an Allison box. Pretty happy with that.
Ted.
Gearbox Mjgman Sprinter and B-van Forum 5 08-12-2016 05:13 AM
Steering coupler - between gearbox & column bkahler Mechanics Corner - Engines, Transmission & More... 10 10-16-2012 08:30 AM
need steering gearbox for 1977 argosy 24 dillmann Member Introductions 1 05-22-2008 11:24 AM
Window lifting arms/gearbox Walker's Wanderer Windows & Screens 2 03-25-2004 07:46 AM
Trailor brakes on 2003 2500 chev joel Tow Vehicles 9 10-10-2003 05:30 PM
