Old 05-24-2004, 03:19 PM   #1
Ann Arbor
Question cavitation in Isuzu engines
Does anyone know if cavitation (pitting of the piston interior wall) occurs in Isuzu engines if coolant additive is not used. Cavitation is a known problem in the 7.3 IDI engine in my Ford truck, which is why I ask.
Thanks for any info.
Eugenie
maznblu is offline   Reply With Quote
Old 05-24-2004, 03:22 PM   #2
Aluminut
Silvertwinkie's Avatar
2004 25' Safari
. , Illinois
Are you specifically talking about the Duramax?
Old 05-24-2004, 04:08 PM   #3
Moderator Emeritus
Pick's Avatar
1972 31' Sovereign
High Springs , Florida
Images: 36
Cavitation is an issue in ALL diesel engines. Best cure is prevention. Change your coolant every year if possible, or at least every 2 years, minimum. There are additives, but regular coolant changes are the best.
One friend of mine had to replace his John Deere tractor engine block, because of cavitation. Another a piston liner in his '89 Ford 7.3L.
ARS WA8ZYT
Propane Powered Honda EU2000i
Lots of Hot Sauce!
Air # 283
WBCCI 1350
Old 05-31-2004, 10:22 AM   #4
dienst1's Avatar
Images: 11
Cooloant additive
I paid a bunch to replace the non turbo Isuzu engine, in my 1981 Excella, with a new Isuzu turbo Diesel so when it was finished I did everything possible to upgrade the cooling system. A Super Cool radiator, high quality electric pusher fan, Shellzone coolant and Redline Water Wetter additive. The claim by surfactant additive manufacturers is that they eliminate cavitation.
dienst1 is offline   Reply With Quote
Isuzu Turbo Diesel Fred Airstream Motorhome Forums 15 11-05-2018 05:19 PM
Poll: Isuzu Diesel MH - Would you do it again? ViewRVs Mechanics Corner - Engines, Transmission & More... 4 08-14-2013 01:51 PM
Isuzu Diesel dienst1 Mechanics Corner - Engines, Transmission & More... 3 11-15-2003 01:40 PM
Isuzu Diesel fan shroud dienst1 Mechanics Corner - Engines, Transmission & More... 3 08-14-2003 09:18 PM
1981 Isuzu Diesel Engine jpurdy Mechanics Corner - Engines, Transmission & More... 10 11-30-2002 10:14 AM
