Originally Posted by Lido&Linda
what is a good source for a new or rebuillt carbuator. mine wont allow fuel to enter the bowl.
Hi there guys!
First of all, can you quantify the statement above?
We need more info to offer solutions that might be cheaper and easier than replacing the carb.
I mean, that there are many reasons why fuel is not delivered to the carb.
1/ Insufficient fuel in the tank. Dont believe the gauge!
2/ Blocked tank vent, or loss of pump prime due to a cracked supply pipe.
3/ Rear electric fuel pump is missing/broken/electrical supply failed.
4/ Blocked fuel filter... FYI, my '84 345 has 3 inline. One by the rear electric pump, one on the chassis rail by the step, one on top of the intake, and one inside the carb!
5/ Failed mechanical fuel pump.
6/ Failed float valve inlet, or float stuck.
7/ Blocked internal passage in carb.
Now, if the Carb is old, aged and worn out that is a reason to replace it, but #1 thru 5 are not the carbs fault!
Should a carb be on your list, and I am going thru this at the moment, despite the fact I rebuilt mine, I am not happy/secure I did it right, as its still running odd.
I have selected my Guru, Cliff Ruggles of Cliffs Performance.
He is building my Carb as I wrote this.
He has the has the reputation, and literally wrote the book on Quadrajets!
https://www.amazon.com/Rebuild-Modif...=cliff+ruggles
Find him here:
http://www.cliffshighperformance.com/
