08-06-2017, 01:06 PM
Undereducated AS Newbie
1989 34.5' Airstream 345
Charlotte
, North Carolina
Broken Starter Housing
As you can see by the pictures, I have a significant starter issue.
Parts house guy says motor locked up, mechanic next door agrees.
I'd never experienced this problem, got my pull handle & 3/4 deep well socket & turned the front crank (clockwise) a turn or two.
If crank turns, the motor isn't locked up...so...what caused this?
I'd rather not replace more than 1 starter.
Your ideas/suggestions are appreciated.
08-06-2017, 01:22 PM
Richmond
, Kentucky
It's possible the starter wasn't shimmed properly during installation.
Did the engine backfire while trying to start it?
1975 24' Argosy Motor Home
08-06-2017, 01:33 PM
2009 27' FB Flying Cloud
1982 31' International
1991 35' Airstream 350
Jay
, Oklahoma
I would agree with the backfire question.
Also wonder about a low battery voltage during crank (slower then normal crank speed) and when the engine started the bendix gear hung in the flywheel.
Regards,
JD
Jeff & Cindy
'09 27FB Flying Cloud;'82 31 International
'91 350 LE MH; '21 Interstate 24GT
08-06-2017, 02:33 PM
Charlotte
, North Carolina
No backfires, newly installed rebuilt Quadrajet. Had moved it to an exit from the storage lot, shut it off & went home for dinner. Came back to move it, cranked it, stopped (still getting used to pump the accelerator to set the choke) & resumed cranking after 20-30 second delay, the starter was broken then or just before as all I heard was the gear spinning without contact.
08-06-2017, 02:48 PM
Charlotte
, North Carolina
How would you determine the difference between slow & normal cranking speed?
08-06-2017, 03:07 PM
Jay
, Oklahoma
Did it sound like starter was cranking hard and normal, or like the batteries were low and about to die?
Several things going on here:
Had engine run with new carb?
Did the engine cough or try to fire during initial crank?
What normally breaks the end of the starter is either misalignment of the starter on the bell housing, kick back from the engine during cranking, or bendix hung after engine starts.
Regards,
JD
Jeff & Cindy
08-06-2017, 03:17 PM
1981 31' Excella II
New Market
, Alabama
Go to AutoZone and get a lifetime rebuilt starter and see if that fixes it. Is the shaft on the starter also bent? A backfire could have caused this but I would think you would see other stuff bent as well. Could it have hydrolocked from fuel or water in the cylinders? I assume you drive this often and it is not something you found in a field?
Perry
08-06-2017, 09:59 PM
1973 31' Sovereign
Middletown
I would second the Auto Zone starter and make sure you have the right bolts that are knurled for good alignment. Also GM put that brace that goes from the rear end of the starter to the block for a reason. If it's missing (and it usually is) get a new one soon. Were the bolts tight when you took the starter off?
08-07-2017, 01:17 AM
Charlotte
, North Carolina
Had cranked right up 3 times after installing the rebuilt carb.
Had engine run with new carb? 4-5 minutes each time above.
Did the engine cough (NO) or try to fire during initial crank (no issues).
Bought & installed a reman Carquest Limited Lifetime warranty. Cranked, fired & started after 10 seconds.
We're running again...
08-07-2017, 05:50 AM
Charlotte
, North Carolina
R terminal wire
Looked up Youtube GM starter wiring. Shows a wire to the "R" terminal, my starter had the battery wire, a 12G wire to the "S" terminal and a 6G ground wire to a starter mounting bolt. Is there a need for the R terminal wire?
08-07-2017, 07:05 AM
Richmond
, Kentucky
No, it's not used.
08-19-2017, 10:36 AM
Charlotte
, North Carolina
Didn't have the brace, did have the knurled bolts & yes, the bolts were tight (probably 50-60 ft-lbs).
Where can I get the brace?
08-19-2017, 10:53 AM
1984 27' Airstream 270
Scotia
, New York
I have never seen a rear brace on any of my 454 Motorhomes.
Never had a starter housing crack either
08-19-2017, 11:04 AM
2023 30' Flying Cloud
Garden City
, Alabama
6.2 and 6.5 diesels used a starter brace. Might can adapt one. Being your starter has staggered mounting bolts I wouldn't worry about a brace. Only time I've ever broke the nose was the engine kicking back.
08-20-2017, 12:48 PM
1973 31' Sovereign
Middletown
Always gone...
You might notice that the top bolt that holds the starter motor together has an extension stud sticking out. There is usually a nub cast on the block with a threaded hole that is even with where that stud ends up. The brace is a stamped slightly curved angle iron piece about 4" long and I don't think they have them at Chevy dealers for some reason. I've found them laying on the ground at junkyards in the GM section. I think about every older GM V8 had them from the factory. I always wondered why that stud was there on the starters until one day I changed the starter on something that still had the original starter, and there was that bracket! I guarantee GM didn't spend the extra 50 cents per vehicle for no reason, but they always get left off when the starter gets changed the first time. I wouldn't worry too much about it but if you stumble across one or keep breaking starters you could put one on.
08-20-2017, 12:58 PM
Richmond
, Kentucky
This looks like the starter brace on my 454 powered Argosy.
08-20-2017, 08:27 PM
1987 32.5' Airstream 325
Windsor
, Ontario
I cracked mine trying to start with low voltage on my battery. Just barely cranking and "snap", new unit to boot.
Chris
08-20-2017, 11:09 PM
1973 31' Sovereign
Middletown
Yep that be it! Hey realprank did your starter have the brace on when it broke? I'd say the end brace adds quite a bit of support but there is a heck of a lot of engines where they are missing and generally every things fine for a long time if the bolts are tight.. To me breaking the snout is a pretty rare thing and could be from a few different causes such as a thin casting or loose bolts but there were some blocks made where you need to shim the starter out to get proper tooth depth. If I broke a snout I'd check the tooth fit. I always put all the bolts and brackets back on too!
08-22-2017, 06:33 AM
Windsor
, Ontario
No i don't think it did have the brace, pretty darned surprised, I had never seen it but the rebuild shop said he sees them from time to time. That's a big-ass motor
Thread |
Thread Starter |
Forum |
Replies |
Last Post |
Why do I carry a spare starter?
PeterH-350LE |
Mechanics Corner - Engines, Transmission & More... |
32 |
12-02-2009 05:39 AM |
Help - starter solenoid
ViewRVs |
23 |
02-27-2004 07:58 PM |
Portable Jump Starter
joshua32064 |
Batteries, Univolts, Converters & Inverters |
6 |
10-12-2003 12:13 PM |
Starter heat problems
ALANSD |
0 |
02-15-2003 02:51 PM |
Ode to a starter
ALANSD |
9 |
01-07-2003 10:55 AM |
