Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Motorhome Forums > Mechanics Corner - Engines, Transmission & More...
Old 08-06-2009, 04:59 PM   #1
Auretrvr's Avatar
Iowa City , Iowa
Broken Shock Bracket on Lower Control Arm
1983 Airstream 310 Motor Home: I think the front passenger side shock must have froze, or else there was one large pothole I never saw.
Now I'm looking for a lower control arm -- the shock bracket broke in two and broke off the control arm.
I've found on listed for 'all' P30 chassis but it says they are for vehicles with front disk and rear drum brakes. I haven't found anything for RV's.
Anyone know of a parts source for something like this?
Thanks!
Airstream OCD...there is no cure!
1983 Classic 310 Motorhome.
AIR 15765
Auretrvr is offline   Reply With Quote
Old 08-06-2009, 07:54 PM   #2
SteveH's Avatar
Common Sense , Texas
Of course I haven't seen it, but wouldn't it be easier to just weld it back together?
Old 08-07-2009, 09:16 AM   #3
Auretrvr's Avatar
Iowa City , Iowa
The bracket is broken in two as well as broken off the arm; I'll ask the shop if they would do this. Hate to let anyone get too close to the air bags with a torch, and also I wonder if there's an issue about welding on a piece that might be tempered. Thanks for you suggestion--I will follow up on that option.
AIR 15765
Old 08-13-2009, 08:10 PM   #4
GlenCoombe's Avatar
1984 28' Funeral Coach
Belleview , Florida
Images: 27
Try Millsupply.com and the step van catalog. They've been a great resource for all things P30.
Glen Coombe AIR #8416
Former Rolling Showroom & PuttLab (now party bus)
"I'm not an expert. But I did sleep in an Airstream last night."
GlenCoombe is offline   Reply With Quote
Old 08-15-2009, 06:15 AM   #5
Auretrvr's Avatar
Iowa City , Iowa
That was easy...
Guess I was a worry wort. The suspension guy said he could just weld it back on, and I was out $25 and on the road half an hour later.
A lot less of a problem than I thought, and shows how important it is to ask for advice!
AIR 15765
shocks, suspension
Rats, broken shock mount dbj216 Shocks 7 07-04-2009 05:01 AM
3 out of 4 Broken Shock Mounts? Lookinghard Shocks 8 04-14-2006 09:08 PM
Broken rear upper shock mount Robfike Mechanics Corner - Engines, Transmission & More... 7 02-27-2006 08:06 PM
Broken shock absorber stud jasper2222 Axles 7 01-31-2005 06:34 PM
