Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Motorhome Forums > Mechanics Corner - Engines, Transmission & More...
Old 02-27-2006, 02:59 PM   #1
Robfike
Robfike's Avatar
Profile:  Speedway , Indiana
Broken rear upper shock mount
I just found that I have a right rear upper shock mount stud broken.
Before our Florida trip, I had a new set of Bilsteins installed. The shock is not damaged, but I need to know how everyone is fixing this problem.
The stud failed, and the web on the frame looks ok.
Thanks, Rob
Robfike is offline   Reply With Quote
Old 02-27-2006, 04:01 PM   #2
overlander63
overlander63's Avatar
Profile:  1974 31' Sovereign
soon to be , on the move again
Images: 58
MotorMite makes a replacement shock stud in their Help! line. You will need to drill a hole where the old stud was mounted, insert the replacement, and tighten the nut on the back of it. I make it sound a little easier than it is, but it isn't tough, maybe an hour and a half job, including R&R that tire/wheel.
Change is inevitable, except from a vending machine
AIR#2611
overlander63 is online now   Reply With Quote
Old 02-27-2006, 04:18 PM   #3
guy99
guy99's Avatar
Profile:  Dunsmuir , California
Images: 16
When I was shopping for Bilsteins, I came across a reference that said you need to weld a new shock mount on the P30 chassis to fit Bilstein's on the rear. No such requirement for the fronts.
Did you do that? If not, I wonder if that is somehow the cause of your problem.
1984 310 Limited Motorhome
guy99 is offline   Reply With Quote
Old 02-27-2006, 04:49 PM   #4
Robfike
Robfike's Avatar
The guys that installed the shocks just bolted them on. No changes were made to the mounts.
Old 02-27-2006, 05:00 PM   #5
Zeppelinium
Zeppelinium's Avatar
Profile:  1970 18' Caravel
1977 23' Safari
1975 31' Sovereign
Palmer Lake , Colorado
I'm getting a new axle from Axis, should arrive in two weeks. One thing that puzzled me was that they don't have a suitable shock stud. I couldn't tell whether that was because they were trying to match the original Airstream stud or what. They are putting on the bracket for a horizontal shock and I have a pair of 555003 (hmm, is that right?--close) shocks in a box waiting for the axle change. Any insight on this would be greatly appreciated:
1. If I find the right size bolt, can you just put the bolt through the bracket hole and the shock, then tighten the nut? Would that wobble too much and does that mean the stud/bolt has to be welded?
2. What is the right size and does it have to be a bolt/stud with a long threadless shank?
thanks, Roger
Current 6-word memoir: Vintage Airstreams: Four are not enough.
www.mindseyephoto.com www.airstreamdoctor.com
Old 02-27-2006, 05:49 PM   #6
guy99
guy99's Avatar
Images: 16
Rob,
Here's an old thread about Bilstein's. You'll see that I'm not the only one who noticed that you need modified mounts for the rear.
Good luck.
Guy
Old 02-27-2006, 06:02 PM   #7
markdoane
Profile:  , Minnesota
Images: 59
Originally Posted by 3isnotenough
They are putting on the bracket for a horizontal shock and I have a pair of 555003 (hmm, is that right?--close) shocks in a box waiting for the axle change. . . .
thanks, Roger
Roger,
Those shocks have a 5/8" x 1 5/16" loop end. Monroe makes a 'Trailer retrofit' kit which has the correct studs and parts to do this installation.
Here is the website:
http://www.monroeheavyduty.com/monro...e=retrofit_kit
Non-contributing deadbeat.
Old 02-27-2006, 08:06 PM   #8
shadejo
Profile:  Ottawa , Ontario
Rob, the broken upper mount is a common problem on the P30 chassis, and is made even more likely with Bilsteins. I had a broken one on my 345 when I bought it last year. While clearance is a nuisance, I drilled out the remains of the stud, drilled through the chassis bracket with a 1/2 inch drill, enlarged the hole to 5/8inch with a die grinder (didn't have a big enough drill or drill bit) and then replaced the stud with a good quality bolt and a couple of washers to space the shock away from the bracket. Tightening it up was potentially a nuisance as the nut is on the inside of the bracket, but if need be I was prepared to bend a wrench to shape.
It is not the most pleasant job to tackle as I found I could not adequately use the drill from the wheel side and had to lie underneath the rig (suitably blocked and safety standed - you do not want that 10,000 pound rear end to fall on you !). If you can access a ready made kit to replace the stud, so much the better, but I found that the 5/8 bolt soution was quite adequate and have travelled several thousand miles since the repair.
Good luck, whatever route you go!
John
shadejo is offline   Reply With Quote
Saggy Bottom ( rear end ) smily Repairing/Replacing Floor &/or Frame 127 10-01-2006 08:28 PM
bike rack mount on rear of AS trailer rmmm68 Repairing/Replacing Floor &/or Frame 7 11-26-2002 10:55 AM
63 TW shock Moonshot Shocks 5 08-26-2002 09:24 AM
Old CB ball mount davidz71 Phone, CB & Ham Radio 2 05-28-2002 06:54 PM
Cooking Forum - Sailing Forum - Early Retirement - Airstream Trailer - Aquarium Forum - Royal Forum - Book Forum - Yoga Forum - Volkswagen Touareg Forum - Jeep Wrangler Forum - Whitewater Kayaking & Rafting Forum - Fiberglass RV Forum - U2 Forum
