Old 05-17-2006, 09:00 PM   #1
outofcontrol's Avatar
1996 28' Excella
Portland , Oregon
Brakes pull left
1981 AS Excella 280 Motorhome, 454 chevy motor, P30 Chassis, 60k mi.
When I apply the brakes the coach pulls to the left. When I visually inspected the front end, I noticed several things wrong, so I decided to fix them all, and see if it corrected the problem.
1. The front swaybar bushings were ruptured/broken/old, and almost gone on the left side, so I replaced them.
2. The LF airbag leaked, so I replaced the set (what a PITA).
3. I thought it might be the shocks, so I replaced them (bilstiens).
4. The only thing left I see is a leak from the hydroboost to the brakes? I'm not real familiar...well I don't know anything about this system, except what I've read here--I do know not to tighten the belt using the pump body .
I'm not sure if a leak would make the brakes pull one direction?
I'm going to fix the leak anyway, but I'm going to need some help with ideas on where to look next.
Ball joints? Bleed the brake lines? Take it to a Mechanic? Something loose?
I have pulled the wheels off, and everything looks ok; the pads are good, the rotors look fine, there's no oil squirting on the rotors. I kind of expected to see something obvious.
It also seems like you have to put a lot of foot into the pedal to get the coach to stop. I drove trucks for 12 years (all air brakes) and the feel seems really heavy- granted I have nothing to compare it with.
My goal is to have the brakes work well enough to let my wife drive, and right now I wouldn't let anyone drive it. I've spent several hours reading posts here, but nothing specific about brakes pulling. What makes this happen?
Thanks in advance!! I've owned this RV for 3 weeks now, and I've spent 3 awesome weekends in it.
-Kevin
1996 Airstream Excella 28'
2007 GMC Duramax 4x4 CCSB
outofcontrol is offline   Reply With Quote
Old 05-17-2006, 10:40 PM   #2
wkerfoot's Avatar
1979 23' Safari
1954 29' Liner
Orange , California
OutofControl.
Could be a sticking caliper on the right side. Which is not engaging.
Bill
Just my personal opinion
Old 05-18-2006, 12:25 AM   #3
1960 24' Tradewind
santa barbara , California
one of the most common troubles are the front brake hoses.Interestingly I am replacing a set for a customer with the same type chassis but sob .They close up from deterioration from the inside and then ,and usually one side more than the other does not release completely ,as the brakes are applied that calipar will grab more than the other,your trouble sounds like a calipar problem,one is most likely not applying very well while the other is clamping the rotor,you will get a pull to the side that is doing the most work.Given the wear and tear your coach had with the front end ,I would recommend replacing the calipars and the hoses together and both sides.I have serviced this type of problem many times with the gm p-30 or the c -30 trucks.This is more common on a motor home which is not used often .Sitting idle these coaches require more attention with most of the systems or mechanicals.
Scott
scottanlily is offline   Reply With Quote
Old 05-18-2006, 09:36 AM   #4
1996 28' Excella
Portland , Oregon
Thank you for the ideas!
I spent the night reading on the internet, and I saw "collapsed rubber hoses" several times. Some suggest adjusting the rear brakes - hadn't thought of that- could have an effect. Another idea is to flush the fluid. It turns to water over time, and rusts internals/performs poorly. And sticky calipers.
I'm going to replace the rubber hoses, flush the fluid, and look into the calipers. I would guess there are re-build kits available instead of replacing the whole caliper? I've done this stuff 20 over on motorcycles, but this is my first RV...
Just went to the NAPA website- I can buy remanufactured calipers for $45-60 with new pads and hardware. That doesn't sound too bad. I was thinking $200. Looks like I'll have to turn the rotors if I'm putting new pads in. Re-pack/inspect the bearings while I'm at it... Just regular maintainence right?
-Kevin
Old 05-18-2006, 09:44 AM   #5
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
You are right about brake fluid, it absorbs moisture and needs to be changed because of that.
1966 overlander..sold
AIR #005
OUR AIRSTREAM PASSION! BLOG
RESTORING AN AIRSTREAM
retired!
Old 05-18-2006, 01:09 PM   #6
1996 28' Excella
Portland , Oregon
I bought the service manual and the owner's manual from AS, and niether say much about the brakes.
I need to know if I have GM JB7 or JB8 calipers, and if the hydroboost is 8,500 psi or 10,000 psi.
I think I need to find a service manual for the chassis if I keep running into these issues.
Thanks guys!
-Kevin
Old 05-18-2006, 04:57 PM   #7
Well Preserved
overlander63's Avatar
1993 21' Sovereign
Colfax , North Carolina
Okay, pull to the left while braking could be:
Left lower ball joint
Left inner or outer tie rod end
collapsed right front brake hose
stuck right caliper
worn or sticking hardware (caliper slides)
misadjusted front wheel bearings
misadjusted rear brake shoes
lower control arm bushings
Old 05-18-2006, 05:08 PM   #8
noiva's Avatar
Chesapeake , Virginia
Images: 46
stuck right caliper
I agree absolutely with Overlander. However, I did have a problem that caused the same issue. The outer rear axle seal was leaking into the brake housing. A new seal, and new set of pads cured the pulling, and gave me much better braking as well.
Tim
1987 30P
2003 Suburban 2500
AIR # 5648
noiva is offline   Reply With Quote
Old 05-18-2006, 10:39 PM   #9
1960 24' Tradewind
Replace the calipers and the hoses,flush the lines with fresh fluid ,getting the rotors turned gives you the chance to repack/replace wheel bearings.You mentioned braking effort was higher than normal to stop the coach,so check the rear brakes as well ,the rear hub seals leak oil onto everything eliminating stopping power there,very common on GM 30 series 1 ton chassis.Always make certain the rear differential fluid is full ,especially after rear brake service where there has been fliud leaking for awhile ,low fluid level in the Gm 14bolt corporate rear axle causes bearing failures at the outer wheel bearings and the rear differential bearings as well .You would be surprised how often the assumption that the level is ok without it actually being checked.
Good luck with your repairs.
Scott
Old 05-19-2006, 06:09 AM   #10
Chaplain Kent's Avatar
1994 30' Excella
Milwaukee , Wisconsin
This does not help your problem but I just have to tell the story. On our way down to the Spring Fling Rally in Georgia I had a brake lock up outside of Chattanooga. I thought it would be OK but when we left the park in Georgia it began to squeal and I was sacred in the mountains. We stopped at the Wal Mart in Elijah, GA and they sent us to Payless Auto out in the country. Here I am a Northern guy who can barely speak the language with a motor home that is in desperate need of brakes. I squeal into his lot and the guy says it will be about an hour before he can look at it. We make lunch and prepare for the worse.
When it was our turn he confirmed we needed new front brakes. He goes to the phone dials and then walks to his back shelf and starts to pull off boxes of parts. He had everything in stock! If you think I was surprised he was shocked. One hour later Chummy had all new front brakes. Now it was time to pay the bill. I felt like Chevy Chase in Summer Vacation- open the wallet and give it all. He totals the bill and hands it over. $125.99. I think I will drive down to Elijah, GA for all of my service work from now on.
Chaplain Kent
2015 Coachman Freedom Express 19RBS, Chummy IV- Ford Excursion- 7.3 Turbo-diesel
Chaplain Kent is offline   Reply With Quote
Old 05-19-2006, 06:18 AM   #11
noiva's Avatar
Images: 46
Chaplain Kent,
I told you to move down south, learn the accent, and you'll live so much better ! Look at all the "cheap" fixes I've found for the Silver Blimp (a.k.a.) 1989 370LE .
Best,
Tim
1987 30P
2003 Suburban 2500
AIR # 5648
Old 05-19-2006, 08:18 AM   #12
On my truck, a violent pull to the left was caused by a rotor that needed replacing.There was no obvious visual sign. On the last three occasions I have carried out a major service on my various vehicles' brakes, I have fitted new rotors, rather than having them skimmed. Rotors are one item on vehicles that seem very low in price, so I would recommend new rotors, rather than skimming them. I just looked up a new rotor for a Ford Crown Vic, and it was $20, as an example.
Nick.
Nick Crowhurst, Excella 25 1988, Dodge Ram 2500 Cummins Diesel. England in summer, USA in winter.
"The price of freedom is eternal maintenance."
nickcrowhurst is offline   Reply With Quote
Old 05-19-2006, 10:06 AM   #13
RivetAddict
swebster's Avatar
1986 34.5' Airstream 345
Louisville , Kentucky
Hey, I resemble that remark.
Everything you're looking into replacing is a good idea anyway and as you are finding out - parts are pretty cheap for the P30. Sounds like a front end rebuild is a good idea.
On the type of brakes, I'm pretty sure it's the JB7 - but the chassis VIN (not the Airstream serial number) will tell you which system you have for sure. Call a GM truck dealer, tell then you need a price on calipers and a hydroboost and give them your VIN and ask them which system you have for your records.
On that Hydroboost leak you mentioned, which line is leaking? The pump itself provides hydraulic pressure to the hydroboost unit bolted to the frame. There is a high pressure line from the back of the pump into the unit. The master cylinder bolts to the back of the fixed unit and receives it's "boost" from the unit itself.
There is another high pressure line which goes from the unit to the power steering gear (boost for steering). There are then low pressure line (larger hoses with band clamps) which return the fluid back to the pump from the steering and brake systems.
If the low pressure sides are leaking (or weeping) it's not hyper critical and new hoses and clamps will quickly fix it, if it's high pressure then you'll notice hard pedal effort, steering effort, loss of large quantities of fluid etc.
No matter the cause of the leak I doubt it will cause more breaking on one side over the other.
stuck right caliper
Lastly, Terry's advice has always helped me when troubleshooting issues on my motorhome. I think his list is right on target.
Steven Webster
1986 Airstream 345 Classic Motorhome
AIR 1760
swebster is offline   Reply With Quote
Old 05-19-2006, 03:18 PM   #14
1996 28' Excella
Portland , Oregon
First off... You guys are the greatest. Your ideas are right on point!
So I thought about it more, and I decided to start with the cheap stuff first, and keep going until I fixed the problem, or I found something obvious. I pulled off the left side brake hose and took it with me to NAPA. They only had the right side in stock, so I bought it, because I want to replace both anyway. I came home and decided to work on the right side while I waited for the L to come in tomorrow.
On the R side, I cracked open the line on one end of the hose, and no fluid leaked out. Hmmm
I removed the rest of the line and held it over my drip pan, still no fluid. Hmmmm.
I put some compressed air on the MC side, (125psi) and nothing.
With air on the caliper end, I got it to start weeping out with a couple glugs.
Seems to point toward a clogged/corroded/ruptured hose on the right side causing weak braking and a pull left.
Tonight Iíll install the right side hose, bleed the system, and go for a test. I donít want to get my hopes up too much, but at least I think I found a problem.
The hose leaking off the hydroboost was a return line, and it was cracked all over, especially on the ends. It was like 40 cents + some clamps for that one.
Overlander,
Your list is spot on. I'm going to cruise down it until I find the problem. Are the "Lower Control Arm Bushings" the same as what I would call the "sway-bar bushings"? I'm not a truck/car guy. Motorcycles are my forte.
Thanks again!
-Kevin
Grabbing Brakes 74Tradewind Brakes & Brake Controllers 15 08-05-2004 05:26 PM
problem with Brakes jazzbone Brakes & Brake Controllers 33 08-23-2002 07:05 AM
Disc Brakes? J.Hemingway Brakes & Brake Controllers 2 08-22-2002 07:56 PM
Heeeelp! My brakes have failed...anyone have a similar experience? williamhenshall Airstream Motorhome Forums 9 07-12-2002 03:04 PM
Strange noise?? Univolt?? Brakes?? rroessler General Repair Forum 2 06-22-2002 04:41 PM
