Old 03-25-2004, 03:51 PM   #1
josephhh's Avatar
1979 24' Airstream Excella 24
Macon , Georgia
Brake Seizure - Front Right Side
Hey folks,
After having completely rebuilding the caliper piston assembly, the right front brake is still dragging on my '79 motorhome. I drove it a 4 miles last evening and the wheel was smokin hot when I got home. Someone said that if a unit sits too long, rubber brake flex lines can sometimes let fliud go TO the brake and then NOT let it return FROM. Hence the lock up. I was told the fix is replaceing the flex line.
So, I am trying to do that as a next attempt and the NAPA guy says I need to know the size of the REAR brakes in order for him to match up the correct FRONT brake hose.
Can anyone shed some light here? Where do I look up brake sizes? Or better yet, what's the part number for the brake line I need?
Unit is '79 24' Excella 454.
Joe
josephhh is offline   Reply With Quote
Old 03-25-2004, 04:07 PM   #2
Take the hose to the store. Size (of hose) shouldn't matter. This is a common problem and should go away with the new hoses. Do both.
fangthorpe is offline   Reply With Quote
Old 03-25-2004, 04:10 PM   #3
josephhh's Avatar
Macon , Georgia
I'll do that. Glad to hear the hose can fix it.
My picture looks pretty good if you stand about 50 feet back from your computer screen.
Joe
Old 03-25-2004, 04:41 PM   #4
wb13798's Avatar
2004 28' Classic
huntsville , Alabama
i got my hose from napa and that was my problem. but i would change both. left and right . will cost about $50 for the hoses.
if napa doesn't have them go to oreily. do a good bleed job after you get the hose replaced front and rear.
i ruined a tire when mine locked up. better check the tire also.
AL
2007 chevrolet 2500 duramax 6.6
allison 6 speed
2004 classic 28 WB , Pro Pride P-3 hitch
centramatics wheel ballancers 300-556
wb13798 is offline   Reply With Quote
Old 03-25-2004, 04:48 PM   #5
wb13798's Avatar
2004 28' Classic
re read your post you need to find a new parts store . the guy doesn't know what he is talking about. make sure the end that bolts to the caliper is the same as the old one. the only question would be drum brakes or rear disk brakes.
napa couldn't match up my rear lines. i was going to replace those also haven't found the correct line yet, but i stopped looking.
AL
allison 6 speed
Old 03-25-2004, 05:03 PM   #6
josephhh's Avatar
Macon , Georgia
I was just out under it looking for the obvious disconnect points but they weren't obvious.
On the caliper end, the rubber hose crimps onto a short metal hose that ends in a little square thing on top of the caliper with a bolt going down into it. Is that the bolt I need to loosen to free the caliper end?
On the other end, I see a nut on top of the mounting point and a thin nut below the mounting point. The upper, big nut looks to be the one to loosen. Do I need to hold the lower one while cranking on the upper one?
jc
Old 03-25-2004, 05:08 PM   #7
davidz71's Avatar
1986 25' Sovereign
Southern Middle , Tennessee
That reminds me, I have an eye doctor appointment next week. Maybe he should see me earlier.
Craig
AIR #0078
3.73 rear end
Mag-Hytec rear diff cover
Amsoil synthetics all around
Old 03-25-2004, 05:16 PM   #8
josephhh's Avatar
Macon , Georgia
Can you read the letters at the top of the picture?
Old 03-25-2004, 06:08 PM   #9
whistler's Avatar
Joe
Never worked on a motorhome, but service brakes all the time. Yes the bolt goes through the end of the hose into the caliper, that bolt needs to be removed. When you remove it you will see that it has 2 copper washers on each side of the hose. These are very important washers, they should be replaced and should come with the new hoses. These washer provide a seal on each side of the brake hose, without them you will have a leak. On the other end the larger nut should be part of the brake hose, the smaller nut should be on the metal line running to the master cylinder. Hold the large nut and turn the smaller one, be careful not to twist the metal line off. If the line is rusted, soak it with penetrating oil. Good luck.
whistler
whistler is offline   Reply With Quote
Old 03-25-2004, 06:19 PM   #10
wb13798's Avatar
2004 28' Classic
yes you remove the bolt that threads into the caliper. that is a castle bolt. on the upper end it is mounted to the frame and the steel hard line has a fitting that screws into the flex line. the flex line is secured sometimes with a bolt but most cases with a clip.
remove the clip or nut first . and yes with two wrenches. then force the hard line thru the frame mount and put a line wrench on the nut that is on the steel line, so you don't screw it up. you can use what ever you want on the old flex line just so you get it removed. the new flex line should be identical to what you take off. especially the hole for the castle bolt , should be the same size. you will have a bolt (1/4 20) holding the flex line to the rocker arm . got to remove that nut and bolt and be sure to put it back, it is a pain in the back to do. unless you have small hands , i got paws. of course put it all back like it was. do not over tighten the bolt that goes in to the caliper. good in tight is enough.
AL
allison 6 speed
Old 03-25-2004, 06:21 PM   #11
josephhh's Avatar
Macon , Georgia
Thanks much Whistler. Exactly the details I needed.
And thanks to everybody else.
I'll report back as soon as I have broken the metal lines off.
Joe
Old 03-25-2004, 06:21 PM   #12
wb13798's Avatar
2004 28' Classic
dont forget the copper washers use the new ones you get with the new hose. in worse case use the old ones. gotta have them.
AL
allison 6 speed
Old 03-25-2004, 06:24 PM   #13
josephhh's Avatar
Macon , Georgia
Oops. I missed your note there Al & Sue. Thank you also for the tech advice. I'll let it all soak in Liquid Wrench for a couple a days and then give it a try.
ThX
joe
Old 03-25-2004, 06:38 PM   #14
wb13798's Avatar
2004 28' Classic
been there done that. be sure to use a line wrench on the hard line.
AL
allison 6 speed
Old 03-25-2004, 06:42 PM   #15
dinoburb's Avatar
1982 34' Limited
Tidewater , Virginia
I think you mean a flare nut wrench. It's designed to loosen the nuts holding brake, fuel and other restricted nuts without rounding them. Very useful tool. It looks similar to a box (closed) end wrench with a small cut-out in front to slip past the offending line. Usually six point gripping surface. Works like a charm.
Hope that helps.
Take care
Old trucks and old trailers . . . a comfortable combination!
AIR 1446
W5CDR
A-6E All Weather Attack Driver, BUFF
USN Aircraft Maintenance Officer, Ret.
'91 Suburban R-2500 w/BBC
'78 Honda GL-1000
'72 Triumph T-100R Daytona
dinoburb is offline   Reply With Quote
Old 03-26-2004, 10:15 AM   #16
wb13798's Avatar
2004 28' Classic
napa call s them line wrench s. i call them flare nut wrenches also. he was going to napa to get his parts, didnt want to confuse the parts guy. it is a small steel nut and the steel is soft.
i think 7/16s ??? been a while. need too get to the motor on mine .
AL
allison 6 speed
