Old 09-27-2009, 06:57 AM   #1
IPM
1996 clipper gas 34'
Blue Springs , Missouri
Brake pedal travel and side pull
FYI for all. Like others, I have had good brakes but some curiosity about the lengthy brake pedal travel for my motor home. The master cylinder on mine had been replaced by the previous owner. But I pondered if he had used the wrong unit, such as one with a smaller diameter bore. I also questioned the condition of the rubber brake lines. So I replaced the master with a new correct cardone unit and all 5 rubber brake lines with bendix brand parts. Had to replace the metal lines at the rear axle as well since they would not separate from the rear caliper hoses. Pedal travel is now less. No more brake pull to one side as well. And Pedal is firmer with application of brakes. Successful repair! Bought my master and rubber lines from rock auto online. Parts ordered were:
CARDONE SELECT Part #131668
BENDIX Part #77548
BENDIX Part #77549
BENDIX Part #77330
BENDIX Part #77329
BENDIX Part #88651
The bendix parts are the rubber hoses. They all had tabs that I had to grind off the point were the steel head of each hose rests in the chassis (tab that holds connection/union of hose to steel line). Mine is circular with no locating tab. Was no big deal took couple of seconds for each. The replacement metal brake lines I used at the rear axle was generic replacement line from the local auto parts. Oh, and my rig is an '81 excella 28 with a 454, disc brakes at all 4 wheels stock and of course the hydroboost.
IPM is offline   Reply With Quote
Brake controller side by side comparison Boondocker Brakes & Brake Controllers 4 10-17-2007 12:05 PM
Having brake pedal issues and may need rotors SilverToy Brakes & Brake Controllers 10 06-25-2007 04:43 PM
Brake Pedal Stuck To Floor Chaplain Kent Mechanics Corner - Engines, Transmission & More... 14 09-24-2006 12:03 PM
1986 345 AS MH Brake Pedal Travel Jim Tyrney Mechanics Corner - Engines, Transmission & More... 8 04-03-2004 04:47 PM
Brake Pedal Supposed To Be HARD? fangthorpe Airstream Motorhome Forums 8 11-29-2003 01:10 PM
