Old 01-05-2006, 04:12 PM   #1
Robfike's Avatar
1999 36' Land Yacht Widebody
Spencer , Indiana
Brake master cylinder install
Today I got to be intimate with my master cylinder. Sometimes things really can go good, and today was one of those days. The stars must be alligned somewhere.
I started the project 2 days ago by drounding everthing that needed to come apart with PB Blaster. Today all the bolts, and line nuts came apart without much drama. All I can say is that this could have been a real drag without the help from all of you other Airstreamers. The job took about 4.5 hours, and that included taking the old MC to match up to the new one.
While I was in there, I replaced the questionable oil pressure sender for the guage. Now the coach does not have a spot of brake fluid under it, and the oil pressure does not "peg". I have 55psi oil pressure at idle, and just a little higher with RPM.
Special thanks to Steven!
Later, Rob
Robfike is offline   Reply With Quote
Old 01-08-2006, 08:37 PM   #2
RivetAddict
swebster's Avatar
1986 34.5' Airstream 345
Louisville , Kentucky
Way to go Rob. It's nice when everything goes well.
Steven Webster
1986 Airstream 345 Classic Motorhome
AIR 1760
swebster is offline   Reply With Quote
Brake Controllers smily Brakes & Brake Controllers 6 10-02-2002 06:12 AM
Brake install -INSTALLATION/ADJUSTMENT/WIRING Sharon Lee Brakes & Brake Controllers 10 07-21-2002 07:47 PM
Electric Brake Controller Problem Don Brakes & Brake Controllers 4 04-15-2002 01:05 PM
Hydraulic Brake Replacement DanLyle Brakes & Brake Controllers 2 03-26-2002 05:02 PM
Which brake controller? Andy R Brakes & Brake Controllers 2 03-06-2002 10:11 AM
