Old 04-10-2010, 07:57 PM   #1
JBinKC's Avatar
2007 31' Classic
Kansas City , Missouri
Bottle Jack Maintenance
Friends: My bottle jack failed us this weekend when we needed it to change a flat. After ignoring the little guy for years, he let me down. So I vowed to do the following annual maintenance, which I shamelessly stole from another manufacturer, since my instructions are long gone:
1. Replace the complete hydraulic jack oil at least once per year.
2. Use good hydraulic jack oil, such as Mobil DTE12M or equivalent. Do not mix different types of fluid and never use motor oil or other substitutes.
3. With the saddle fully lowered, remove the oil filler plug.
4. Turn the jack on its side and drain the fluid into a suitable container. Dispose of the fluid responsibly.
5. With the jack upright, fill until oil is level with the filler plug hole. Reinstall oil filler plug.
Iíve vowed to do periodic lubrication by applying a coating of light oil to pivot points, axles and hinges, and to periodically check the pump piston and ram and to wipe it with an oily cloth.
Hope this helps the community. Best wishes, John
JBinKC is offline   Reply With Quote
Stabilizer jack maintenance ostream Jacks, Stabilizers, Lifting and Leveling 16 11-11-2010 07:32 AM
Gravel in a Bottle ...! AIR-Quarius Cleaning, Stripping & Polishing 4 04-13-2010 09:58 PM
LP Bottle Size JimGolden LP Gas, Piping, Tanks & Regulators 11 11-20-2005 08:08 PM
propane bottle norbert Our Community 12 08-03-2003 05:36 PM
Gas bottle size skipj Our Community 4 06-30-2003 06:11 PM
