Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Motorhome Forums > Mechanics Corner - Engines, Transmission & More...
Old 04-01-2002, 08:07 PM   #1
1985air345
airstreammotorhomes.com
1985air345's Avatar
Profile:  Charleston , West Virginia
Question Blinking Galley Lights
My galley lights (under the overhead storage bins) have a problem. The set in the center (kitchen and dinette) of the coach blink and go off when on the HIGH setting. They operate fine on the LOW setting. The blinking begins a minute or two after turning them on.
The front set of galley lights (over the sofa and chairs) don't have this problem.
Any suggestions? My only thought was to replace all the bulbs and check the sockets for some kind of debris or short.
Fred H.
No Airstream Anymore..
Fred's Airstream Archives - Motorhomes
Fred's Airstream Archives - Trailers
1985air345 is offline   Reply With Quote
Old 04-01-2002, 08:17 PM   #2
PeterH-79MH
PeterH-79MH's Avatar
Profile:
Images: 63
try changing the fuse. Press fuse holder clamps together, before inserting the new fuse.
PeterH-79MH is offline   Reply With Quote
Old 04-02-2002, 08:09 PM   #3
1985air345
1985air345's Avatar
Are you talking about the 12v distribution panel? I see the Chevy fuse box up front and I know where the breakers are. The only thing left would be the 12v distribution panel under the stove in my 345.
Fred H.
Old 04-02-2002, 08:51 PM   #4
PeterH-79MH
Profile:
Images: 63
yes, the fuse inside the 12 V distribution panel.
you should be able to identify the fuse by temperature. Only turn the lights in question on high, wait a few minutes and feel them. If you have a wiring diagram, you will know which one it is. Should be a SFE 20 amp fuse.
The chevy fuse box has nothing to do with the coaches 12V electrical system.
Old 04-03-2002, 07:37 AM   #5
ALANSD
GA Airstreamer Air_005
Profile:  North , Georgia
My fuses are located under the bed in the rear.
Old 06-23-2002, 05:30 PM   #6
thenewkid64
Just a member
thenewkid64's Avatar
Profile:  Tampa Bay , Florida
Images: 21
Fred,
I think I may have stumbled on the problem with your overhead lights. I pulled my plastic lenses today to fix a bad connection and saw that one of the bulbs was burned out. I pulled it and headed to the parts store. After checking for 20 minutes I realized that the bulb I need looks like an 1156 single filament. But when I compare the two the filament is wider than the one in my hand. Then I remembered that when we had the AS trailer the service manager told me the bulbs are a low wattage type and are not available at the auto parts store. The only marking on the bulb is a W with 93 under it. If you are running 1156 series bulbs you may be drawing to many AMPS. I did find a bulb R10W that seems to throw out the same light but the bulb glass is smaller than the original.
Brett G
WBCCI #5501 AIR # 49
"Stop worrying about the potholes in the road and celebrate the journey." -- Fitzhugh Mullan
Wise men talk because they have someting to say; fools, because they have to say something. -- Plato
In politics, absurdity is not a handicap— Napoleon
Old 06-23-2002, 06:04 PM   #7
Pahaska
Pahaska's Avatar
Profile:  2005 28' Classic
Austin (Hays County) , Texas
Images: 12
Blinking lights
My previous trailer (and all like it) had lights that blinked off when hot. It was apparently a thermal problem in that when the socket expanded with heat, the base of the bulb was lifted off the grommet in the center of the socket. No one ever did find a good fix and a lot of owners swapped out the lamp fixtures for a different type.
If you do happen to have hotter, higher wattage bulbs than original, this could certainly be your problem.
John W. Irwin
2005 Classic 28 "Sabre-Dog III"
2004 Silverado 2500HD Duramax/Allison
WBCCI Region 9 Webmaster, #9632
Old 06-23-2002, 08:42 PM   #8
1985air345
1985air345's Avatar
I was kicking around replacing them with flourescent fixtures if I could find the right size replacement. Right now, the low or high run 12 bulbs total (4 units of 3 bulbs each). Drawing less DC power and creating less heat in the coach would be a plus.
I'll check the bulbs. My notes are in the unit which is not at my house . I used the bulb #'s recomended on the fixture and not the #'s in my 345 manual.
Fred H.
Running Lights Barkingspider Lights - Interior & Exterior 7 12-11-2003 08:48 PM
Rear Indicator Lights Cracker Lights - Interior & Exterior 7 11-03-2003 02:42 PM
Blinking lights 53flyingcloud On The Road... 0 10-26-2003 09:57 PM
running lights mazda997 Electrical - Systems, Generators, Batteries & Solar 0 08-27-2003 08:55 PM
looking for brake lights and back up lights larrylisa Lights - Interior & Exterior 6 12-07-2002 06:43 PM
Cooking Forum - Sailing Forum - Early Retirement - Airstream Trailer - Aquarium Forum - Royal Forum - Book Forum - Yoga Forum - Volkswagen Touareg Forum - Jeep Wrangler Forum - Whitewater Kayaking & Rafting Forum - Fiberglass RV Forum - U2 Forum
