Old 05-25-2008, 05:49 PM   #29
richinny's Avatar
2011 34' Classic
Originally Posted by 85MH325
You might find this interesting:
Roger
i had the same thoughts as the last line of the story. if cars ran on water, how expensive would water become?
Ricky
Old 05-26-2008, 12:15 PM   #30
Skater's Avatar
1995 30' Excella
Bowie , Maryland
Everything I've read in this thread, except for the "better driving habits" comments, is a scam.
The Tornado does absolutely nothing for mileage. The reason it seems to work is that when you put it in you're thinking about mileage, so you drive more gently. The Tornado can do one thing though: if one of those tines were to break off, you'd be out an engine - which is going to offset any increase in mileage you would've gotten if it did work.
The hydrogen thing has been covered already, but let's face it: 1. You're only going to get tiny bits of hydrogen out, and 2. You now have to carry around a bunch of water for the engine's use (I realize us RVers are already usually carrying around water, but you see what I mean). The weight, complexity, and cost of this system will never offset the price you paid for it in terms of fuel usage - especially for a motorhome which doesn't get that many miles to begin with. Even if it does work (which I highly doubt).
Don't even get me started on magnets on the gas line... yes, because magnets have a HUGE effect on non-ferrous materials like gasoline.
Oh, and bottled water is still more expensive than gasoline. Go figure.
1995 Airstream Classic 30' Excella 1000
2014 Ram 2500 Crew Cab with Cummins 6.7L Diesel
Sold but not forgotten: 1991 Airstream B190
Sold: 2006 F-250 6.0L Powerstroke Supercab
Skater is offline   Reply With Quote
Old 06-04-2008, 11:10 AM   #31
Silver Bullet
choctawmel's Avatar
1986 34.5' Airstream 345
choctaw , Oklahoma
I installed a water injector on my 360cid Dodge back in the '80's. Had to use distilled water or the jet would stop up. Never could get it adjusted to work right. Couldn't tell if it helped or not. Not too long after I installed it, it went nuts and shot in too much water at an idle, flowed the engine and bent a couple valves.
choctawmel is offline   Reply With Quote
Old 06-04-2008, 12:25 PM   #32
Tom Nugler's Avatar
1972 25' Tradewind
McHenry County , Illinois
Set the Way-Back Machine to.....
What’s old is new again.
Advertisement from 1947 Science and Mechanics magazine.
Tom.
AirForums # 2806
WBCCI / VAC # 6411
Not All Who Wander Are Lost.
Avid supporter of trailing edge technology.
Tom Nugler is offline   Reply With Quote
Old 06-04-2008, 01:08 PM   #33
Incorrigible
Ike T's Avatar
1976 Argosy 24
-- , Georgia
I might try the "water-via-vacuum-line" or the "injection via smog pump" trick with my Travelall to see if I can improve efficiency. The 345 engine with 1406 Edelbrock carb in the T-all has less than 9:1 compression ratio and rarely spins above 2500k rpm at the speeds I drive (60mph or less). The engine seems like a good candidate for improvement via some of the links posted. I removed all the vacuum lines associated with the emissions system but did not remove the air pump. Just depends if I want to add another thing that might go wrong to a 35 year old truck.
I'll post my findings if I do this.
Tim
1976 24' Argosy
1973 International Harvester Travelette 1210 4x4 'Bernard' 164" WB
1997 Georgie Boy 30' SuperDuty v10
Ike T is offline   Reply With Quote
Old 06-04-2008, 01:25 PM   #34
The Hawk's Lair
cooperhawk's Avatar
1985 34.5' Airstream 345
BACK WOODS , Minnesota
The idea of injecting water into aircraft engines isn't new. The reason for doing it however was not to burn the water as a fuel per se. It was done to increase the mass of the air being drawn into the engine.
The early Boing 707's had water injected engines. We called them "Water wagons". They were so underpowered that water was injected to help them climb. It wasn't the hydrogen they were after, but the oxygen that was available in the water which had a higher density than the thin air of the upper atmosphere.
In other words, they couldn't suck in enough air in the early engines, so they injected water to increase the mass of oxygen. Nowadays, they have solved that problem and no longer have a need to do so.
In the end, you can't create more energy than is already present in the fuel. You can only use it more efficiently.
AKA THE GUNNER
There is no "I" in the word "team," but there are four in "Platitude Quoting Idiot!"
AIRSTREAM 345 TURBO-DIESEL
VFW, LEGION, NRA
cooperhawk is offline   Reply With Quote
Old 06-04-2008, 01:28 PM   #35
Naysayer
Boondocker's Avatar
1968 24' Tradewind
Louisville , earth
Send a message via Yahoo to Boondocker
The things you can learn here.....
Rodney
Visit my photography page
and the
Favorite camp grounds project map
My Blog
(The artist formerly known as General Disarray)
Boondocker is offline   Reply With Quote
Old 06-04-2008, 02:57 PM   #36
ScottW's Avatar
Hernando , Mississippi
Actually, I thought the water injected engines the military used were to turn the water into steam, therefore increasing thrust. Water expands many times (10 or so??) when turned into steam. In thrust we trust!
Rgds,
Scott
Air 16426
Fully retired now!
Remember:
Never start anything before noon and always plan on being finished by 5.
I will never HAVE to be anywhere ever again!
ScottW is offline   Reply With Quote
Old 06-04-2008, 05:12 PM   #37
altamont's Avatar
2007 27' Safari FB SE
Tracy , California
Interesting article in todays Wall Street Journal about mileage increasing products. None of them work but people are still trying to make improvements at any cost. The only thing that really helps are low restriction intakes and exhaust systems.
altamont is offline   Reply With Quote
Old 06-09-2008, 02:44 PM   #38
vswingfield's Avatar
1983 34' Excella
1967 24' Tradewind
Little Rock , Arkansas
Images: 32
The main use I have seen of water injection was on turbocharged engines to allow more boost without pre-ignition issues.
Vaughan
Old 06-09-2008, 05:26 PM   #39
Moderator Emeritus
Pick's Avatar
1972 31' Sovereign
High Springs , Florida
Images: 36
Those HHO devices are a big scam. When you calcuate how many BTU's of hydrogen you would need, versus the amount a mason jar sized hydrogen generator "might" produce, it is very clear that it is a physical impossibility for such a device to work as claimed.
Do a search for HHO or Hydrogen Generators on YouTube. You'll laugh 'til you cry, funnier than watching the comedy channel.
ARS WA8ZYT
Propane Powered Honda EU2000i
Lots of Hot Sauce!
Air # 283
WBCCI 1350
Old 06-09-2008, 06:07 PM   #40
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
Water injection was used during WWII in military aircraft for much the same reason it was used in early jets. They had to be careful with the big radial engines that water didn't pool in the bottom cylinders, hydrolocking the engine. Very bad at 20,000 or more feet in the air when the motor starts shucking internal parts.
Old 06-23-2008, 09:52 AM   #41
345bill's Avatar
Las Vegas , Nevada
I asked these questions as I was having problems cutting through all the hype in finding out which ones are real and work, (if any)which ones are real and kinda work, which ones are just gimmicks.
To quote Gen Disarray "The things you can learn here", Thanks for all the replies.
345bill is offline   Reply With Quote
Old 06-23-2008, 10:37 AM   #42
Mexray's Avatar
1978 28' Ambassador
Morada , California
...and, 'there's a sucker born every day'...just make sure you aren't one of them!
Ray & Pat; Morada, CA
Real World MPG -- Avalanche & Bambi grizzy On The Road... 13 06-15-2011 09:06 AM
19 mpg with new diesel Grand Master Tow Vehicles 7 03-08-2008 08:21 PM
Real Answers for Real A/C questions nbk3ad2 Furnaces, Heaters, Fireplaces & Air Conditioning 10 02-06-2007 08:51 AM
First real trip; real dumb mistake... myoung On The Road... 49 03-29-2006 07:37 PM
tornado and mpg ALANSD Airstream Motorhome Forums 3 07-21-2002 08:05 PM
