Old 04-16-2019, 02:03 PM   #1
2018 28' Flying Cloud
Mahomet , Illinois
Question best small air compressor
Just trashed my small air compressor, one I carried around on the road to inflate tires, blow out lines when winterizing. So now I'm hoping to get good recommendations for a good compressor, one which would do those tasks without taking all afternoon to inflate a tire. Light weight and compact would be ideal, but powerful enough to do the basics efficiently. Good ideas?
wtrclrptr is offline   Reply With Quote
Old 04-16-2019, 02:07 PM   #2
SeaLevel's Avatar
2016 25' Flying Cloud
Jupiter , Florida
We like our Viair portable air compressor. They make some different models depending on what you need and how much you want to spend. We got this one: https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
"A good traveler has no fixed plans, and is not intent on arriving." - Lao Tzu
SeaLevel is offline   Reply With Quote
Old 04-16-2019, 02:38 PM   #3
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
Not the smallest, but this is what I use. It's not just an air compressor, but it's also a jump starter, and it has both a 12v power outlet and a USB port, and has a small LED work light attached so you can see what you're doing at night. Having an air compressor that doesn't have to be plugged in while airing up a tire offers increased utility as well.
Cats and ultraleather Airstream upholstery don't mix!
Old 04-16-2019, 03:19 PM   #4
Mollysdad's Avatar
I bought the Viair 400P-RV kit.
It's the pump that provides more air than the 450, but cannot run continuously. It's never been a problem.
In all honesty, save yourself some money and don't buy the full blown kit. Two hoses? With the Airstream you can reach all the tires with one hose, and the times I've connected two they turned into a tangled mess I gave up on. Also, the kit comes with a 12" long air chuck. I've never used it. I love the gauge and trigger.
So, the unit that checks all the boxes, IMO, is the Viair 400-P (not RV)and it almost $100 less on Amazon.
Old 04-16-2019, 03:51 PM   #5
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
A 'portable'(Vair), pump is not a compressor, there is no tank to hold the compressed air. I have one to take on the road, but use a compressor at home for winterizing.
A pancake would be a good option for Winterizing at home, patience necessary it's a slow process. If you have a generator it is an on the road option.
I used a Black & Decker AC powered fo years on the road.👍
W. H. Auden
"The hardest thing about Airstreaming, clearing your head and accepting how others feel itís supposed to be done"Ö..
Amanamus
"Tahawus"
Old 04-16-2019, 04:00 PM   #6
z , Texas
This is the one I got it will winterize and inflates tires but it is slow,
https://www.homedepot.com/p/ANVIL-2G...247A/302862443
5150mike is offline   Reply With Quote
Old 04-16-2019, 05:30 PM   #7
Thank you. Nomenclature is important. I do have a compressor that I keep at home, that I can use for winterizing. But the pump/jump starter is what I carry on the road.
Old 04-16-2019, 06:50 PM   #8
SeaLevel's Avatar
Jupiter , Florida
This thread is about 12V DC air compressors, that need to run continuously to inflate an object like a tire or sports ball, not the typically much larger AC driven air compressors that include a pressure vessel to accumulate compressed air. Even a manual hand bike pump compresses air.
Old 04-16-2019, 07:25 PM   #9
While nomenclature is important, there's no need to get pedantic about it. "Air pump vs. compressor" doesn't need to go the same route as the recurring "propane tank vs. cylinder." For the sake of our collective sanity, let's just say a compressor has a tank (and a pump to fill the tank) and a pump by itself doesn't have an attached tank.
Old 04-16-2019, 07:28 PM   #10
2020 Classic 33 on order
Box Elder , South Dakota
I've used the ViAir to do the blowouts in the winter. Added an inline pressure regulator to regulate to 55#'s or so and have had no issues. Becomes more of two person job, one opening the various water valves the other triggering the air, but I have done it by myself.
Gary
2020 Classic 33 Twin on order
NōVPN
ghaynes755 is offline   Reply With Quote
Old 04-17-2019, 09:33 AM   #11
urnmor's Avatar
2012 25' Flying Cloud
Berlin , Maryland
Agree with Molly Dad's The Air
urnmor is offline   Reply With Quote
Old 04-17-2019, 10:24 AM   #12
AirMiles's Avatar
2017 25' Flying Cloud
Apollo Beach , Florida
I had a couple different 12V air pumps that took forever to fill 80 PSI tires. This one from Home Depot was complete junk: https://www.homedepot.com/p/Husky-12...D12A/301753171
Now I carry a $99 150-PSI Porter-Cable pancake compressor powered by my generator which can easily adjust my 80-PSI tire pressures:
https://www.homedepot.com/p/Porter-C...2002/203162815
2017 Flying Cloud 25FB (Miles) 234 nights 31,732 miles
400W Solar, 230AH 6V Batteries, PD4655 Converter, Champion DualFuel Generator, ProPride 1400# Hitch, 16" Michelin's
2019 F250, 6.7 Power Stroke, 4x4, 1.5" Leveled (Sully)
Sold: 2013 Casita SD17 89 nights 16,200 miles
AirMiles is offline   Reply With Quote
Old 04-17-2019, 10:27 AM   #13
The Tin Man
2017 27' International
SoCal , California
+1 for the Viair 400-P
2017 Serenity 27FB
Registry Name
"Rivets for the Tin Man"
WBCC #4913
sandollars is offline   Reply With Quote
Old 04-17-2019, 10:31 AM   #14
Caffeinated's Avatar
2015 27' Flying Cloud
Portland , Oregon
Viair. They work great.
Mike
2015 27ft FC FB
WBCCI #3960
2019 F150 ecoboost
Caffeinated is offline   Reply With Quote
Do we go small or really small KelloggKid Buyer Guidelines 50 12-15-2015 09:18 AM
credenza, dining table, small table for top of credenza, small table from other side of trailer janeinthemtns Airstream Classifieds 1 09-25-2014 05:24 PM
small compressor YACHTSTER Land Yacht/Legacy Motorhomes 2 09-27-2010 08:37 AM
air bag air compressor dbyar Mechanics Corner - Engines, Transmission & More... 12 05-08-2004 12:58 PM
Air conditioner compressor rdm Mechanics Corner - Engines, Transmission & More... 2 05-13-2002 06:54 AM
