Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Motorhome Forums > Mechanics Corner - Engines, Transmission & More...
Old 03-08-2006, 06:20 PM   #1
jim8860
jim8860's Avatar
Profile:
Bent Wheels
I developed a shake in my MH . The shake felt like tire balance so I took the MH to work today and "spun" the tires up on our high tech balancer The Hunter GSP9700 http://www.hunter.com/pub/product/ba...159T/index.htm
From what I measured the passenger side wheel has a bend or just plain out of round, the wheel has to much "roadforce" over 43lbs. My question is can my 19.5 steel wheel bend? They look so heavy duty I just can even think of that option , and also where is the best place to buy a new wheels . Thanks Jim
jim8860 is offline   Reply With Quote
Old 03-08-2006, 07:04 PM   #2
ralley
Profile:  Prince Frederick , Maryland
wheels
Any piece of steel can bend. Have the tire dismounted and test the wheel separately, or, if you can, jack up your vehicle and turn the wheel by hand near an index point set on the wheel. Use a micrometer to measure any change. Measurable change will require help.
R
ralley is offline   Reply With Quote
Old 03-08-2006, 07:17 PM   #3
overlander63
overlander63's Avatar
Profile:  1974 31' Sovereign
soon to be , on the move again
Images: 58
Oh, yeah, they can bend...
They really can bend. Even though your wheels are very heavy duty, you also have a very heavy vehicle exerting force on them, when you hit a pothole, you put thousands of pounds of force on the edge of the rim. And if you scuff a curb, you have up to ten thousand pounds of force pushing the wheel sideways. You may be able to get a replacement steel wheel from a medium/heavy duty truck dealer. I located one for another forum member's motorhome at the local International Truck dealer, for around $100 new. They will ask if your wheels are hub centered, or lug centered, and how much offset you have. Hub centered is when the hub has a ridge on it to hold the wheel in place, lug centered is where the holse for the lug nuts have a bevel so the beveled lug nuts will hold the wheel centered.
Change is inevitable, except from a vending machine
AIR#2611
overlander63 is online now   Reply With Quote
Bent (?) Door Jabba Doors & Locks 1 10-26-2002 10:44 PM
Bent Trailer Door Argosy74 Doors & Locks 3 09-03-2002 08:31 AM
Airstream steel wheels davidz71 Our Community 5 05-23-2002 07:50 AM
Best wheels & Tires... Andy R Wheels 4 04-15-2002 10:41 AM
Cooking Forum - Sailing Forum - Early Retirement - Airstream Trailer - Aquarium Forum - Royal Forum - Book Forum - Yoga Forum - Volkswagen Touareg Forum - Jeep Wrangler Forum - Whitewater Kayaking & Rafting Forum - Fiberglass RV Forum - U2 Forum
